Photoshop CC don't have 3D Option
Oct 21, 2013 7:29 PM
I was try to search the solution but there is no one work for me.
I hope adobe can help me about it.
    Oct 21, 2013 7:31 PM   in reply to Hoh Yue
    Video card needs at least 512mb of VRAM memory.  Will not work with Win XP
    Hope this helps.  If not supply more info.
  • JJMack
    Jan 9, 2006
    Oct 21, 2013 8:24 PM   in reply to Hoh Yue
    Use menu Edit>preferences>performance make sure Photoshop had GPU enabled. if not there will be no 3D. You system info states it is and you have 2GB of VRAM use advance settings and enable OpenCL also.
  • JJMack
    Jan 9, 2006
    Oct 21, 2013 9:43 PM   in reply to Hoh Yue
    There may be a later driver for your notebook
    Version331.58 - WHQL
    Release DateMon Oct 21, 2013
    Operating SystemWindows 7 64-bit
    Windows 8.1 64-bit
    Windows 8 64-bit
    LanguageEnglish (US)
    File Size246.4 MB
    http://www.geforce.com/drivers/results/68502/
    A quick look seemed to indicate it supports OpenCL
    Oct 22, 2013 8:13 AM   in reply to Hoh Yue
    Update your PS as you are using version 14.0.  Click on Help/update
    Jan 18, 2014 5:06 PM   in reply to Curt Y
    I have 4096mb and the 3D option is not available... I also cannot enable check-off the Use OpenCL box either... any help?
    Jan 18, 2014 5:54 PM   in reply to A Terrible Photoshopper
    Open CL does not work with all cards.
    Jan 18, 2014 6:13 PM   in reply to Curt Y
    so does that mean i wont be able to use 3D? With my current card that is
  • Noel Carboni
    Dec 23, 2006
    Jan 18, 2014 6:30 PM   in reply to A Terrible Photoshopper
    OpenCL doesn't have much of anything to do with 3D rendering.  And it's not available on 32 bit Photoshop either.
    Please post a copy of your Help - System Info output as the user above did.
    -Noel
    Jan 18, 2014 6:34 PM   in reply to Noel Carboni
    Adobe Photoshop Version: 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00) x64
    Operating System: Windows 8 64-bit
    Version: 6.2
    System architecture: AMD CPU Family:15, Model:0, Stepping:1 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2
    Physical processor count: 2
    Processor speed: 2695 MHz
    Built-in memory: 3546 MB
    Free memory: 1962 MB
    Memory available to Photoshop: 2927 MB
    Memory used by Photoshop: 60 %
    Image tile size: 132K
    Image cache levels: 4
    OpenGL Drawing: Enabled.
    OpenGL Drawing Mode: Basic
    OpenGL Allow Normal Mode: True.
    OpenGL Allow Advanced Mode: True.
    OpenGL Allow Old GPUs: Not Detected.
    OpenCL Unavailable
    OpenGL Version: 3.0
    Video Rect Texture Size: 16384
    OpenGL Memory: 512 MB
    Video Card Vendor: ATI Technologies Inc.
    Video Card Renderer: AMD Radeon HD 7520G
    Display: 1
    Display Bounds: top=0, left=0, bottom=768, right=1366
    Video Card Number: 1
    Video Card: AMD Radeon HD 7520G
    Driver Version: 8.982.7.0
    Driver Date: 20120808000000.000000-000
    Video Card Driver: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,ati umd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdv a,atiumd6a.cap,atitmm64.dll
    Video Mode: 1366 x 768 x 4294967296 colors
    Video Card Caption: AMD Radeon HD 7520G
    Video Card Memory: 512 MB
    Serial number: 91198709403270006793
    Application folder: C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\
    Temporary file path: C:\Users\Cameron\AppData\Local\Temp\
    Photoshop scratch has async I/O enabled
    Scratch volume(s):
      D:\, 25.4G, 3.02G free
      C:\, 672.5G, 612.9G free
    Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\Required\
    Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\Plug-ins\
