How to delete vertical space between two divs?
Oct 21, 2013 7:59 PM
I have a very simple page right now. Top div holds an image. The div below it holds another image. Both divs appear to be adding space to the bottom. I know other's have had this issue - yet when searching the forum I'm not finding anything. I've added 0 for padding and margins.... I"m out of patience. Want to go back to tables (but I won't let those divs beat me!) help please? http://www.duenorthdesign.com/christmas
I even added a container around everythign to see if that would help and it didn't. And my height dimensions match my images exactly.
OK, found the answer after nearly 3 hours. Due to  doctype html5 I used:
img {
vertical-align: bottom;
Just maybe this will help someone out there searching..... I went through about 50 attempts from reading posts before I stumbled on this one.
    Oct 21, 2013 9:56 PM   in reply to duenorth09
    After seeing your website it looks like you want the two images to join without any spacing. Correct? Why don't you try giving a negative value (of say -5px) to the top margin to #nav and see if this works for you?
    #nav{
    margin-top: -5px;
    HTH
    Nithya
    Oct 22, 2013 6:37 AM   in reply to duenorth09
    img {
    Here's another (simpler) fix for the entire page...
    img {display:block;}
    What this does is remove the space for the text descender that is attached to display:inline elements (lower case j, g, q, etc).
