Can "File Info" data be deleted?
Oct 22, 2013 7:08 AM
Tags: #file_info #framemaker_11
Hello,
Currently using FM11 and creating unstructured documents.  We make custom types of equipment and tend to start a new document from a previous version.  We'd like to delete the previous "File Info" data and update with current data for the new document.  We delete the "File Info" data and save the document, but when reopened, the data is still there.
Thanks you in advance,
WRB
    Oct 22, 2013 7:24 AM   in reply to WRB
    Is this a book, or a single FM document file?
    If a book, make sure you delete file info in the Book dialog, and just for good measure, if leaving empty, also make sure all of the component files have no File Info. I haven't tested it, but it wouldn't surprise me if FM uses the first-found when building the PDFinfo.
    In our release process, we routinely process the PDFs in Acrobat Pro, Examine Document, and let it remove (only) Metadata and File Attachements (since it's buggy on everthing else). Removing Metadata deletes almost all of the PDFInfo (FM File Info).
    We end up pasting the desired values back in, so that search engines can find our stuff. Some search engines may only index PDFinfo, either because that's all they do, or because that may be the only plaintext available if you have certain security settings.
    I suspect Google indexes everything, as long as it can open the PDF at all, even if it needs to OCR the whole thing.
    Attention Authors: on the Windows platform, your user/login name is often written to the PDFinfo by default. This is either a benefit or a hazard. If it's a benefit, it's not my problem .
    Oct 22, 2013 11:24 PM   in reply to WRB
    A very quick test seems to show that with FM10 you can copy what you've set with File ⇨ Info between .fm files – File ⇨ Import ⇨ Formats ⇨ Document properties. It even seems to be a "destructive copy": a field with no value in the source document overwrites a field with another value in the target. HTH in FM11.
    Fringes of the thread, so to speak – I don't have anything in the file info the customer mustn't see. The reason I try to keep an eye on it is a tendency to start docset B by copying and renaming something from docset A, then updating a handful of user variables.
    Oct 23, 2013 1:46 PM   in reply to WRB
    There is a maker.ini setting (CopyFileInfoOnImport) that controls whether or not imported Doc Info fields are copied over or not. This is not documented in the Maker.ini Reference Guide.
    If you want the contents coming over from a template or another file, this needs to be explicitly added to the [Preferences] section as "CopyFileInfoOnImport=On". Likewise, if you don't want a template overwriting the already marked up meta-date. You need to explicitly set this to "Off".
    Also, keep in mind that FM "merges" content when you import formats, i.e. if the item exists in both files, it gets replaced, otherwise it is left alone.
    Nov 13, 2013 8:07 AM   in reply to Arnis Gubins
    Arnis,
    I'm working with Frame 11 on Windows 7 and I've having the same trouble. I tried adding CopyFileInfoOnImport=On to the maker.ini file in Users > username > AppData > Roaming > Adobe > FrameMaker > 11. I reopened Frame, opened my template (which has the File Info I'm trying to get rid of), deleted it, and hit Set. Then I saved as  new file name. After that, I did File > Import > Formats and imported the blank file info (Title and Author) into my new file. Saved, but then when reopened the file, it's there again! This is driving me crazy. What am I doing wrong?
    Gail
    Nov 13, 2013 8:51 AM   in reply to WRB
    Aha! I didn’t think to try starting with a blank document, then importing everything BUT Doc Properties. That did the trick! Thanks so much, I really appreciate it.
    Gail
Bookmarked By (1)
