Drop Down Menus in Photoshop CS 6 Goes Blank In Mavericks
Oct 23, 2013 10:05 PM
Tags: #photoshop #x #mac #cs6 #blank #os #white #menus #mavericks
Hi
I'm having trouble with Photoshop CS6 in Mavericks. After a working a little while, all pop up/drop down menus goes blank. They still work, but I can't see what's on them. Even the Apple menu bar is afflicted by this, though only when Photoshop is in the front.
Any help is appreciated. Thanks.  PS: I do use a cintiq on a 2012 Macbook Pro 15" with retina display.
Skjermbilde 2013-10-24 kl. 00.45.45.pngSkjermbilde 2013-10-24 kl. 00.46.09.png
Branched to a new discussion.
Replies 1 2 3 ... 9 Previous Next
    Oct 23, 2013 10:42 PM   in reply to TK_Churchill
    So far we only have 2 reports of this, and we haven't seen it on any of our systems with MacOS 10.9 installed.
    Our best guess is a third party system extension or plugin causing interference with menu drawing.
    Oct 24, 2013 5:18 AM   in reply to Chris Cox
    I am experiencing the same issues here. Not using any 3rd party plugins.
    I'm experiencing weird (random) glitches while using the Polygon Lasso Tool. When these 'glitches' start to occur, the blanc menus start to show up.
    I work on an 2012 iMac, 32 Gb Ram, Wacom Intuous Tablet..
    BTW, I'm using Photoshop CC.
    Oct 24, 2013 8:14 AM   in reply to Chris Cox
    We are also having this issue with our two brand new 27 inch iMacs (not Haswell but the previous model) in our photography studio. We're running recent installs of Photoshop CC and since the computers are only used for Photoshop, the only thing we installed on them was Photoshop, Bridge, and nothing else except the driver for our Wacom Intuos 4 tablets. The issue started happening today on both computers, right after installing Mavericks this morning. It never happened before.
    So far, the issue happened once on each of two computers over the course of 6 hours of continuous work.
    The issue is solved when quitting Photoshop and reopening it, however, when having many unsaved files open, it becomes almost impossible to save them as the menu and dialog boxes are all blank. So it inderectly leads to lost data.
    Here's the system info from one of the computers:
    Adobe Photoshop Version: 14.1.2 (14.1.2 20130923.r.427 2013/09/23:23:00:00) x64
    Operating System: Mac OS 10.9.0
    System architecture: Intel CPU Family:6, Model:58, Stepping:9 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
    Physical processor count: 4
    Logical processor count: 8
    Processor speed: 3400 MHz
    Built-in memory: 16384 MB
    Free memory: 9119 MB
    Memory available to Photoshop: 14926 MB
    Memory used by Photoshop: 69 %
    Image tile size: 1024K
    Image cache levels: 4
    Display: 1
    Main Display
    Display Bounds: top=0, left=0, bottom=1440, right=2560
    OpenGL Drawing: Enabled.
    OpenGL Allow Old GPUs: Not Detected.
    OpenGL Drawing Mode: Advanced
    OpenGL Allow Normal Mode: True.
    OpenGL Allow Advanced Mode: True.
