SokesFilms
Rendering/Exporting Overheating ASUS
Oct 27, 2013 9:47 PM
Tags: #overheating #over-heating #cpu_overheat
Okay getting completely irritated with these issues of overheating when I even just am rendering a video to get ready for export (and also on exporting)
Computer Specs:
Windows 8 64-bit
System Model CM1855
BIOS 0802
AMD FX(tm)-8120 Eight-Core Processor (8CPUS), 3.1GHz
Memory 8192MB RAM
Page File 2211MB used 7100avail
DirectX 11 Version
I have tried setting power controls to the CPU to 80% but using SpeedFan I can see the CPU usage still spiking 90%-98% and heating just keeps rising and rising til shutdown.
Idle CPU
Rendering Usage in Balanced Power Settings
Rendering Usage in High Power Settings
I really suck at understanding these things.  But changing from Balanced to High Power didnt seem to affect the rendering times.  But also the time was down at like 20-40 minutes before I started messing with the power controls now its at over 2 hours.
Finished a small render with success but it got pretty hot again and Norton pops up saying High CPU usage by PPro.  100% was hit quite a bit too.
If someone could help me out I have 2 wedding videos to get completed.
    Oct 27, 2013 10:02 PM   in reply to SokesFilms
    Try using set affinity.
    http://www.youtube.com/watch?v=ZpX98T8eYuI
    I've used it for overheating and it works fine.
    Oct 27, 2013 11:03 PM   in reply to SokesFilms
    Untick processors 1,3,5,7 for Adobe Premiere or Adobe Encoder, whichever is using the most CPU cycles.
    Now only 1/2 of your processors are working.  That should lower your internal temperature a bit.
    Oct 28, 2013 8:53 AM   in reply to SokesFilms
    What brand/model CPU cooler do you have, and when is the last time you opened your case and "carefully" vacumed the dust out?
    I never have CPU heat problems (link http://forums.adobe.com/thread/652694 includes a link to the computer I built) but I DO have a good CPU cooler and a case with 2 side fans blowing air directly onto the motherboard
    Oct 28, 2013 11:57 AM   in reply to SokesFilms
    Adobe Media Encoder. It launches when you export from Premiere via the Queue command. The render that you're performing is handled within Premiere Pro's process.
    It's not necessary to pre-render within Premiere prior to exporting. Rendering helps with exporting only if you enable the Use Previews, and that's recommended only in a few special cases.
    Perhaps if you tell us a bit about your sequence, we can advise as to whether it's expected that the CPU would be working so hard.
    • What are the sequence's video dimensions & timebase and the Video Preview settings? (a screenshot of the Sequence Settings dialog will fill in all these blanks)
    • Does your content match the settings?
    • What effects are applied to clips in the sequence?
    • Does the sequence contain a lot of nested or multicam sequences?
    Also, on the hardware side, what graphics card is installed? Does it support GPU acceleration, and is that option enabled (File>ProjectSettings>General>Renderer)?
    Oct 28, 2013 2:09 PM   in reply to Mark Mapes
    According to what I found via Google, the ASUS CM1855 has AMD CPU and AMD GPU, but he mentions CC so his GPU "may" allow hardware acceleration (I found several configurations under that model, so not really sure if his GPU has enough memory for hardware acceleration)
    As far as his comment "weird that Adobe makes it overheat and Vegas supposedly does not" that would be similar to saying "it's odd that my Chevy oil filter won't fit my Ford truck" where the two programs do things differently (at least that is my opinion)
    Oct 28, 2013 5:04 PM   in reply to SokesFilms
    Change your warning settings.  There's nothing wrong with 64C.  Mine regularly gets to over 80C and has for years without issue.
    Oct 28, 2013 5:58 PM   in reply to SokesFilms
    I bought a fan specifically to aim air at the intake of my PC.  It reduced the temp significantly. Of course, all that really means is that I should have more fans in my case, but the external fan works fine.
    Oct 28, 2013 6:04 PM   in reply to SokesFilms
    No it hits 88C then turns off
    OK, that is a bit hot.  You will likely need to get better cooling.
