Create i:nil XML Attribute
Oct 11, 2013 7:48 AM
Tags: #xml #coldfusion8 #cf8
I need to create an XML Document with an element that requires the attribute i:nil=true. I've tried <cfset StructInsert(mydoc.employee.name.XmlAttributes, "i:nil", "true")>, but it returns the error "The right hand side of the assignment is not of type XML Node".
What I want is to create an element like this: <name i:nil="true"/>
Any help would be greatly appreciated.
    Oct 13, 2013 2:21 PM   in reply to rhpt
    What does this produce?
    <cfdump var="#isStruct( mydoc.employee.name.xmlAttributes )#" />
    If it's Yes/True, I think the problem here has to do with you attempting to set a key with a value that is not permitted.  Variables cannot have special characters like ':' in them.  To quickly test this, change 'i:nil' to 'i_nil' since underscores are permitted.
    The xmlAttributes() method returns back a structure of key/value pairs.
    Is it valid for an XML node to look like:
    <user lastname="smith" firstname="john" i:nil="true" /> ?
    Not sure that's allowed.
    If you're attempting to use namespaces, those are placed onto the root element <user> not its attributes.  Like:
    <i:user lastname="smith" firstname="john" />
    Oct 14, 2013 8:58 AM   in reply to rhpt
    Happy you got it rolling, but I gotta say I'm very surprised here.
    To my knowledge the xmlAttributes() function returns a structure, which is just a series of name/value pairs.  I guess I'm so used to keeping special characters outside of my variable names that I never really tried to set one with a colon in it.  Come to think of it, I think CF is more concerned about the FIRST character of the variable name than subsequent ones.  Like, the variable couldn't be called ':nil', because it began with the colon, but the colon could exist as a subsequent character in the variable name.
    Good to know.
