kalsen
Adding a same component in each tab of super tab navigator creates problem
Oct 23, 2013 8:43 AM
When a UI component is created once and added to each tab using super tab navigator in AS 3.0, the component is adding only to the last index of the tab. The component is missing in the previous tab.
I have given the code below. Please help me why this is happening and the solution for this.
<mx:Application
        xmlns:mx="http://www.adobe.com/2006/mxml"
        creationComplete="createSuperTabNav()">
        <mx:Script>
                <![CDATA[
                    import mx.core.UIComponent;
                        import com.tab.navigator.components.SuperTabBar;
                        import com.tab.navigator.components.SuperTabReorderEvent;
                        import com.tab.navigator.components.SuperTab;
                        import com.tab.navigator.components.SuperTabNavigator;
                        import com.tab.navigator.components.ButtonScrollingCanvas;
                        import mx.controls.Label;
                        import mx.controls.Button;
                        import mx.controls.Spacer;
                        import mx.containers.VBox;
                        import mx.containers.HBox;
                        import mx.containers.Canvas;
                        import mx.containers.Panel;
                        import mx.core.ScrollPolicy;
                        import flash.events.MouseEvent;
                        public var _tabs : SuperTabNavigator;
                        public var _addBtn : Button;
                        public var _vbox:VBox;
                        public var pageCount:uint;
                        public var tabID:String;
                        private var _comp:UIComponent;
                        public function createSuperTabNav():void
                            _vbox = new VBox();
                            _vbox.percentWidth = 75;
                            _vbox.percentHeight = 75;
                            _vbox.setStyle("horizontalAlign","center");
                            _vbox.setStyle("verticalGap", 20);
                            createTabs();
                            createAddButton();
                            addChild(_vbox);
                        public function createTabs():void
                            _tabs = new SuperTabNavigator();
                            //initTabs();
                            addObjectTab();
                            // Set Properties
                            _tabs.id = "nav";
                            _tabs.percentHeight = 75;
                            _tabs.percentWidth = 50;
                            _vbox.addChild(_tabs);
                        public function addTab(lbl:String, navigator:SuperTabNavigator, component:UIComponent, getId:String) : Canvas
                            // Create canvas to put into tab
                            var child:Canvas = new Canvas();
                            child.percentHeight = 100;
                            child.percentWidth = 100;
                            child.id = getId;
                            child.label = lbl;
                            child.setStyle("closable", true);
                            child.addChild(component);
                            child.setStyle("backgroundColor",0xF8F8F8);
                            navigator.addChild(child);
                             //trace(_tabs.selectedChild.getChildren().toString());
                            _tabs.reorderTabList();
                            return child;
                        public function createAddButton():void
                            _addBtn = new Button()
                            _addBtn.label = "Add Tab";
                            _addBtn.id = "addTabBtn";
                            _addBtn.width = 75;
                            _addBtn.height = 20;
                            _addBtn.addEventListener(MouseEvent.CLICK, handleButtonClick,false,0, true);
                            _vbox.addChild(_addBtn);
                        public function handleButtonClick(evt:MouseEvent):void
                            //addTab('tab '+Number(_tabs.numChildren + 1), _tabs);
                            addObjectTab();
                            _tabs.selectedIndex = _tabs.numChildren - 1;
                        public function addObjectTab():void
                            var frameCanvas:Canvas = new Canvas();
                            frameCanvas.horizontalScrollPolicy = ScrollPolicy.OFF;
                            frameCanvas.verticalScrollPolicy = ScrollPolicy.OFF;
                            frameCanvas.percentHeight = 100;
                            frameCanvas.percentWidth = 100;
                            if ( _comp == null )
                                _comp = addComponent();
                            frameCanvas.addChild(_comp);
                            // Create container to implement horizontal padding
                            var horizontalPadder:HBox = new HBox();
                            horizontalPadder.setStyle("backgroundAlpha", 0);
                            horizontalPadder.horizontalScrollPolicy = ScrollPolicy.OFF;
                            horizontalPadder.verticalScrollPolicy = ScrollPolicy.OFF
                            horizontalPadder.addChild(new Spacer());
                            horizontalPadder.addChild(frameCanvas);
                            // Create container to implement vertical padding
                            var verticalPadder:VBox = new VBox();
                            verticalPadder.setStyle("backgroundAlpha", 0);
                            verticalPadder.horizontalScrollPolicy = ScrollPolicy.OFF;
                            verticalPadder.verticalScrollPolicy = ScrollPolicy.OFF
                            verticalPadder.addChild(new Spacer());
                            verticalPadder.addChild(horizontalPadder);
                            // Position padder
                            verticalPadder.setStyle("horizontalAlign", "Left");
                            verticalPadder.x = 0
                            verticalPadder.y = 0;
                            tabID = "page"+ _tabs.getNumberOfTabs()+1;
                            var canvas:Canvas = addTab("Page "+(_tabs.getNumberOfTabs()+1), _tabs ,verticalPadder, tabID);
                            canvas.setStyle("backgroundColor", "#009900");
                        public function addComponent():UIComponent
                            var pageCount:uint = _tabs.getNumberOfTabs()+1;
                            var page:Canvas = new Canvas;
                             page.width = 250;
                             page.height = 250;
                             page.setStyle("backgroundColor", "#FFFFFF");
                            var _pageBtn:Button = new Button();
                            _pageBtn.label = "Button "+(pageCount);
                            _pageBtn.id = "addTabBtn "+(pageCount);
                            _pageBtn.width =100;
                            _pageBtn.height = 20;
                            page.addChild(_pageBtn);
                            return page;
        </mx:Script>
</mx:Application>
