newsec
converting pdf to word Adobe Acrobat XI Pro trial
Oct 15, 2013 12:47 PM
I am using a 30 day trial of Adobe Acrobat XI Pro, when I convert a pdf to word doc, it has several hidden letters & symbols, is this because it is a trial?
    Oct 15, 2013 1:11 PM   in reply to newsec
    The trial is fully functional so, no.
    That being said, the Acrobat forum is at http://forums.adobe.com/community/acrobat. You'll want to ask your questions there.
    Oct 15, 2013 10:25 PM   in reply to newsec
    [topic moved to Acrobat forum]
    Oct 16, 2013 8:08 AM   in reply to newsec
    Your PDF probably contains these hiddens characters as well. There is an easy way to check under the Tools pane > Protection panel > Remove Hidden Information command. You can run the command and see what is hidden before actually deleting the hidden content.
    Oct 16, 2013 10:57 AM   in reply to LoriAUC
    Also be aware that the conversion to WORD is a hit-and-miss affair. A lot depends on the structure of the PDF and how it was created. Some files convert almost perfectly for basic text and graphics (equations would generally convert as images), while others have little in common with the view of the PDF.
