garyg
Audition 3.0
Oct 18, 2013 8:12 AM
Tags: #crash #audition #multitrack
Where can I get support for Audition 3.0?
Audition 3.0 shuts down when launched; get error message "To continue working where you left off, please restart Audition".  I tried rebooting my computer, but Audition still does not launch.  Also, I can open a .wav file with Audition and it opens in edit mode. But I can't launch Audition from the icon and can't get into multitrack mode nor open a session file.  Running on Windows 7.
    Oct 18, 2013 3:40 PM   in reply to garyg
    You could try renaming the Audition settings folder in case it has become corrupted. Audition will recreate it (hopefully) the next time you start AA3.
    C:\Users\"username"\AppData\Roaming\Adobe\Audition\3.0 where "username" is your username.
    Otherwise I think you may need to reinstall AA 3 unfortunately
    Oct 18, 2013 3:43 PM   in reply to ryclark
    If Waveform view works fine but it crashes in Multitrack view, then the culprit is very likely corrupted Workspace XML files. Deleting or renaming the Workspaces directory in the settings folder should fix that.
    Oct 28, 2013 2:12 PM   in reply to garyg
    That folder is usually hidden by default.  The quickest way to get there is to type %APPDATA% in the location box.
