Integrating Robohelp files and folders in repository
Oct 24, 2013 1:43 AM
I am using robohelp 10 for generating word document and eclipse help.
Now we wanted to publish the outputs from a repository using command line syntax.
As far I know, we have to keep the project files, css, images, baggage files, toc contents in the repository. We dont want the files which will be re-generated during publish to be inside the repository, as it consumes more space.
Could anyone support me for the required files (to be saved in the repository) and the regenrated files (to be removed in the repository for reducing the space)?
Regards,
Nalini
    Oct 24, 2013 11:54 AM   in reply to dhanya.p
    I’m not sure whether I understand the question. Bur from what I gather, you can store the RoboHelp project in a respository. When you generate, choose to generate to a location outside that repository, such as your C drive. (You set this in the Single Source Layout.) This way, RoboHelp will not add output files into the repository location.
    If you are talking about a repository, what exactly are you talking about? Some kind of source control system?
    Greet,
    Willam
