dblameuser
Preflight tool resizing stamps
Oct 23, 2013 3:34 PM
I am using the preflight tool to flatten some stamps that have been added and resized, but whenever the tool runs it resized the stamps back to their default size.  How do I retain their size after flattening?  I am using 10.0.
  • George Johnson
    Aug 11, 2002
    Oct 23, 2013 3:38 PM   in reply to dblameuser
    An easy way is to use the flattenPages() JavaScript method in the interactive JavaScript console (Ctrl+J). Just enter this line of code:
    flattenPages();
    and with the cursor on that line, press Ctrl+Enter, or the Enter key on the numeric keypad.
    If you have to do this a lot, consider using this free JavaScript-based tool: http://www.uvsar.com/projects/acrobat/flattener/
  • George Johnson
    Aug 11, 2002
    Oct 23, 2013 4:04 PM   in reply to dblameuser
    What happens if you execute that line of JavaScript in the console instead?
  • George Johnson
    Aug 11, 2002
    Oct 23, 2013 4:21 PM   in reply to dblameuser
    I don't get the same type of thing with Acrobat 9 or 11. You mentioned you're using 10.0, so you might consider updating to the latest (10.1.8) to see if it makes a difference.
    Dec 10, 2013 7:48 AM   in reply to dblameuser
    I have 10.1.8.  When I run the line
    flattenPages();
    I get "undefined" back.  What's up with that.
    Dec 10, 2013 8:18 AM   in reply to tomand007
    It means the code ended without errors, and didn't return any values. In
    other words, it worked.
  • George Johnson
    Aug 11, 2002
    Dec 10, 2013 8:25 AM   in reply to tomand007
    That's normal and is an indication that it worked.
