How to Place an image onto a document?
Sep 25, 2013 10:12 PM
Tags: #photoshop #mac #c++ #plugin #plug-in #sdk #cc #objective-c #placeevent
I've been trying to build a plugin for placing images onto Photoshop document using a Mac that is based on the current "Dissolve" project provided in the CC SDK.
I'm at the stage of trying to place an image on a document. To figure out the code for this I've built the Listener plugin and ran through the steps of using Photoshop's "File:Place..." menu item to place an image (I've so far tried gifs and EPSes) onto a document. I then looked at the code generated and tried to build a function to do what I wanted from that.
However, when I try to run it I hit the following error message: "Could not complete the Dissolve command because of a program error."
I'll append the current form of my code to the end to avoid cluttering my comments.
If I comment out the line with "sPSActionControl->Play(" then the error goes away. (Of course nothing then happens.)
Some notes:
1) I didn't retain the exact layout of the output of the Listener plugin. The compiler complained about the goto methods that Listener added.
2) I'm running this in a objective-C++ class (that's triggered through a file with a .mm postfix).
3) There's NSLog statements to help me figure out the problem. I see number 7 but I never see the final error code. Looks like an exception.
4) I've retained older code that I tried, by commenting it out, so you'll see some of my thinking as I struggled with this.
Any ideas or suggestions?
- (SPErr)photoshopPlayeventPlace:(char *)cPath
NSLog(@"photoshopPlayeventPlace %d", 0, NULL);
PIActionDescriptor result = NULL;
// PIActionDescriptor desc0x100 = NULL;
// PIActionDescriptor desc0x108 = NULL;
Auto_Desc descriptor;
Auto_Desc offsetDetails;
SPErr error = kSPNoError;
Handle aliasValue = NULL;
FullPathToAlias(cPath, aliasValue);
do
// error = sPSActionDescriptor->Make(&desc0x100);
// if (error) break;
NSLog(@"photoshopPlayeventPlace %d", 1, NULL);
// error = sPSActionDescriptor->PutAlias(desc0x100, keyNull, aliasValue);
error = sPSActionDescriptor->PutAlias(descriptor.get(), keyNull, aliasValue);
if (error) break;
NSLog(@"photoshopPlayeventPlace %d", 2, NULL);
// error = sPSActionDescriptor->PutEnumerated(desc0x100, keyFreeTransformCenterState, typeQuadCenterState, enumQCSAverage);
error = sPSActionDescriptor->PutEnumerated(descriptor.get(), keyFreeTransformCenterState, typeQuadCenterState, enumQCSAverage);
if (error) break;
NSLog(@"photoshopPlayeventPlace %d", 3, NULL);
// error = sPSActionDescriptor->Make(&desc0x108);
NSLog(@"photoshopPlayeventPlace %d", 4, NULL);
// error = sPSActionDescriptor->PutUnitFloat(desc0x108, keyHorizontal, unitDistance, 0);
error = sPSActionDescriptor->PutUnitFloat(offsetDetails.get(), keyHorizontal, unitDistance, 0);
if (error) break;
NSLog(@"photoshopPlayeventPlace %d", 5, NULL);
// error = sPSActionDescriptor->PutUnitFloat(desc0x108, keyVertical, unitDistance, 0);
error = sPSActionDescriptor->PutUnitFloat(offsetDetails.get(), keyVertical, unitDistance, 0);
if (error) break;
NSLog(@"photoshopPlayeventPlace %d", 6, NULL);
// error = sPSActionDescriptor->PutObject(desc0x100, keyOffset, classOffset, desc0x108);
error = sPSActionDescriptor->PutObject(descriptor.get(), keyOffset, classOffset, offsetDetails.get());
if (error) break;
NSLog(@"photoshopPlayeventPlace %d", 7, NULL);
// error = sPSActionControl->Play(&result, eventPlace, desc0x100, plugInDialogSilent);
error = sPSActionControl->Play(&result, eventPlace, descriptor.get(), plugInDialogSilent);
if (error) break;
NSLog(@"photoshopPlayeventPlace %d", 8, NULL);
while (false);
if (result != NULL) sPSActionDescriptor->Free(result);
// if (desc0x100 != NULL) sPSActionDescriptor->Free(desc0x100);
if (aliasValue != NULL) sPSHandle->Dispose(aliasValue);
// if (desc0x108 != NULL) sPSActionDescriptor->Free(desc0x108);
NSLog(@"photoshopPlayeventPlace error:%d", error, NULL);
return error;
    Sep 26, 2013 1:36 PM   in reply to Another Andrew
    You cannot "Play" from a filter plug-in type. (Dissolve)
    You can only "Play" from an automation plug-in type. (Listener, Getter, AutomationFilter, et. al.)
