ivanhoe90
Errors in PSD specification
Sep 24, 2013 5:39 PM
Tags: #read #format #psd #specification
Hello,
I am trying to make a program, which loads and parses PSD files. I am using this specification: http://www.adobe.com/devnet-apps/photoshop/fileformatashtml/ from June 2013.
I have found many errors and incomplete things. The last problem I am stuck at is Virtual Memory Array List - http://www.adobe.com/devnet-apps/photoshop/fileformatashtml/#VirtualMe moryArrayLis
In docs, it says, that there is
4   Boolean indicating whether array is written
4   Length
4   Pixel depth: 1, 8 or 16
1   Compression mode of data to follow. 'Pat2' compression is zip.
Variable    Actual data based on parameters and compression
But all PSD files I have actually contain
4   Length
16  Rectangle for pattern (same rectangle is there twice + once for each pattern channel = five times!)
2   Pixel depth again, but as Short
Varialbe    Some random bytes of random length (20 ~ 200 bytes). No idea what is inside, what they are used for. About half of them are "continuous" zeros.
Can Adobe specify these data and update the document? I think those errors are there for years.
    Sep 25, 2013 11:50 AM   in reply to ivanhoe90
    I can take a look. Can you give Photoshop steps to create the file in question? Which version of Photoshop created the file? Did you try Toby's parser? Does it have issues with the file in question?
    http://telegraphics.com.au/sw/product/psdparse
    Oct 3, 2013 12:10 PM   in reply to ivanhoe90
    VMArrayList.PNGTry this version. The online update will come soon.
    Oct 3, 2013 12:28 PM   in reply to ivanhoe90
    Photshop code + parsing an actual file out of Photoshop CC. There should be no "extra" data. My guess is that you are not looking at number of channels + one for user mask + one for sheet mask. Make sure you loop number of channels + 2. Make sure you are skipping non written and no length arrays.