    Installed components:
       ACE.dll   ACE 2013/03/19-12:09:02   79.535293   79.535293
       adbeape.dll   Adobe APE 2013/02/04-09:52:32   0.1160850   0.1160850
       AdobeLinguistic.dll   Adobe Linguisitc Library   7.0.0
       AdobeOwl.dll   Adobe Owl 2013/03/03-12:10:08   5.0.13   79.533484
       AdobePDFL.dll   PDFL 2013/03/13-12:09:15   79.499517   79.499517
       AdobePIP.dll   Adobe Product Improvement Program   7.0.0.1768
       AdobeXMP.dll   Adobe XMP Core 2013/03/13-12:09:15   79.151481   79.151481
       AdobeXMPFiles.dll   Adobe XMP Files 2013/03/13-12:09:15   79.151481   79.151481
       AdobeXMPScript.dll   Adobe XMP Script 2013/03/13-12:09:15   79.151481   79.151481
       adobe_caps.dll   Adobe CAPS   7,0,0,21
       AGM.dll   AGM 2013/03/29-12:09:59   79.536232   79.536232
       ahclient.dll    AdobeHelp Dynamic Link Library   1,8,0,31
       aif_core.dll   AIF   5.0   79.534508
       aif_ocl.dll   AIF   5.0   79.534508
       aif_ogl.dll   AIF   5.0   79.534508
       amtlib.dll   AMTLib (64 Bit)   7.0.0.169 BuildVersion: 7.0; BuildDate: Mon Apr 8 2013 2:31:50)   1.000000
       ARE.dll   ARE 2013/03/19-12:09:02   79.535293   79.535293
       AXE8SharedExpat.dll   AXE8SharedExpat 2011/12/16-15:10:49   66.26830   66.26830
       AXEDOMCore.dll   AXEDOMCore 2011/12/16-15:10:49   66.26830   66.26830
       Bib.dll   BIB 2013/03/19-12:09:02   79.535293   79.535293
       BIBUtils.dll   BIBUtils 2013/03/19-12:09:02   79.535293   79.535293
       boost_date_time.dll   DVA Product   7.0.0
       boost_signals.dll   DVA Product   7.0.0
       boost_system.dll   DVA Product   7.0.0
       boost_threads.dll   DVA Product   7.0.0
       cg.dll   NVIDIA Cg Runtime   3.0.00007
       cgGL.dll   NVIDIA Cg Runtime   3.0.00007
       CIT.dll   Adobe CIT   2.1.6.30158   2.1.6.30158
       CITThreading.dll   Adobe CITThreading   2.1.6.30158   2.1.6.30158
       CoolType.dll   CoolType 2013/03/19-12:09:02   79.535293   79.535293
       dvaaudiodevice.dll   DVA Product   7.0.0
       dvacore.dll   DVA Product   7.0.0
       dvamarshal.dll   DVA Product   7.0.0
       dvamediatypes.dll   DVA Product   7.0.0
       dvaplayer.dll   DVA Product   7.0.0
       dvatransport.dll   DVA Product   7.0.0
       dvaunittesting.dll   DVA Product   7.0.0
       dynamiclink.dll   DVA Product   7.0.0
       ExtendScript.dll   ExtendScript 2013/03/21-12:10:31   79.535742   79.535742
       FileInfo.dll   Adobe XMP FileInfo 2013/03/19-12:09:02   79.151561   79.151561
       filter_graph.dll   AIF   5.0   79.534508
       icucnv40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
       icudt40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
       imslib.dll   IMSLib DLL   7.0.0.37
       JP2KLib.dll   JP2KLib 2013/02/19-12:28:44   79.248139   79.248139
       libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
       libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
       LogSession.dll   LogSession   2.1.2.1756
       mediacoreif.dll   DVA Product   7.0.0
       MPS.dll   MPS 2013/03/15-13:25:52   79.535029   79.535029
       msvcm80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6910
       msvcm90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
       msvcp100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
       msvcp80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6910
       msvcp90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
       msvcr100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
       msvcr80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6910
       msvcr90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
       PatchMatch.dll   PatchMatch 0000/00/00-00:00:00   1.   1.