    NumGPUs=1
    gpu[0].OGLVersion="2.1"
    gpu[0].MemoryMB=1024
    gpu[0].RectTextureSize=16384
    gpu[0].Renderer="NVIDIA GeForce GTX 675MX OpenGL Engine"
    gpu[0].RendererID=16918308
    gpu[0].Vendor="NVIDIA Corporation"
    gpu[0].VendorID=4318
    gpu[0].HasNPOTSupport=1
    gpu[0].CompileProgramGLSL=1
    gpu[0].TestFrameBuffer=1
    gpu[0].OCLSupported=1
    gpu[0].OCLVersion="1.2 (Aug 24 2013 21:03:27)"
    gpu[0].CUDASupported=0
    gpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
    gpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTR UCTIONS_ARB]=[16384]
    gpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
    gpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
    gpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
    gpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
    gpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
    gpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
    gpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[2048]
    gpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
    gpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
    gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
    gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
    gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
    gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
    gpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
    gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
    gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
    gpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
    gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
    gpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
    Serial number: 96040340820095013106
    Application folder: /Applications/Adobe Photoshop CC/
    Photoshop scratch has async I/O enabled
    Scratch volume(s):
      Macintosh HD, 930.7G, 897.7G free
    Required Plug-ins folder: /Applications/Adobe Photoshop CC/Adobe Photoshop CC.app/Contents/Required/Plug-Ins/
    Primary Plug-ins folder: /Applications/Adobe Photoshop CC/Plug-ins/
    Installed components:
       adbeape.framework   adbeape   3.4.0.29366   0.1160850
       AdbeScriptUIFlex.framework   AdbeScriptUIFlex   6.3.2.30746   79.535742
       adobe_caps.framework   adobe_caps   7.0.0.21   1.248010
       AdobeACE.framework   AdobeACE   2.20.02.31468   79.543790
       AdobeAGM.framework   AdobeAGM   4.30.24.31468   79.543790
       AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.7.101.18636   66.26830
       AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.7.101.18636   66.26830
       AdobeBIB.framework   AdobeBIB   1.2.03.31468   79.543790
       AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   79.543790
       AdobeCoolType.framework   AdobeCoolType   5.13.00.31468   79.543790
       AdobeCrashReporter.framework   AdobeCrashReporter   7.0.1
       AdobeExtendScript.framework   AdobeExtendScript   4.5.5.30746   79.535742
       AdobeJP2K.framework   AdobeJP2K   1.2.2.29712   79.248139
       AdobeLinguistic.framework      19061
       AdobeMPS.framework   AdobeMPS   5.8.1.30604   79.535029
       AdobeOwl.framework   AdobeOwl   5.0.13   79.533484
       AdobePDFL.framework   AdobePDFL   10.0.1.30505   79.499517
       AdobePDFSettings.framework   AdobePDFSettings   1.4
       AdobePIP.framework   AdobePIP   7.0.0.1786
       AdobeScCore.framework   AdobeScCore   4.5.5.30746   79.535742
       AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
       AdobeXMP.framework   AdobeXMPCore   79.151481   79.151481
       AdobeXMPFiles.framework   AdobeXMPFiles   79.151481   79.151481
       AdobeXMPScript.framework   AdobeXMPScript   79.151481   79.151481
       ahclient.framework   ahclient   1.8.0.31
       aif_core.framework   AdobeAIF   5.0.00   79.534508
       aif_ocl.framework   AdobeAIF   5.0.00   79.534508
       aif_ogl.framework   AdobeAIF   5.0.00   79.534508
       AlignmentLib.framework   xcode   Copyright © 2013 Adobe Systems Incorporated
       amtlib.framework   amtlib   7.0.0.169
       boost_date_time.framework   boost_date_time   7.0.0.0
       boost_signals.framework   boost_signals   7.0.0.0
       boost_system.framework   boost_system   7.0.0.0
       boost_threads.framework   boost_threads   7.0.0.0
       Cg.framework   NVIDIA Cg
       CIT.framework   CIT   2.1.6.30929   151865
       CITThreading.framework   CITThreading   2.1.6.30929   151865
       dvaaudiodevice.framework   dvaaudiodevice   7.0.0.0
       dvacore.framework   dvacore   7.0.0.0
       dvamarshal.framework   dvamarshal   7.0.0.0
       dvamediatypes.framework   dvamediatypes   7.0.0.0
       dvaplayer.framework   dvaplayer   7.0.0.0
       dvatransport.framework   dvatransport   7.0.0.0
       dvaunittesting.framework   dvaunittesting   7.0.0.0
       dynamiclink.framework   dynamiclink   7.0.0.0
       FileInfo.framework   FileInfo   79.151561   79.151561
       filter_graph.framework   AdobeAIF   5.0.00   79.534508
       ICUConverter.framework   ICUConverter   3.61   "gtlib_3.0" "." "16615"
       ICUData.framework   ICUData   3.61   "gtlib_3.0" "." "16615"
       LogSession.framework   LogSession   2.1.2.1785
       mediacoreif.framework   mediacoreif   7.0.0.0
       patchmatch.framework   patchmatch   1.2.00.31297   79.542390
       PlugPlugOwl.framework   PlugPlugOwl   4.0.1.34
       UpdaterNotifications.framework   UpdaterNotifications   7.0.1.102   "7.0.1.102"
       WRServices.framework
    Required plug-ins:
       3D Studio 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
       Accented Edges 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Adaptive Wide Angle 14.0, Copyright © 2013 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
       Angled Strokes 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Average 14.1.2 x001  ©1993-2013 Adobe Systems Incorporated - from the file “Average.plugin”
       Bas Relief 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       BMP 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Camera Raw 8.2 (94), Copyright © 2013 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
       Camera Raw Filter 8.2 (94), Copyright © 2013 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
