Streaming using livepkgr Cache issues
Oct 8, 2013 10:11 AM
Tags: #ams
[root@localhost channel777]# ls -l
total 268280
-rw-rw---- 1 ams ams      6430 Oct  8 11:59 channel777.bootstrap
-rw-rw---- 1 ams ams        16 Oct  8 11:59 channel777.control
-rw-rw---- 1 ams ams       434 Oct  8 11:29 channel777.meta
-rw-rw---- 1 ams ams 274679787 Oct  8 11:59 channel777Seg1.f4f
-rw-rw---- 1 ams ams     14649 Oct  8 11:59 channel777Seg1.f4x
This feild -rw-rw---- 1 ams ams 274679787 Oct  8 11:59 channel777Seg1.f4f really concerns me for 2 reasons
Reason
#1 Why does the file get so large? IE: 14 GB before i restart FMLE and Delete the stream data manually. if i don't delete cache iphone/ipad doesn't play correctly when i restart stream.
#2 When i restart FMLE it doesnt delete cache automaticly like Wowza Server.
Im using AMS Extended 5.0.1 r1076
Any suggestions or comments are welcome
    Oct 8, 2013 10:38 AM   in reply to bluraymakulit2
    You do not have diskmanagment enabled for the livepkgr application in the /application root folder.   It needs to reside in /applications/livepkgr/events/_definst_/liveevent/Event.xml
    Google search for samle Event.xml for the livepkgr application.  You can then slice and dice the segments in an array for configurations to suite your server application.
    total 268280
    Reason
    Oct 8, 2013 12:10 PM   in reply to bluraymakulit2
    It is not Application.xml
    <Event>
      <EventID>liveevent</EventID>
      <Recording>
        <FragmentDuration>4000</FragmentDuration>
        <SegmentDuration>400000</SegmentDuration>
        <DiskManagementDuration>1</DiskManagementDuration>
      </Recording>
    <HLS>
        <MediaFileDuration>8000</MediaFileDuration>
        <SlidingWindowLength>0</SlidingWindowLength>
    </HLS>
    </Event>
    It is Event.xml located in the livepkgr instance    /opt/adobe/fms/applications/livepkgr/events/_definst_/liveevent/Event .xml
    Obviously you will substitute "livepkgr" to the name of your application.
    Oct 8, 2013 12:23 PM   in reply to bluraymakulit2
    No, Diskmanagment is the length in hours that files will be deleted. It will only keep 1 hour of 4 second 400,000kbyte files, in my example.
    Oh ok i see that my DiskManagementDuration>1</DiskManagementDuration>
    is set to 3 by default do i need to change it to 1?
    what other things will i change?
    Oct 8, 2013 12:34 PM   in reply to bluraymakulit2
    That is enabled yes.
    What also could be skipping the Event.xml
    is you are not adding the string identifer in the rtmp sream URI     rtmp://foo.bar/livepkgr/channel777?&adbe-live-event=liveevent
    If you don't specificy the string 'liveevent', then it will not use <EventID>liveevent</EventID>
    rtmp://foo.bar/livepkgr/channel777?&adbe-live-event=myevent
    <EventID>myevent</EventID>
    No identifier... Defaults to NULL, no diskmanagment.
    Oct 9, 2013 8:47 PM   in reply to bluraymakulit2
    Wow. 10gig.. Big file.
    are you missing the main.far or main.asc file in the /livepkgr root?
    What is the full RTMP URI?
    Im still seeing huge files
    total 10225424
    -rw-rw---- 1 ams ams      262640 Oct  9 22:39 channel777.bootstrap
    -rw-rw---- 1 ams ams          16 Oct  9 22:39 channel777.control
    -rw-rw---- 1 ams ams         434 Oct  9 03:18 channel777.meta
    -rw-rw---- 1 ams ams 10469977121 Oct  9 22:39 channel777Seg1.f4f
    -rw-rw---- 1 ams ams      557337 Oct  9 22:39 channel777Seg1.f4x
    and 45 second delay on iphone and only 3 second delay on windows
    for live stream
    Oct 10, 2013 2:59 PM   in reply to bluraymakulit2
    just a quick question was that 45 second delay also in Wowza or just in AMS, I did have on average a 35 second delay with iphones with Wowza, curious if the same will happen in AMS
