chasesdad
Can only draw one line segment
Oct 19, 2013 12:38 PM
I'm sure this is a simple thing but it's driving me crazy. Every time I draw a line it gets erased as soon as I try to draw the next one. Any ideas?
Thanks.
    Oct 19, 2013 12:46 PM   in reply to chasesdad
    Which version of Illustrator are you using?
    What tool are you using to draw your segments? Probably the Pencil tool? Or something else?
    Oct 19, 2013 1:12 PM   in reply to chasesdad
    Is a stroke (weight/colour) applied to the path while drawing with the Line Segment tool?
    Oct 19, 2013 5:57 PM   in reply to chasesdad
    Learn to use the Pen tool. It’s far the most versatile of the drawing tools.
    Oct 19, 2013 8:46 PM   in reply to Kurt Gold
    Or is white selected as the stroke color?
    Oct 20, 2013 2:04 AM   in reply to chasesdad
    chasesdad,
    Or, to put it in a third way: is it just invisible?
    You can switch to the Selection Tool (just press the V key) and drag over the area where it should be, and see.
    Oct 20, 2013 4:03 PM   in reply to chasesdad
    If you click 3 times with the Line Segment tool (moving your mouse between clicks) you get 2 unconnected line segments.
    If you do the same with the pen tool you get 2 connected line segments.
    Whether the segments are visible or not depends on whether they are coloured or not.
    Test this by turning off the preview (Cmd/Ctrl+Y). Your ‘erased’ lines will probably show up.
