cgascons
Ant build failed, 'compiler.extensions' unknown configuration variable
Sep 30, 2013 1:58 AM
Tags: #flash #builder #extensions #compiler #ant_build
Hi, I'm trying to compile a SWC via an ANT build file loading my configuration xml file generated from Flash Builder. The compiler is whining about the compiler.extensions, it says is an unknown configuration variable, here's the stack:
Buildfile: C:\Users\cgascons\Documents\workspace\TCGEngine\build.xml
generateAssets:
     [echo] Target::generateAssets
compile:
     [echo] Target::compile
    [mxmlc] Unknown:compiler.extensions
    [mxmlc] Loading configuration: C:\Users\cgascons\Documents\workspace\TCGEngine\ant_config.xml
    [mxmlc] C:\Users\cgascons\Documents\workspace\TCGEngine\ant_config.xml:8
    [mxmlc] Warning: 'compiler.accessible' is not fully supported.
    [mxmlc]       <accessible>false</accessible>
    [mxmlc] C:\Users\cgascons\Documents\workspace\TCGEngine\ant_config.xml:49
    [mxmlc] Error: unknown configuration variable 'compiler.extensions'.
    [mxmlc] C:\Users\cgascons\Documents\workspace\TCGEngine\ant_config.xml (line: 49)
    [mxmlc]       <extensions>
BUILD FAILED
C:\Users\cgascons\Documents\workspace\TCGEngine\build.xml:18: mxmlc task failed
Does anybody know what could be happening here?
