Issue With select Check box in advance datagrid
Oct 12, 2013 10:37 AM
Hi
       i am using advance datagrid having hierarichal data.There is one column having checkbox and one header renderer(CheckBox) on top giving functionality of select all.when i clicked on select all checkbox , all the checkboxes in that column not showing checked unless  i collapse or expand the heirarichal data or scroll the advance data grid,similar is the case with unselect checkbox.however internally values are selected and unselected as per functionality but checkboxes are not show checked/unchecked in first go.i have tried following things to refersh the data but nothing worked.
refreshing the arrayCollection and then calling invalidateList() on the grid.
IHierarchicalCollectionView(adg.dataProvider).refresh();
so please  guide me .
Thanks in advance
  Vineet Osho
    Oct 13, 2013 6:59 PM   in reply to vineet osho
    we have a field to bind the checkbox selected status, such as 'selected', when the data['selected'] = true means the checkbox is checked, otherwise is unchecked
    the itemrenderer code:
    public class CheckBoxADGItemRenderer extends CenteredCheckBox
                        public function CheckBoxADGItemRenderer()
                                  super();
                        override public function set data(value:Object):void
                                  super.data = value;
                                  invalidateProperties();
                        override protected function commitProperties():void
                                  selected = data['selected'];
                                  super.commitProperties();
    when click the header renderer checkbox, change the collection data 'selected' field, when checked, data['selected'] = true;
    then invalidate the check column properties,
    eg:
    private function invalidateCheckColumnProperties():void
                                  var i:int = 0;
                                  var n:int = listItems.length;
                                  var instance:IInvalidating;
                                  for (i = 0; i < n; i++)
                                            instance = listItems[i][0] as IInvalidating;
                                            if (instance)
                                                      instance.invalidateProperties();
    Hope help for your.
    Huang
