mwphotodesign
EOF?
Oct 15, 2013 6:22 AM
Kennt jemand die Meldung in Photoshop, dass das Ende der Datei (EOF) erreicht ist und photoshop diese nicht öffnen kann?
  • Noel Carboni
    Dec 23, 2006
    Oct 15, 2013 7:30 AM   in reply to mwphotodesign
    mwphotodesign wrote:
    Does anyone know the
    message in Photoshop that the end of file (EOF) is reached and photoshop can not open this?
    It sounds as though you have a truncated file (i.e., not all the data is there).
    If it is a file you previously saved, check your system log for disk errors.  Also check your file system integrity (e.g., CHKDSK on a Windows system).  It could be a serious problem and should be dealt with immediately before you lose more data.
    If it is a file you received via a communications link (e.g., internet download or eMail attachment) you may want to try getting another copy.
    Also, make sure the file type is set to match the actual file format - in other words, if it is supposed to be a JPEG file, make sure the filename ends with .jpg.
    -Noel
    Oct 15, 2013 6:24 PM   in reply to mwphotodesign
    Leider bedeutet diese Meldung in 99,00% aller Fälle, daß die Datei hoffnugloss beschädigt und nicht mehr zu retten ist.
  • Trevor Dennis
    May 24, 2010
    Oct 15, 2013 7:07 PM   in reply to station_two
    That's a good one Station.  "99,00% aller Fälle"  Best punchline I have heard in ages.
