Cubby199
Can Someone Please Help Me Do This? .png (photoshop touch) to vector for a t-shirt
Sep 26, 2013 8:31 PM
Tags: #illustrator #help #export #convert #vector #question #.png #t-shirt
Hello, Im new to this community but ive been playing around with bits of adobe suite.  I am currently trying to get a crash corse on vector graphics and illustrator.  Basically i want to design a t-shirt for a school in my area.  The problem is the company would like a vector file.  Also i origionally made the design on photoshop for ipad, so the files are not vector.  The design is fairly simple and i am confident me and adobe can trace it properly.  Can someone guide me through how to do this list of things?
1. Import a .png file keeping its transparent backgrounds (i have white text and when i try it blends the text in with the background)
2. Have adobe trace the shape and convert it into vector
3. Edit it so it only uses black, white, and transparent.
4. Save it as a high quality .jpeg or other format (for approval by the teacher)
5. Save it as a "vector file" (for the company)
Can anyone guide me through doing this in Illustrator?
Thankyou for your help!
    Sep 26, 2013 9:04 PM   in reply to Cubby199
    make all your objects black and allow the background to be white. This will help illustrator to separate the objects and ignore the background. Once the tracing is done, then you can set the colors to what you want.
    You did not mention what version of illustrator you have as it has changed some, mainly the name of the tracing command
    Once you open the png, make sure the image is selected, then you should find the tracing button in the top tool bar.
    After the image has been traced, you can the see the tracing tools in the top tool bar, there you will find the preferences for tracing. Clicking it will allow you to choose between some presets, adjust the setting to your liking and the check box to ignore white.
    When you are satisfied, you can then click the expand button in the top tool bar.
    If you are still happy with it, use file>save as to save your vector file, preferably in the ai or pdf formats.
    Next use File>Save for web or File>Export to save as a jpg or png either one can be used by your teacher. Keep in mind that jpg does not support transparency, if they plan on overlaying the objects over another file, png would be recommended.
    Saying all that, keep in mind there are times when it is way better to trace manually using the pen tool. The auto tracing feature can add extraneous points that normally would not be required. Just keep that in mind.
    Sep 26, 2013 9:51 PM   in reply to Cubby199
    If you plan on printing white on a black tee-shirt, leave the colors alone. The text must be black and the background transparent or white. The printer will substitute white ink for anyplace that is black and will apply that ink to a black tee-shirt.
    Actually it would be best to ask your printing service as they could have equipment that I never heard of or uses a new technology.
