How do I import AVI video with stereo audio (and keep it that way)?
Oct 3, 2013 4:41 PM
Today I just discovered that all the AVI video with stereo audio I've ever imported into a Premiere Pro CS6 project has been mysteriously converted to mono. And I can't find any import setting anywhere that enable me to change this.
Here's the deal...
I've have an AVI file with stereo audio (the file is actually a stereo sound test that I downloaded to prove that I wasn't imagining things). On my hard drive, I right-click and view the properties:
Video
Length: 00:00:36
Frame width: 320
Frame height: 240
Frame rate: 25 frames/second
Audio
Bit rate: 128kbps
Channels: 2 (stereo)
Audio sample rate: 44 kHz
I click on it to play and listen with headphones--everything is playing in the correct part of the stereo spectrum. Then, I import it to Premiere, click the file name in the left content menu, and check the properties, suddenly they read:
Type: AVI Movie
File Size: 1.1 MB
Image Size: 320 x 240
Frame Rate: 25.00
Source Audio Format: 11025 Hz - 16 bit - Mono
Project Audio Format: 11025 Hz - 32 bit floating point - Mono
Total Duration: 00:00:36:15
Pixel Aspect Ratio: 1.0
Sure enough, I drag it into the sequence, listen to it, and it's indeed playing mono. Outside of Premiere, the original source file still reads and plays correctly with stereo sound.
When I import stereo WAVs and MP3s, it keeps the original stereo channels without me having to do anything special. I even just imported the same exact file as a MOV with stereo audio, and it showed up in Premiere as:
Source Audio Format: 44100 Hz - 16 bit - Stereo
Project Audio Format: 44100 Hz - 32 bit floating point - Stereo
What is going on here with AVIs? Am I doing something wrong? Are there settings I'm missing somewhere?
(And before anyone suggests I only use MOV in the future... that's not exactly the answer I'm looking for.)
    Oct 3, 2013 4:50 PM   in reply to oldpantsnewjersey
    Welcome to the forum.
    I might have missed it, but what is the Audio CODEC used for that AVI's Audio Stream?
    Also, to edit Audio, PrPro WILL have to Conform your Audio, so the 32-bit Floating Point is what you should see. What should NOT happen, is for a 2-channel (Stereo, in your case), to be converted to 1-channel (Mono).
    Oct 3, 2013 5:00 PM   in reply to oldpantsnewjersey
    Thank you for that info.
    For video, the codec is MPEG-4 Video (XVID) and for audio it says MPEG Audio Layer 1/2/3 (mpga).
    There are two issues with that file:
    The first is the Xvid CODEC (not meant for editing), and then the MPEG Audio/MPGA. I would convert that file, to something that is more editable.