       pdfsettings.dll   Adobe PDFSettings   1.04
       Photoshop.dll   Adobe Photoshop CC   CC
       Plugin.dll   Adobe Photoshop CC   CC
       PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   4.0.1.34
       PSArt.dll   Adobe Photoshop CC   CC
       PSViews.dll   Adobe Photoshop CC   CC
       SCCore.dll   ScCore 2013/03/21-12:10:31   79.535742   79.535742
       ScriptUIFlex.dll   ScriptUIFlex 2013/03/21-12:10:31   79.535742   79.535742
       svml_dispmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
       tbb.dll   Intel(R) Threading Building Blocks for Windows   4, 1, 2012, 1003
       tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   4, 1, 2012, 1003
       updaternotifications.dll   Adobe Updater Notifications Library   7.0.1.102 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   7.0.1.102
       WRServices.dll   WRServices Mon Feb 25 2013 16:09:10   Build 0.19078   0.19078
    Required plug-ins:
       Accented Edges 14.0
       Adaptive Wide Angle 14.0
       Angled Strokes 14.0
       Average 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)
       Bas Relief 14.0
       BMP 14.0
       Camera Raw 8.2
       Camera Raw Filter 8.2
       Chalk & Charcoal 14.0
       Charcoal 14.0
       Chrome 14.0
       Cineon 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)
       Clouds 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)
       Collada 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)
       Color Halftone 14.0
       Colored Pencil 14.0
       CompuServe GIF 14.0
       Conté Crayon 14.0
       Craquelure 14.0
       Crop and Straighten Photos 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)
       Crop and Straighten Photos Filter 14.0
       Crosshatch 14.0
       Crystallize 14.0
       Cutout 14.0
       Dark Strokes 14.0
       De-Interlace 14.0
       Difference Clouds 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)
       Diffuse Glow 14.0
       Displace 14.0
       Dry Brush 14.0
       Eazel Acquire 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)
       Embed Watermark 4.0
       Extrude 14.0
       FastCore Routines 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)
       Fibers 14.0
       Film Grain 14.0
       Filter Gallery 14.0
       Fresco 14.0
       Glass 14.0
       Glowing Edges 14.0
       Grain 14.0
       Graphic Pen 14.0
       Halftone Pattern 14.0
       HDRMergeUI 14.0
       IFF Format 14.0
       Ink Outlines 14.0
       JPEG 2000 14.0
       Lens Blur 14.0
       Lens Correction 14.0
       Lens Flare 14.0
       Liquify 14.0
       Matlab Operation 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)
       Measurement Core 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)
       Mezzotint 14.0
       MMXCore Routines 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)
       Mosaic Tiles 14.0
       Multiprocessor Support 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)
       Neon Glow 14.0
       Note Paper 14.0
       NTSC Colors 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)
       Ocean Ripple 14.0
       Oil Paint 14.0
       OpenEXR 14.0
       Paint Daubs 14.0
       Palette Knife 14.0
       Patchwork 14.0
       Paths to Illustrator 14.0
       PCX 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)
       Photocopy 14.0
       Photoshop 3D Engine 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)
       Picture Package Filter 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)
       Pinch 14.0
       Pixar 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)
       Plaster 14.0
       Plastic Wrap 14.0
       PNG 14.0
       Pointillize 14.0
       Polar Coordinates 14.0
       Portable Bit Map 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)
       Poster Edges 14.0
       Radial Blur 14.0
       Radiance 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)
       Read Watermark 4.0
       Reticulation 14.0
       Ripple 14.0
       Rough Pastels 14.0
       Save for Web 14.0
       ScriptingSupport 14.0
       Shake Reduction 14.0
       Shear 14.0
       Smart Blur 14.0
       Smudge Stick 14.0
       Solarize 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)
       Spatter 14.0
       Spherize 14.0
       Sponge 14.0
       Sprayed Strokes 14.0
       Stained Glass 14.0
       Stamp 14.0
       Sumi-e 14.0
       Targa 14.0
       Texturizer 14.0
       Tiles 14.0
       Torn Edges 14.0
       Twirl 14.0
       Underpainting 14.0
       Vanishing Point 14.0
       Variations 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)
       Water Paper 14.0
       Watercolor 14.0
       Wave 14.0
       WIA Support 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)
       Wind 14.0
       Wireless Bitmap 14.0 (14.0 20130423.r.221 2013/04/23:23:00:00)
       ZigZag 14.0
    Optional and third party plug-ins: NONE
    Plug-ins that failed to load: NONE
    Flash:
       Adobe Exchange
       Kuler
    Installed TWAIN devices: NONE
  • Noel Carboni
    Dec 23, 2006
    Jan 18, 2014 6:38 PM   in reply to A Terrible Photoshopper
    Right off the bat I see that your ATI display driver is a year and a half out of date (noting the Driver Date: 20120808... indication).
    Go to AMD.com, select the display driver that matches your hardware and operating system - which is likely going to be their Catalyst 13.12 package - and download and install it.
    I'm betting that will get Photoshop's features working for you.  It works for me (I have an ATI 7850 and Catalyst 13.12).
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Jan 18, 2014 6:40 PM   in reply to Noel Carboni
    Also, go into Help - Updates or run the Photoshop CC application and update your Photoshop to 14.2, which was recently released.
    -Noel
    Jan 18, 2014 6:42 PM   in reply to Noel Carboni
    Ok I will try this. Thank you so much... I haven't updated anything but windows since I bought this laptop
  • Noel Carboni
    Dec 23, 2006
    Jan 18, 2014 6:53 PM   in reply to A Terrible Photoshopper
    Ah, I didn't realize it was a laptop.  Often with laptops you need to go to the web site of the maker of the laptop to get new drivers.
    -Noel
    Jan 18, 2014 6:58 PM   in reply to Noel Carboni
    it still amd... i tried and it failed so im not all taht worried about it...
