text on photos
Oct 16, 2013 2:46 PM
Lat ps el, i used was el 4 and had no problem wring text on a photo ....now with ps el 10 i cannot get it to work sepite following the inst i adobe help.
    Oct 16, 2013 11:22 PM   in reply to mantiboa892
    What happens when you try to write text on image using type tool.
    Oct 17, 2013 1:40 AM   in reply to mantiboa892
    Try below two things
    - Make sure that the first layer in the layers panel is selected . Then try typing.
    - If the first solution doesn't work then don't drag , instead just click on the image and start typing. When you drag and type , then probably the text is not fitting in the bounding box and therefore not visible.
    Let me know.
    Oct 17, 2013 3:14 AM   in reply to mantiboa892
    You don't need to drag . Just click on the image with the type tool and once the cursor appears start typing. Can you post a screenshot of your application . It will be easier to tell then.
    Also Follow the below steps below to check if everything is fine-
    - Go to "File Menu>New>Blank File". A new file dialog will come up. Choose 'OK'. A new blank file wil be created.
    - Select type tool (Press Shortcut  'T'. Type Tool will be selected.
    - Just click on the blank file(do not drag) and once the cursor appears start typing. The character you type will appear.
    Do let me know the result of this.
    Oct 17, 2013 7:24 AM   in reply to mantiboa892
    Please send the files to slohia@adobe.com , I will have a look at it. Did you try typing on a blank file as I suggested above . What was the result.
