Proper application design - hardcoded vs dynamic
Oct 13, 2013 1:17 PM
We have a table, 2 columns.  ID and NAME.  When our application installs, the script writes 3 records to it in the following sequence: 'Admins', 'Users', 'Visitors'.  So one would think, the table data looks like:
ID - NAME
1 - Admins
2 - Users
3 - Visitors
So, when it comes to coding the application, is it better practice to assume that "Admins will always have an ID of 1, so I can write a SQL statement that may reference:  WHERE ID = 1 -- These are admins
Or should I be dynamic, where I would build a function called: getIDByName() and you can pass in the name 'Admins' and it will perform a SQL run and return back the number 1.  This would mean that when I write the above SQL statement I would say:
.... WHERE ID = getIDByName( 'Admins' ) -- Admins
I have a feeling that dynamic is the better approach, even though it means I'll have to code in more functions to automate it.
    Oct 14, 2013 8:21 AM   in reply to Aegis Kleais
    Aegis,
    Is the "ID" column an auto-incrementing identity column that is controlled by the underlying database?  If so, I would err on the side of caution and not assume that the records will be written in the precise order you want.  What you might do is query that table once and cache the results in an application scope variable, then query that as needed to get the IDs as needed (saving multiple round trips to the database to retrieve the IDs over and over again.
    HTH,
    -Carl V.
    Oct 14, 2013 9:28 AM   in reply to Aegis Kleais
    Glad that worked out!
    -Carl V.
