Photoshop CC x64 Constructor Error
Sep 25, 2013 3:26 PM
Tags: #photoshop #error #script #constructor #cc
I recently upgraded from Photoshop CS6 to CC. When I try to run the Image Processor script on PS CC x64 I get the following error message -
Reference Error: Windows dows not have a constructor: 325
The Image Processor script will not run.
The odd thing is that if I switch to PS CC x86 the same script will run just fine.
Does anyone have an idea as to what is going on.
    Sep 25, 2013 4:21 PM   in reply to sjhoyes
    Sounds like you moved or deleted some of the support scripts that ImageProcessor needs, and only from the 64 bit directory.
    Sep 26, 2013 12:45 PM   in reply to sjhoyes
    Well, somehow the support scripts have gone missing after you installed the app.
    Or you copied scripts from an older version and replaced the ones required by the current version.
    Sep 26, 2013 1:13 PM   in reply to sjhoyes
    Everytime someone reported this, we found that they (or someone in their household) had deleted or moved the scripts, or tried to copy the scripts from a previous version of Photoshop.
  • Noel Carboni
    Dec 23, 2006
    Sep 26, 2013 5:44 PM   in reply to sjhoyes
    You didn't KNOWINGLY do anything to a Photoshop directory.
    In the long run you might want to remove and reinstall Photoshop when it's convenient.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Sep 27, 2013 9:58 AM   in reply to sjhoyes
    I understand.
    You might only need to uninstall Photoshop and reinstall; assuming you don't use the Photoshop Creative Cloud Removal tool (which is very aggressive), plug-in software should not be touched by a simple uninstall / reinstall.
    It's also possible one of your plug-ins isn't compatible with Photoshop CC 14.1.2.  Have you tried running without the plug-ins?  You can start Photoshop temporarily without 3rd party plug-ins by holding down the Shift key while cold-starting Photoshop.
    -Noel