       Chalk & Charcoal 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Chrome 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Cineon 14.1.2 x001  ©2002-2013 Adobe Systems Incorporated - from the file “Cineon.plugin”
       Clouds 14.1.2 x001  ©1993-2013 Adobe Systems Incorporated - from the file “Clouds.plugin”
       Collada DAE 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
       Color Halftone 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Colored Pencil 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       CompuServe GIF 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Conté Crayon 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Craquelure 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Crop and Straighten Photos 14.1.2 x001  ©2003-2013 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
       Crop and Straighten Photos Filter 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Crosshatch 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Crystallize 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Cutout 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Dark Strokes 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       De-Interlace 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Dicom 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “dicom.plugin”
       Difference Clouds 14.1.2 x001  ©1993-2013 Adobe Systems Incorporated - from the file “Clouds.plugin”
       Diffuse Glow 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Displace 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Dry Brush 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Eazel Acquire 14.1.2 x001  ©1997-2013 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
       Embed Watermark NO VERSION - from the file “DigiSign.plugin”
       Entropy 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
       Extrude 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       FastCore Routines 14.1.2 x001  ©1990-2013 Adobe Systems Incorporated - from the file “FastCore.plugin”
       Fibers 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Film Grain 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Filter Gallery 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Flash 3D 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
       Fresco 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Glass 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Glowing Edges 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Google Earth 4 KMZ 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
       Graphic Pen 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Halftone Pattern 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       HDRMergeUI 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
       IFF Format 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Ink Outlines 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       JPEG 2000 14.1.2 x001  ©2001-2013 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
       Kurtosis 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
       Lens Blur 14.0, Copyright © 2002-2013 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
       Lens Correction 14.0, Copyright © 2002-2013 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
       Lens Flare 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Liquify 14.0, Copyright © 2001-2013 Adobe Systems Incorporated - from the file “Liquify.plugin”
       Matlab Operation 14.1.2 x001  ©1993-2013 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
       Maximum 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
       Mean 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
       Measurement Core 14.1.2 x001  ©1993-2013 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
       Median 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
       Mezzotint 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Minimum 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
       MMXCore Routines 14.1.2 x001  ©1990-2013 Adobe Systems Incorporated - from the file “MMXCore.plugin”
       Mosaic Tiles 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Multiprocessor Support 14.1.2 x001  ©1990-2013 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
       Neon Glow 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Note Paper 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       NTSC Colors 14.1.2 x001  ©1993-2013 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
       Ocean Ripple 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Oil Paint 14.0, Copyright © 2013 Adobe Systems Incorporated - from the file “Oil Paint.plugin”
       OpenEXR 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Paint Daubs 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Palette Knife 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Patchwork 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Paths to Illustrator 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       PCX 14.1.2 x001  ©1989-2013 Adobe Systems Incorporated - from the file “PCX.plugin”
       Photocopy 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Photoshop 3D Engine 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
       Photoshop Touch CC (14.0.0.0) ©1993-2013 Adobe Systems Incorporated - from the file “PSDX.plugin”
       Picture Package Filter 14.1.2 x001  ©1993-2013 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
       Pinch 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Pixar 14.1.2 x001  ©1989-2013 Adobe Systems Incorporated - from the file “Pixar.plugin”
       Plaster 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Plastic Wrap 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       PNG 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Pointillize 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Polar Coordinates 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Portable Bit Map 14.1.2 x001  ©1989-2013 Adobe Systems Incorporated - from the file “PBM.plugin”
       Poster Edges 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Radial Blur 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Radiance 14.1.2 x001  ©2003-2013 Adobe Systems Incorporated - from the file “Radiance.plugin”
       Range 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
