GregoriusIII
Cerificate problem
Sep 27, 2013 2:19 AM
Tags: #export #flex-4.6 #certificate #air3.4
I'm experincing a strange problem when I try to export my app as an Air application. I had to get a new codesigning certificate from Verisign because my old one expired. When I changed certificate the problems started. When I export the Application everything seems to work but when on a fresh computer the file the publisher shows up as unknown. When I try to install the app on a computer that has the app already installed (upgrade) I get an error message telling me that the file is corrupt. The log from the install look like this:
9/27/13 11:02:29.248 AM Adobe AIR Application Installer[1407]: Application Installer begin with version 3.7.0.2100 on Mac OS 10.8.5 x86
9/27/13 11:02:29.248 AM Adobe AIR Application Installer[1407]: Commandline is: /flashbuilder/test/test.air
9/27/13 11:02:29.248 AM Adobe AIR Application Installer[1407]: Installed runtime (3.7.0.2100) located at /Library/Frameworks/Adobe AIR.framework
9/27/13 11:02:30.195 AM Adobe AIR Application Installer[1407]: Unpackaging file:///flashbuilder/test/test.air to /var/folders/6v/gxrkcq210fl4cx6qm0320sy80000gn/T/FlashTmp.uglt3I
9/27/13 11:02:32.753 AM Adobe AIR Application Installer[1407]: Application signature verified
9/27/13 11:02:32.754 AM Adobe AIR Application Installer[1407]: Unpackaging/validation complete
9/27/13 11:02:32.758 AM Adobe AIR Application Installer[1407]: No app located in directory /Users/myuser/Downloads/test/Payload 3/test.app
9/27/13 11:02:32.758 AM Adobe AIR Application Installer[1407]: Got an unexpected fatal error while unpackaging: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Missing necessary file META-INF/AIR/application.xml" errorID=0]
9/27/13 11:02:35.897 AM Adobe AIR Application Installer[1407]: Application Installer end with exit code 7
This log does not really seem related to the signing issue. But it might be related to te fact that the app used to be signed and now is not.
I have also tried to export the file to airi fromat and manually signed the package. It seems to work but the thr result is the same. The command I used to sign id:
adt -package -storetype pkcs12 -keystore ./Docs/Cert/test.pfx test.air test.airi
Hopefully somone knows whats going on.
Best
Greg
