phonzs
Quick question for the amazing professionals
Oct 18, 2013 7:17 AM
Hello everyone,
Im using Dreamweaver CS6
Im stuck on somehting & maybe to alot of professionals it might be easier for you.
So lets try to imagine, that I have a blank website templete, & I want to have some small amount of text
on the right side of the templete, and have a column of text going down. Now the only trick is for me
say I want to take my right corner of my window broswer and scale to make it just lttle bit smaller I
want to have that small amount on text column move with it, instead of disappearing off the screne
which I been getting.
Now, my guess use a container right? or not the best way to go about it!
So if anyone can help me solve this problem that will be amazing or anyone knows a perfect website witha great tutorial that is very close to what I need to figure out that will be amazing as well.
I tired looking on-line for something even close to what Im trying to figure out but no results
    Oct 18, 2013 7:23 AM   in reply to phonzs
    I don't understand what you are asking. Can you show us a screen shot of what you want?
    Oct 18, 2013 7:36 AM   in reply to phonzs
    I guess you are using a fixed width design set in px? You need to use a responsive or fluid contruction which used % rather than a fixed width.
    So for instance if you have a two column design you could set col 1 at 85% and col 2 at 15% both columns would still be visible on screen as you closed down the browser viewport.
    Oct 18, 2013 7:55 AM   in reply to phonzs
    It's a 3 col design what you have shown so far. The columns need to be flexible so they move with the browser viewport when it is narrowed and widened.
    Example:
    <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
    <html>
    <head>
    <meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
    <title>Untitled Document</title>
    <style>
    #wrapper {
        width: 96%;
        max-width: 960px;
        margin: 0 auto;
        background-color: #ccc;
        overflow: hidden;
    #leftCol {
        float: left;
        width: 20%;
    #centerCol {
        float: left;
        width: 60%;
    #rightCol {
        float: left;
        width: 20%;
    </style>
    </head>
    <body>
    <div id="wrapper">
    <div id="leftCol">Left Col</div><!-- end leftCol -->
    <div id="centerCol">Center Col</div><!-- end centerCol -->
    <div id="rightCol">Right Col</div><!-- end rightCol -->
    </div>
    </body>
    </html>
    Oct 18, 2013 8:21 AM   in reply to phonzs
    Its not possible with the code you are using as everything is absolutely positioned and has a specific width.
    Using absolutely positioned containers is simply the wrong approach.
