RTTT
changing color
Oct 24, 2013 3:48 PM
How can I change sections of a photo to white?
    Oct 24, 2013 4:25 PM   in reply to RTTT
    1. Open the picture in full editor (expert tab in PSEv.12)
    2. Make a selection of the object designated for the color change, using one of the selection tools - e.g. Selection brush, lasso tool. Once the selection is complete, you should see a wiggly outline surrounding it - referred to as marching ants
    3. Go to Edit menu>fill selection>contents - use white
    4. Go to CTRL+D to get rid of the marching ants
    Oct 24, 2013 11:41 PM   in reply to RTTT
    The stpes provided by hatstead above should very well in PSE 11. May you are not following the steps correctly or you are not able to make a precise selection. You have to use selection tools very carefully and precisely select the section of the photo that you want white. Then use either
    - Go to Edit menu>fill selection>contents - use white.
    - Select Brush Tool (Shortcut B) . Set foreground color to white . Paint over the selected sections of the photo that you want white.
    See this adobe help link for making selections
    http://helpx.adobe.com/photoshop-elements/using/making-selections.html
    Oct 25, 2013 2:20 AM   in reply to RTTT
    This should work in all versions of the program. Where are you getting stuck?
    Sent from my iPad
