kristinbaylis
Help with Mavericks crashes Photoshop CC & bugs with Illustrator CC?
Oct 24, 2013 8:48 PM
Tags: #photoshop #bugs #illlustrator #mavericks #crashes_upon_launch
Have I missed an update specifically for CC users who have upgraded to Mavericks? Really wishing I had held off on the upgrade to the OS - luckily my CS4 is still compatible with the java update, however had just purchased the CC license, and wanted to use the new apps - now Photoshop CC crashes on launch (havent successfully opened one file in it without having to force quit it) and Illustrator CC bounced for a while then stopped. Randomly five minutes later the app launched. I quit it then re-opened to check for lag again, seemed fine - but then switched between that app and another, then returned to Illustrator CC and took ages for it to open. I am on a 3.4GHz intel core i7 iMac with 16GB memory 1600mhz ddr3, it shouldn't be having any lag problems, and is only a couple months old.
    Oct 24, 2013 9:47 PM   in reply to kristinbaylis
    If you have a crash, we need to see the crash report to know what is going on.
    The Illustrator launch just sounds like something hung for a while - could be an OS issue, or a driver/hardware problem (disks are the most common cause, followed by network servers, printers, scanners, etc.).
    Oct 24, 2013 9:48 PM   in reply to kristinbaylis
    Can you post the crash logs? Also, please go to Help> System Info... and copy/paste that info in your reply.
    regards,
    steve
    Oct 24, 2013 10:05 PM   in reply to kristinbaylis
    In Finder, Cmd+Shift+G to bring up the Go to Folder path input. Then paste in "~/Library/Logs/DiagnosticReports" and look for Adobe Photoshop CC...
    regards,
    steve
    Oct 24, 2013 10:18 PM   in reply to kristinbaylis
    Make sure you include the ~ in the path. That points to your user directory instead of the root directory.
    regards,
    steve
    Oct 24, 2013 10:46 PM   in reply to kristinbaylis
    That's not a crash report, just a hang/freeze report (crashes and freezes are very different things).
    What that shows is that Photoshop was waiting for the OS to get some font information - and that can take a while if the OS font cache is corrupted or incomplete (like you just installed the OS).
    Oct 25, 2013 11:40 AM   in reply to kristinbaylis
    OK, my guess is that there was a problem in the OS font cache and that letting Photoshop finish it's font list and previews allowed the OS to rebuild the font cache.  20 minutes does seem a bit excessive though. Do you have a lot of additional fonts installed?   (I want to get more info, in case others run into this, or in case we need to follow up with Apple)
