BrancosScreen
Update for PSE11
Oct 17, 2013 11:28 AM
Tags: #file #a #for #raw #update #support #as #downloadable #pse11
Hello,
How can I download from Adobe site the update for PSE11, for different (new) cameras RAW files support, but the update to be in a downloadable file format, rather than automatic, so I can update PSE11 on the computer that's never connected to the internet and used only for photo editing? Does the question makes sense? Any ideas? Thanks. BS
  • 99jon
    Jan 6, 2010
    Oct 17, 2013 12:30 PM   in reply to BrancosScreen
    You have to do it from the menu in Expert Mode:
    Help >> Updates
  • 99jon
    Jan 6, 2010
    Oct 17, 2013 12:55 PM   in reply to BrancosScreen
    Sorry Adobe does not make available zip file updates for PSe11 or PSe12
    Oct 17, 2013 1:31 PM   in reply to BrancosScreen
    What operating system are you using?
    Do you have pse 11 installed on another machine of the same operating system that is connected to the internet?
    Is there a specific camera you need the 7.4 camera update for?
  • 99jon
    Jan 6, 2010
    Oct 18, 2013 1:41 AM   in reply to BrancosScreen
    Oct 18, 2013 10:09 AM   in reply to BrancosScreen
    If your installing windows on the other system (doesn't have to be windows xp), you could make sure your pse 11 is updated to camera raw 7.4 on
    your computer that is connected to the internet and then copy over the camera raw plugin and you would also need to install
    the 7.4 camera raw profiles on the windows machine not connected to the internet by installing the 7.4 DNG Converter.
    http://www.adobe.com/support/downloads/detail.jsp?ftpID=5569
    Adobe wants people to use the updater from within photoshop elements, hence no camera raw updates after 6.7 on the download page, but in your case that just won't work.
    If you need instructions on how to actually do the above, we can provide that.
    Oct 21, 2013 12:45 PM   in reply to BrancosScreen
    Do you have a portable media device like a flash drive?
    Or does your computer not connected to the internet have a dvd player?
    Oct 22, 2013 1:14 PM   in reply to BrancosScreen
    On windows xp the pse 11 camera raw plugin should be in
    C:\Program Files\Common Files\Adobe\Plug-Ins\Elements 11\File Formats
    Just copy the Camera Raw.8bi file to whatever device your going to use to copy the files from xp to your offline computer
    On the other windows computer, depending on if it's a 32 or 64 bit operating system, the pse 11 camera raw plugin should be in
    C:\Program Files\Common Files\Adobe\Plug-Ins\Elements 11\File Formats (32 bit operating system)
    C:\Program Files (x86)\Common Files\Adobe\Plug-Ins\Elements 11\File Formats (64 bit operating system)
    Replace the plugin that is already there with the one you copied over from windows xp
    Also, download the 7.4 DNG Converter and copy that installer over and install it on your offline computer so you have the correct camera raw profiles.