       Read Watermark NO VERSION - from the file “DigiRead.plugin”
       Reticulation 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Ripple 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Rough Pastels 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Save for Web 14.0, Copyright © 1999-2013 Adobe Systems Incorporated - from the file “Save for Web.plugin”
       ScriptingSupport 13.0, Copyright © 2013 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
       Shake Reduction 14.0, Copyright © 2013 Adobe Systems Incorporated - from the file “Shake Reduction.plugin”
       Shear 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Skewness 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
       Smart Blur 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Smudge Stick 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Solarize 14.1.2 x001  ©1993-2013 Adobe Systems Incorporated - from the file “Solarize.plugin”
       Spatter 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Spherize 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Sponge 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Sprayed Strokes 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Stained Glass 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Stamp 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Standard Deviation 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
       STL 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
       Sumi-e 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Summation 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
       Targa 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Texturizer 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Tiles 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Torn Edges 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Twirl 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Underpainting 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Vanishing Point 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
       Variance 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
       Water Paper 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Watercolor 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
       Wave 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Wavefront|OBJ 14.1.2 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
       Wind 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
       Wireless Bitmap 14.1.2 x001  ©1989-2013 Adobe Systems Incorporated - from the file “WBMP.plugin”
       ZigZag 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
    Optional and third party plug-ins: NONE
    Plug-ins that failed to load: NONE
    Flash:
       Mini Bridge
       Kuler
       Adobe Exchange
    Installed TWAIN devices: NONE
    Oct 24, 2013 1:05 PM   in reply to Venture1
    Check all your system extensions / utilities -- something is interfereing with menu drawing, and it doesn't affect everyone, so it is probably something that you have installed on your system.
    Oct 24, 2013 1:16 PM   in reply to TK_Churchill
    Start with all the system extensions and utilities that you have installed.
    Many will be listed in the system preferences panel, or on the menu bar.  But only you know what you have installed.
    And, as always, avoid anything that claims to be a system "cleaner" (they do more damage than good).
    Oct 24, 2013 2:12 PM   in reply to Chris Cox
    Our machines have nothing installed other than what's necessary: Photoshop CC, Bridge CC, Llightroom 5, latest Wacom Intuos 4 driver, MPEG Streamclip, Perian, Flash and Java. That's really it.
    I'm the system administrator and I make sure that nothing other than what's absolutely necessary is installed on them, because I know that keeping a system clean makes troubleshooting problems like this much easier. There are no extensions, utilities and god forbid any "cleaner" applications, whatsoever installed. Since the machines are just a month old, it's easy to keep track of what's been installed.
    A bit more detail on the problem: not only do menus go blank (white), but also strange artefacts appear. When using the crop tool, for example, a fairly large white square appears at the bottom right of the Crop cursor, and follows it around when dragging. Clicking and holding the mouse on a tool in the toolbar brings up a sub-menu filled with random bits such as brush thumbnails. In addition, when closing Photoshop, the "Do you want to save?" dialog is completely white too. So it's not just popup menus.
    We have two more iMacs that have not (yet) exhibited the issue, but they are identical in both hardware and software to the two that have had the problem. I will keep an eye on them to see what happens.
    The issue only happened twice, once on one iMac, and once on another, within an 8 hour period of constant heavy use of Photoshop.
    I'm sure the issue is related to Mavericks, as it only started happening today, and we installed Mavericks this morning.
    Oct 24, 2013 3:30 PM   in reply to TK_Churchill
    When this happens, what do you see in the "Console"?
    Launch Utilities>Console.app, and click "All Messages" Then look for error messages towards the bottom - messages are time stamped and you can use this to filter out irrelevant messages.
    Oct 24, 2013 4:25 PM   in reply to Venture1
    That makes it sound like a video driver or system drawing issue.
    But it could still be related to a driver or utility software.
    Oct 24, 2013 10:48 PM   in reply to TK_Churchill
    You're connected to an SMB server that isn't working quite right.
    And MacOS is having trouble with one of the windows in Photoshop - so that might be a symptom of the failure to draw, but doesn't tell us why the OS is having trouble with a window.
    Oct 24, 2013 10:50 PM   in reply to TK_Churchill
    Thanks for posting these images.
    Yes the CGSLockWindow failure is interesting. What kinds of tasks are you doing in Photoshop before this happens?
    Oct 24, 2013 11:53 PM   in reply to Jesper Storm Bache
    I'm having the same problems as described above after installing Mavericks.  White boxes instead of menus.  I've tried basic troubleshooting, uninstalling, reinstalling, wiping prefrences clean, updating Photoshop.  No change in results.
