屏幕aaaa
Flex4 css error!
Sep 26, 2013 3:33 AM
I used flex sdk4.10, when open flash, it popup error as following:
ReferenceError: Error #1065: 变量 _class_embed_css_edit_gif__816087204_2003192454 未定义。
          at flash.display::MovieClip/nextFrame()
          at mx.managers::SystemManager/deferredNextFrame()[/Users/justinmclean/Do cuments/ApacheFlex4.10/frameworks/projects/framework/src/mx/managers/S ystemManager.as:286]
          at mx.managers::SystemManager/preloader_preloaderDocFrameReadyHandler()[ /Users/justinmclean/Documents/ApacheFlex4.10/frameworks/projects/frame work/src/mx/managers/SystemManager.as:2635]
          at flash.events::EventDispatcher/dispatchEventFunction()
          at flash.events::EventDispatcher/dispatchEvent()
          at mx.preloaders::Preloader/timerHandler()[/Users/justinmclean/Documents /ApacheFlex4.10/frameworks/projects/framework/src/mx/preloaders/Preloa der.as:525]
          at flash.utils::Timer/_timerDispatch()
          at flash.utils::Timer/tick()
Maybe it related with CSS, but i don't know the real reason, i don't know what's meaning about "_class_embed_css_edit_gif__816087204_2003192454"? Who can help me? Any suggestion will appreciate.
    Sep 26, 2013 10:42 PM   in reply to 屏幕aaaa
    you should give some example code, so we can analyse.
    sometimes, if you compile module optimize for application A, then you load this module in Application B, will happen some like this problem
    Sep 29, 2013 8:32 PM   in reply to 屏幕aaaa
    Every release tries to speed up compilation by making "improvements" to incremental compilation, which tries to minimize the number of things that need to be re-compiled.  Looks like there may have been an issue with 4.5's compiler.
