Fizzybuzzy
How to make menu buttons for Photoshop / InDesign panels
Sep 29, 2013 7:00 AM
Tags: #indesign #extension_builder_2.1
I'm sorry I don't know quite what the button is called, but it exists in most InDesign panels: it's the small icon with four lines and a down arrow that appears in the top-right of panels, and usually gives detailed options that would otherwise be hidden. In Kuler it shows Terms Of Use and Privacy Policy, for example.
This seems like a really common thing to have in Creative Suite extensions, but I don't know how to create one - partly because I don't know what the darn thing is called to be able to search for information on Google!
Can someone enlighten me how to create a couple of menu items in there?
    Oct 2, 2013 1:17 AM   in reply to Fizzybuzzy
    This is called the flyout menu. Further information can be found from the following link:
    http://cssdk.adobesites.com/sdk/2.1/docs/WebHelp/programmers_guide/cus tomizing_the_ui.htm - see 'customising panel menus' section
    Kind regards,
    Lea
    Oct 17, 2013 4:29 AM   in reply to lesavage
    unfortunatly the link do not work anymore.
    I got a problem creating panel menu for indesign cc using FlashBuilder 4.6:
    "CSXSInterface.getInstance().setPanelMenu(xmlMenu);"
    the FB mean CSXSInterface is not supported and recommend to use CSInterface.
    But CSInterface do not know "setPanelMenu" and CSInterface shows nothing in FB - no properties, no methods...
    How the panel menu shall be created for indesign cc? - thx in advance
    EDIT:
    setPanelMenu()method
    public function setPanelMenu(xmlMenu:XML):SyncRequestResult
    Deprecated Since 3.0: Please Use CSInterface.panelMenu
    nice, but CSInterface has no panelMenu property or method.... any suggestions?
    EDIT2:
    CSExtention is the right class with panelMenu.
    Anyone got an idea how to access it within mxml file? using "this"?
    FB knows this.panelMenu(...) but mark it as error 1061
    EDIT 3:
    all problems are solved.
    CSExtention.panelMenu is a property not a method.
    for all of you which has problems with panel menu:
    insteed of:
    use
    "this.panelMenu = XMLstring;"