    I'm having problems when I use the polygonal lasso, sometimes transforming objects (I get a weird white square next to the boudning box) and also certain brushes simply stall photoshop.
      I also run a wacom cintiq.  Could this be tablet related?
    Michael
    Oct 25, 2013 12:01 AM   in reply to Mmaher6540
    "I also run a wacom cintiq.  Could this be tablet related?"
    My feeling says this is the case. When I disconnect the tablet and connect / work with a mouse the Lasso tool seems to work without problems.
    Maybe Wacom driver is not ready for Mavericks...?
    How can we further test this?
    Oct 25, 2013 5:34 AM   in reply to TK_Churchill
    All right, it happened on our third iMac today, so on a total of three computers. Here's a detailed screen recording (view on 1080p to see everything) showing the menu bug, the cursor bug, and some other glitches. I also show the Applications folder and the System Preferences panel to show you what's installed on the system.
    Here's what I was doing before it happened: I opened Photoshop at 9 am and started working on large, multi-layered, 2-3 GB PSB files, editing the contents of smart objects using various tools. I do this every day. The bug happened all of a sudden at 12:15 pm. I quit Photoshop and reopened it, it's all back to normal for now.
    I have the latest Wacom driver installed, version 6.3.7-3, just in case someone's wondering.
    Here are some Console messages from around that time (many many many of these repeat over pages, especially the first one, so I'm only pasting in everything that seems relevant once):
    25/10/2013 12:14:57.005 Adobe Photoshop CC[10910]: CGError CGSGetDisplaySystemState(uint64_t, CGSDisplaySystemState **): MIG error 0x10000003: (ipc/send) invalid destination port
    25/10/2013 12:14:59.053 Adobe Photoshop CC[10910]: _CGSLockWindow: Unable to lock window
    25/10/2013 12:15:18.458 com.apple.launchd[1]: (com.n-able.agent-macos10_4ppc) Throttling respawn: Will start in 10 seconds
    25/10/2013 12:16:08.771 WindowServer[130]: _CGXGetWindowOrderingGroup: Operation on a window 0x2e7f requiring rights 0x5 by caller Photoshop
    25/10/2013 13:20:26.350 WindowServer[130]: _CGXSetWindowBackgroundBlurRadius: Invalid window 0xffffffff
    Oct 25, 2013 6:45 AM   in reply to TK_Churchill
    We're also connected to an SMB share network, unfortunately it's an old network and it's always causing various file-related problems. Not sure if that's related to the Photoshop bug.
    Oct 25, 2013 7:05 PM   in reply to TK_Churchill
    I am having the same issue. The menus go white and when I went to slide the opacity the spunge icon appeared instead of the percentage.  This has only been happening since upgrading to mavericks.
    Using CS6 PS with Wacom tablet.  Restarting PS solves the issue short term.  I am not connected to any other servers.
    Model Name:          iMac
      Model Identifier:          iMac13,2
      Processor Name:          Intel Core i7
      Processor Speed:          3.4 GHz
      Number of Processors:          1
      Total Number of Cores:          4
      L2 Cache (per Core):          256 KB
      L3 Cache:          8 MB
      Memory:          32 GB
      Boot ROM Version:          IM131.010A.B05
      SMC Version (system):          2.11f16
    Oct 25, 2013 7:17 PM   in reply to Venture1
    Thank you for this video.
    When the problem occurs can you try the following two things:
    - Drag a panel out of a group & see if the dragged panel is a white surface or has the expected look
    - Right click on the document tab to get the popup menu that contains "Reveal in Finder". Does this menu show?
    Oct 26, 2013 3:09 AM   in reply to Jesper Storm Bache
    I also have this problem. To answer your questions...
    - Right click brings up the menu - but it is also white
    - dragging a panel out - it is a white box but the image i'm working on does show ok within it.
    I have disabled all plugins etc, reinstalled photoshop cc and it still doesn't work.
    Oct 27, 2013 8:06 AM   in reply to TK_Churchill
    I have the same issue with white menus. Recently upgraded to Mavericks. Happens after I've been working on just one image, so I have to guess where to press, to save it, and then restart PS. This is incredibly annoying and time consuming. Have you found a solution yet? I have Wacom tablet as well as many of you guys. I don't have any third party plugins in Photoshop, but I have third party installations on my macbook pro.
