wyatltaylor
Trouble with Area Type Tool
Oct 8, 2013 3:30 PM
Tags: #help #type #compound_paths #area_type_tool
I'm currently trying to place body copy text inside all that is teal. I have outlined the graphic, and released the compound paths. I have gotten as far sa clicking the edge of the circle and then being able to type within the circle. But how do I make it so the "CH" and "College Hill" are essentially cut into the circle so the text must go around them as well?
Thank you!
    Oct 8, 2013 3:47 PM   in reply to wyatltaylor
    Wyat,
    As I (mis)understand it, you may have/bring the graphic (CH & College Hill) in front of the Type to wrap, select both/all, and then Type>Wrap>Make.
    Oct 8, 2013 5:14 PM   in reply to Jacob Bugge
    In my version this us under Object > Text Wrap > Make.
    Wyat, Text Wrap Options in the same menu where you can control the offset is easier to choose using the preview after applying the wrap with with the wrapped object selected.
    Oct 8, 2013 5:58 PM   in reply to wyatltaylor
    the first image on the left is what we were explaining, the two images on the right is another guess of mine. The images on the right were simply created with the Area Type Tool by clicking in each path and pasting. The paths must be simple and not compound. Letters with wholes like the g at the bottom is two simple paths (not compound) first you fill the outer path  with text and use the inner path to wrap around as suggested in the first guess from Jacob and me.
    If these are still not what you are looking for, draw a sketch of what you are trying to achieve.
    Oct 8, 2013 6:11 PM   in reply to emil emil
    another 3 quick guesses while the document is still open
    May be you are not looking for wrapping but just fill the background with some clipped text?
    Pick up what is in your mind before me closing the document   All of the guesses so far qualify as "recreate this logo out of text"
