I have a machine with Windows 8, Office 2013 and Acrobat X. I'm having trouble with the PDF maker add-in. In Word and Excel, the add-in is listed as "active" but I have no Acrobat toolbar and it does not appear on the ribbon. In Outlook, the add-in is listed as "inactive". It allows me to check the box to activate it, but remains in the "inactive" list regardless of how many times I try to activate it. We have another machine in the office that uses the same hardware and same software versions, and the add-ins work on it just fine. I have run updates on the office and Acrobat software, uninstalled and reinstalled, and ran "repair" on both multiple times and still have the same issue. Help!
Hi ludy,
Acrobat X is incompatible with Office 2013.
Please refer : http://helpx.adobe.com/acrobat/kb/compatible-web-browsers-pdfmaker-applications.html
If you crashed Word/Excel/PowerPoint/Outlook the setting may be stuck in the MS Office registry to keep it disabled.
Thanks! The initial installation of Office failed because of a power outage, so it sounds like that could be my problem! Can you tell me how to modify the registry? I haven't worked much with Windows 8 so I don't even know how to access the registry - clicking "start" and entering "regedit" in the run line clearly won't work in Windows 8. Any advice you can give will be helpful!
Hi ludy,
Then how do I have another machine running Office 2013 and Acrobat X with functional add-ins? Clearly it is not imcompatible. I will look elsewhere for a helpful response.
Hi Ludy,
If you insist that the plugin is working fine on the othe rmahine then you can try the following:
Check the status of the add in Office 2013 >File > Options > Add ins > COM Addins > Go,
The add in tries to configure for the first time and if proper permissions are not there, it fails to load and Office disables the add in.
In addition to the above you can check the following within the Office Application :
Note: Microsoft Office Applications disable add-ins as a failsafe if the application is prematurely closed (for example, if the system wasn't shut off properly or the application crashed).
Add the COM add-in file to the Windows registry.
Check if Acrobat PDFMaker Office COM Add-in is present in the list of available COM Add-ins for the Office Application.
Actually, I must apologize. The user, without my knowledge, apparently purchased and installed the Acrobat 11 upgrade without permission, so it appears that you are likely correct. Have a good day.
I came across this post searching for an answer to a similar problem on a machine with Windows 7 (32 bit), Acrobat 11, and Office 2013. It is possible that installation of Office was interrupted. User was trying to enable the PDFMaker Add-In from within Outlook 2013 and it kept crashing and/or being disabled automatically upon startup. Ultimately the fix was to re-register the Add-in manually. Run from a command prompt: regsvr32 "%programfiles%\Adobe\Acrobat 11.0\PDFMaker\Mail\Outlook\PDFMOutlookAddin.dll" and restart outlook.