    Oct 27, 2013 10:16 AM   in reply to byingeborg
    So far we do not have a reproducible test case. I see that you are using a Wacom tablet. Have to updated your Wacom driver to the latest version? (http://us.wacom.com/en/support/drivers)
    Oct 27, 2013 1:06 PM   in reply to Jesper Storm Bache
    If there - I have the issue with Photoshop CC - I updated my wacom drivers but still the same issue...
    Oct 27, 2013 9:50 PM   in reply to pcrymble2
    I too have updated my Wacom drivers, and have found that there is no difference regarding this issue.
    Unfortunately, the 'blank menus' are appearing so often, that I must restart photoshop (at first sight of the problem) 6 to 7 times DAILY.  I am now at the point where I am considering drastic alternatives, such as going back to Photoshop CS5 or even wiping my system and reinstalling the previous OS all together.  There is no doubt that this issue will cause serious professional problems (if applicable) for any who encounter it.
    It would mean a great deal to me personally to have this issue resolved.
    Please let me know what I can do to help.
    Oct 27, 2013 10:01 PM   in reply to Mmaher6540
    It would be helpful if you can describe the steps (roughly) that you take from start of Photoshop until the problem occurs:
    - How many documents do you open and close?
    - Which tools and filters are you using?
    - Which Wacom model are you using?
    Thanks four your help
    Jesper
    Oct 28, 2013 1:38 AM   in reply to Jesper Storm Bache
    Jesper
    It happens to me when working with PSD files - I have one psd open and a number of of ther JPGs.
    I'm creating album layouts - so only using basic functionality such as crop, copy/paste/, dodge/burn, layer masks, occasionally liquify. It's hard to know exactly when it happens - as you don't notice it until you go to use a new tool or menu...
    I'm using Wacom Intuos 5 tablet.
    As one of the other guys said, its making photoshop nearly unusable for me - so anything I can do to help you get to the bottom of it please let me know!
    Peter
  • Pierre Courtejoie
    Jan 11, 2006
    Oct 28, 2013 5:45 AM   in reply to Jesper Storm Bache
    Jesper, would looking at the GPU sniffer log be useful?
    Oct 28, 2013 8:41 AM   in reply to Pierre Courtejoie
    Having absolutly the same problem! I have to cmd alt esc every 2 minutes it's not possible to work like that! I am a professional photograper and I have to prepair a lot of pictures - hope there will be a solution as fast as possible.
    Oct 28, 2013 8:47 AM   in reply to Pierre Courtejoie
    Jesper,
      This can vary, as the problem occurs with one file and also with several files open in Photoshop.  I am usually running Firefox and Preview with a few windows/tabs simultaneously.  Occasionally iTunes will also be running.
      I use the Brush tool most often, occasionally the polygonal lasso, transform tool, the smudge tool and the eraser
      Wacom, Cintique 22
    Oct 28, 2013 8:52 AM   in reply to Mmaher6540
    at me, most of the Time it happens after clicking the "abwedler Werkzeug" "nachbelichter Werkzeug" (sorry, don't know it in english... its German ;-)
    I use Wacom inotus 4
    Oct 28, 2013 9:00 AM   in reply to BMphotography
    I believe that's Abwelder Werkzeug (Detutsche) or the 'Dodge tool' in English.
    I also use this on a regular basis.
    However, I might point out that no specific tool is setting off the problem consistently for me.
    If anything, I notice it most with the transform tool because a white square will appear next to the bounding box.
    Oct 28, 2013 9:08 AM   in reply to Mmaher6540
    no problems with working by mouse... uaaah i hate prepairing pics by mouse!
    Oct 28, 2013 12:08 PM   in reply to TK_Churchill
    Another customer reports that updating his Wacom driver has solved this issue for him:
    https://twitter.com/tiutenko/status/394886515966230528
    can you guys try updating your wacom drivers and let us know if that solves it for you as well?
    Oct 28, 2013 12:47 PM   in reply to Jeffrey Tranberry
    I have reinstalled the wacom driver as suggested.  I can now access my wacom preferences under system prefs.  Also, my intuos 3 is finally showing up and working correctly, as well.
    I will keep you posted on whether or not this fixes the blank menu bug.
    Thanks for the help thus far Jeffrey,
    Michael
    Oct 28, 2013 1:10 PM   in reply to Mmaher6540
    Sweet. Keep us informed!
Actions
Bookmarked By (7)
