FatScarf
Framerate problem after burning PAL Blu-ray
Oct 21, 2013 12:10 PM
Tags: #problem #cs5 #video #settings #playback #blu-ray #encore #fps #build #transcoding #pal #bluray #transcode #encore_cs5 #25fps #50fps
Hi folks, bit of a rookie here. Usually try to work my way around things but this is a new area for me and I'm a little stumped!
Basically I'm using Encore CS5 to burn a Blu-ray from footage rendered from Final Cut. The footage is from a Sony HDV camera that records 1440x1080 50i. After the transcoding and burning was succesful I found that while looking good the footage was playing at 50fps on both a PS3 and a Panasonic player. I've tried leaving the transcoding settings on automatic and setting them manually to 1440x1080i 25 High Quality MPEG-2, both times the framerate was running at 50fps. So am I missing something obvious here to get the Blu-ray to playback at 25fps? Thanks in advance for any contributions!
