• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
ML 10.8.5 photoshop elements 9, installer failed to initialize.
New Here ,
Oct 21, 2013 Oct 21, 2013
package for support 40-92900-072421102013
cd ~/Desktop/Adobe Photoshop Elements 9/Install.app/Contents/MacOS/
if i try to run the installer from the command line i get
> ./Install
ditto: can't get real path for source
i also tried disabling my anti-virus software, no joy ;(
installed it as root, problem solved.
Views
993
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee ,
OpenDirectoryDude is this related to the other discussion you started at http://forums.adobe.com/message/5773847#5773847?  In that discussion you were trying to install Photoshop Elements 6.0 and faced difficulties.  You then stated that Photoshop Elements 11 did install successfully.  Is there a reason which you are now also trying to install Photoshop Elements 9?
To diagnose why Photoshop Elements 9 is failing to install you will want to review the installation log files.  Please see Troubleshoot install using logs | Elements - http://helpx.adobe.com/photoshop-elements/kb/troubleshoot-install-using-logs-elements.html for information on how to locate and interpret your installation log files.  You are welcome to post any specific errors you locate to this discussion.
Votes
Translate
Translate
Report
Report
New Here ,
yes, i did try to install Photoshop Elements 6.0, it never worked.
no i never tried to install Photoshop Elements 11.0, sorry for the confusion.
we are currently installing Photoshop Elements 6.0 using root.
Votes
Translate
Translate
Report
Report
New Here ,
we did try to install after using
diskutil repairpermissions /
that did not help.
i have l tried a variety of permissions on
/Library/Application Support/Adobe/
i will look at the home directory version of this directory but i don't
understand why that would be relevant.
Votes
Translate
Translate
Report
Report
New Here ,
uggggh i'm so stressed out.
i meant to say we are currently installing Photoshop Elements 9.0 using root.
how do you edit a recent reply?
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Hi OpenDirectoryDude,
If installing the software via Root user account solves the problem, then the issue might be with the Disk / User permissions.
Please check if you have proper permissions for the following folder : ~/Library/Application Support/Adobe
Votes
Translate
Translate
Report
Report
New Here ,
Oct 22, 2013 Oct 22, 2013
i tried chmod 777 /Library/Application Support/Adobe
and mkdir ~/Library/Application Support/Adobe
and chmod 777 ~/Library/Application Support/Adobe
no joy nothing appears in ~/Library/Application Support/Adobe
i then tried
cd /Library/Application Support/Adobe
chgrp -R 1028 .
(my group id for all my users is 1028)
find /Library/Application Support/Adobe -type d -exec chmod 775 {} \;
still no joy
still having to install as root
Votes
Translate
Translate
Report
Report
New Here ,
It's also not fun that i have to do 101 stations one at time.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Photoshop Elements 6 is an old version and has not been tested and is incompatible with Mac 10.8.5.
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
you had mentioned that earlier in this conversation. i am happy you are being clear on that point. i did make a typo that i was not able to edit, i meant to say
we are currently installing photoshop elements 9.
Votes
Translate
Translate
Report
Report
