When i attempt to export a release build with captive runtime i am thrown this error. I'm not sure what is meant by 'make sure your computer time is in sync' and my certificate is valid.
Our QE department was able to reproduce this issue using the currently released build of AIR. However, it appears to be fixed in our upcoming beta release (due out tomorrow afternoon.) Can you give the beta a try and let us know how it works for you?
The same problem with ant build script and "Flex 4.10 & AIR 3.9" SDK on OSX however on Windows it works fine.
Have either of you entered a bug on this over at https://bugbase.adobe.com? I'll ask the team to give this a try, is there a particular version of OSX that you're using?
I've tried on OSX 10.6.8 and OSX 10.9.
Also I've tried to generate new certificate via ADT tool from the latest SDK, I've got the same result.
"Flex 4.6 & AIR 3.5" works fine with the same certificate on OSX and Windows.
Thanks Lazy-Max! The team tried this last night but couldn't reproduce. However, they hadn't seen your bug report or test project yet so I'll ask them to check that out again.
Chris
My application contains too much private data, I can't attach it. Just several notes about my problem:
1. It's not reproducible in the Flash Builder 4.6 on OSX 10.6.8
2. It's reproducible with ant build script
3. Error is gone when I removed all <icon></icon> elements from descriptor file.
Hello ! I got the same problem. Waiting for the new Beta release.
I can confirm the new SDK release fixes this issue. I just downloaded, installed and exported a release build with capitve runtime on mac OSX Mavericks.
Thanks for the feedback!
