purposeofparables
Can't burn CD in CS6
Oct 27, 2013 4:08 PM
In CS6, when I click the "Burn Audio To CD" button, the dialogue box has the OK button grayed out. It shows the correct CD/DVD drive, but I  can’t launch the action. I am using an HP Envy 700-010xt with Windows 8.1 OS and CDR media. The CD/DVD burns perfectly in all other Applications (iTunes, Windows Media Player, etc.) I am using CS6 version 5.02 Build 7.  What can I do to fix this…CD burning in CS6 is critical! Thx,
    Oct 30, 2013 8:50 AM   in reply to purposeofparables
       10/30/2013   I get this Problem too. Sometimes it sees the Blank Disc. And other Times it doesn't. I am using the same Version as the one you have too. Let me know if you find out anything about how to Fix this.
  • SteveG(AudioMasters)
    Oct 26, 2006
    Oct 30, 2013 10:27 AM   in reply to KBeeWhyAreDee
    Because this is an individual issue, and clearly hardware-related, you either need developer comment, or preferrably to phone the Adobe chat line, and get them to talk you through the issue directly, because often this is complicated by settings within your OS.
    The only general comment I can make is that you should both make sure that you have Administrator rights when you use Audition - not having these can make weird things happen sometimes.
    Dec 4, 2013 4:46 PM   in reply to purposeofparables
        I used another Brand of Blank CD and that was what was going on with my problem. It was able to see the more Expensive Brand of Blank CD.
    Oct 26, 2006
    Dec 5, 2013 3:13 AM   in reply to KBeeWhyAreDee
    In this case, your problem is simply a lack of reflectivity from the cheaper discs - not that rare. But it also means that your CD drive isn't exactly making a lot of effort... you might need to replace it soon, as it sounds as though the laser isn't working too well.
    Dec 5, 2013 5:10 AM   in reply to SteveG(AudioMasters)
      This is a Brand Spanking New Laptop (I only had it for 2 Weeks)---->Toshiba Satellite. It is not the Hardware. It is the Software or as you call it Cheap Quality Disc with lack of Reflectivity.Thank You for Helping me out.
    Oct 26, 2006
    Dec 5, 2013 5:49 AM   in reply to KBeeWhyAreDee
    Sorry, I didn't realise that everything brand new has to work properly... Silly me.
