squawk ident
Greyed out icon on iPad
Oct 3, 2013 11:04 AM
The .ipa file for the app has been loaded into iTunes - and when synched with the ipad it turns gray after completely downloading.  When the greyed out icon is tapped it shows "installing".  The same indication remains on iTunes.  The app was built using version 27.  The ipad has iOS 7. Has this anything to do with the version I am using?
    Oct 3, 2013 1:57 PM   in reply to squawk ident
    Are you sure your device is correctly added to the mobileprovision file you used when building the application?
    Neil
    Oct 3, 2013 3:39 PM   in reply to squawk ident
    Have you recreated the developer mobileprovision file as well as the p12 file, rebuilt with them and tried to install? Another user's problem was resolved that way.
    http://forums.adobe.com/message/5634369#5634369
    Oct 3, 2013 4:14 PM   in reply to squawk ident
    Are you attempting to install a distribution or developer signed application? You can only install the developer-signed application. The distribution signed application is not intended to be installed in this manner. Updating the developer certificates should not invalidate the application that customers get from the App Store.
    Oct 6, 2013 12:35 PM   in reply to squawk ident
    This is the same problem I'm having with loading my dev ipa to my iPad via iTunes. It's v27, and I have the latest version of iTunes. The icon is grayed out and then goes into an endless loop of "Installing." I've tried this on both test devices linked to my apple dev account, one running ios 6 and the other 7.
    Doesn't work on either one.
