martin275
Ellipse shape multi-stage object
Oct 26, 2013 11:12 PM
Tags: #button #indesign #multi #object #stage #ellipse #multi_stage_object
I have a few images I inserted into circle frames. I can easily convert them to a multistage object and control them with a button, but once converted to an SWL and exported to interactive PDF they do not have the ellipse frame - drop shadow - and white stroke I applied...they go back to a simple flat rectangle...help!
    Oct 27, 2013 4:53 AM   in reply to martin275
    There's something issue like this, but it related to clip movies into nonrectangular shapes, they appear as full frame rectangles in PDF or SWF. But there is a work around solution.
    I replicate your issue here on indesign CS6, make object state (circle frames), add button to go to next page then export to SWF then place in indesign and export to interactive pdf, it work fine.
    Oct 28, 2013 2:21 AM   in reply to martin275
    I'm curious about this: what is a "multistage" object? Can not find the word or just "stage" in relation to "object" in the Indesign Reference.
    Oct 28, 2013 2:23 AM   in reply to Doc Maik
    I think they mean "multi-state" object or MSO.
    Oct 28, 2013 4:16 AM   in reply to [Ariel]
    Oct 28, 2013 5:27 AM   in reply to martin275
    When I place the SWF file it is not to scale I left scale to
    100% of document and set a point with guides for inserting but part of the image is removed.
    When you place SWF in the frame go to Object menu>Fitting>Fit Content Proportionally
