yuanfei_1984
flash.net.NetConnection limit
Oct 14, 2013 1:52 AM
Tags: #netconnection.connect
For load testing, I'm trying to connect to FMS server with multiple connections in a single air application. However, it seemed the connection is limited by air and only the first couple of connection requests are sent. The program is listed below, and I found only 180 out of 200 connections are connected successful, the connection.connect of the rests are called, but no packet is sent (monitored through network  sniffer) and no NetStatusEvent is raised. I doubt there is a limit for the NetConnection number by which more connection requests are forbidden. I'm using the flex sdk 4.5 on a windows workstation, any ideas?
package
import flash.display.Sprite;
import flash.events.NetStatusEvent;
import flash.events.TimerEvent;
import flash.net.NetConnection;
import flash.utils.Timer;
public class TestNetConnection
  private var timer:Timer;
  private var cons:Array=new Array();
  private var index:Number=0;
  public function TestNetConnection()
   for(var i:Number=0;i<200;i++){
    cons.push(new Connector(i));
  public function start():void{
   timer=new Timer(200,200);
   timer.start();
   timer.addEventListener(TimerEvent.TIMER,startEgm);
  public function startSync():void{
   for(var i:Number=0;i<cons.length;i++){
    Connector(cons[i]).connect();
  private function startEgm(event:TimerEvent):void{
   Connector(cons[index]).connect();
   index++
package
import flash.events.AsyncErrorEvent;
import flash.events.IOErrorEvent;
import flash.events.SecurityErrorEvent;
public class Connector
  private var index:Number;
  private var rtmpClientConnection:NetConnection;
  public function Connector(i:Number)
   index=i;
  public function connect():void{
   trace(index+': '+'connecting');
   rtmpClientConnection=new NetConnection();
   rtmpClientConnection.client=this;
   //mRTMPClientConnection['isAlive']=Delegate.create(this,isAlive);
   //mRTMPClientConnection['mmrCommStatus']=Delegate.create(this,mmrComm Status);
   rtmpClientConnection.addEventListener(AsyncErrorEvent.ASYNC_ERROR, asyncErrorHandler );
   rtmpClientConnection.addEventListener(IOErrorEvent.IO_ERROR, ioErrorHandler );
   rtmpClientConnection.addEventListener(NetStatusEvent.NET_STATUS, netStatusHandler );
   rtmpClientConnection.addEventListener(SecurityErrorEvent.SECURITY_ERR OR, securityErrorHandler );
   rtmpClientConnection.connect("rtmp://XXX.XXX.XXX.XXX/IGT.SB.MMR","CLI ENT",0,'test_'+index);
  public function close():void{
   trace(index+': '+'closing');
   rtmpClientConnection.close();
  protected function securityErrorHandler(event:SecurityErrorEvent):void
   trace('security:'+event);
  protected function ioErrorHandler(event:IOErrorEvent):void
   // TODO Auto-generated method stub
   trace('ioErrorHandler:'+event);
  protected function asyncErrorHandler(event:AsyncErrorEvent):void
   trace('asyncErrorHandler:'+event);
  protected function netStatusHandler(event:NetStatusEvent):void
   trace(index+': '+event.info.code);
   TestConnection.instance.Update(index+': '+event.info.code);
