Photoshop CC on Mavericks: Photoshop slows down/freezes often
Oct 28, 2013 4:44 AM
Tags: #photoshop #lag #slowness #mavericks
Ever since updating to Mavericks, in addition to having the blank menus problem (see relevant thread: http://forums.adobe.com/message/5785359#5785359), I noticed that about once every hour or so, Photoshop will stop reacting to things (it's not listed as "Not Responng" though and there is no beachball or grey circles cursor). Sometimes it will go back to normal on its own, sometimes I can click on a different app and go back into Photoshop and it's fine, but sometimes this won't help. If I work on huge files (2-3 GB PSB files) then slowdowns get much more frequent to the point where I click on something, it freezes for 2 minutes, and then I continue working for a few seconds and it freezes again and so on, until I quit and reopen the file. This has happened a lot on large files, but the short slowdowns always happen regardless of file size. It's extremely annoying and far worse than the blank menu bug.
I notice that most of the time (if not always) I am using the Brush tool when this happens (this might be coincidence - I use the Brush a lot).
I can't yet figure out how exactly the process happens, but it only occured to me now that this may not be general normal slowness since it never happened before. I have 16 GB of RAM on a fresh new iMac so system performance should not be an issue, especially not on tiny files.
I will provide more info when the bug happens again, in the meantime, does anyone else have this issue? Any suggestions?
Also, no I don't have any dodgy programs installed. OS X Mavericks, Photoshop CC 14.1.2, and Wacom Intuos 4 Driver 6.3.7-3, plus some other apps that are necessary to run a computer nowadays (Perian, MPEG Streamclip, Flash, Java, and not much more (see screenshot).Screen Shot 2013-10-28 at 11.41.15.png
    Oct 28, 2013 11:08 AM   in reply to Venture1
    Sampling/profiling the process while it's hung might give us some idea what is going on.
    But so far we just keep seeing the application waiting on some part of the OS (disk access, or font information).
    Oddly, Perian has been mentioned by a few people having the blank menu problem....
    Oct 29, 2013 4:56 AM   in reply to Venture1
    I'm having this exact same issue on a brand new Retina Macbook Pro. It happens most frequently when trying to undue a brush stroke ( I do that all the time so that might be where I'm noticing it) Photoshop CC is updated and I have the latest Wacom Drivers. I think it might be related to the Wacom Drivers.
    Oct 29, 2013 5:04 AM   in reply to Venture1
    Yes, after watching your video I put activity monitor side by side with Photoshop and watched the CPU usage spike when it froze. Exactly like yours it went up to 80 percent.
    Oct 29, 2013 8:14 AM   in reply to ChrisML
    I'm having the exact same problem with Photoshop CC on mavericks. It become totally unusable, especially on larger files - freezes up, does sort itself eventually, maybe 5-10 minutes after the freeze starts. Interestingly I have this problem on my mac Mini but not my 13" rMBP. The Mac Mini is fine when using CS5.1
    Oct 29, 2013 8:24 AM   in reply to tim-p
    Incidentally my Mac Mini has a fusion drive. i suspect that's what's causing the problem, should anyone from adobe be interested!
    Oct 29, 2013 8:34 AM   in reply to tim-p
    I've had slowdowns like this in the past, where photoshop would freeze for up to 5 minutes and then return. In my case it was a failing hard drive (which eventually failed completely before I could backup my data). I suspect that when Photoshop was writing to the scratch disk, it was hitting the bad sectors and that was my first indicator that I ignored (only because something like that had never happened before.) Fast forward to today: if I ever experience a temporary freeze in Photoshop like that again, my first step will to be back up all data and then troubleshoot from there - don't want that happeneing again.
    No clue if this is related or not but just a heads up that it might be something to look into.
    Oct 29, 2013 9:36 AM   in reply to boo radley 2013
    Thanks for the contribution - that was my first thought too, based on a previous HDD failure. However, the fact that it doesn't happen working on the same files with 5.1 leads me to suspect CC rather than HDD. I ran a full TechTool Pro scan yesterday which didn't show up any hardware problem and no bad sectors. However, I have also assiduosly backed up as well, just in case!
    Oct 29, 2013 10:05 AM   in reply to Venture1
    I also have this problem. After a long wait, the program resumes most of the time.
    My Mac is a few years old.
    Photoshop 14.1.2. x64
    My Mac is OS X 10.9
    Processor 2 x 2.8 GHz Quad-Core Intel Xeon
    Memory 6 GB 800 MHz RAM
    Oct 29, 2013 2:05 PM   in reply to Venture1
    I know it's not a hard drive issue, as I have purchased both the new 13 inch macbook pro with retina display and 15 inch macbook pro with retina display and this is issue is a problem with both computers. I have tried on two different wacom tablets. The problem doesn't seem to be there if I use the built in trackpad, which leads me to believe that Wacoms drivers are not ready for prime time.
    Oct 29, 2013 2:35 PM   in reply to Venture1
    I'd like to know if the issue occurs when Photoshop is the only application running on the system.  I'd also like to know if the issue occurs when a mouse is used to drive the app instead of stylus/tablet.  Does this only occur when using a tablet device?
    Also, how much free space do you have on your OS volume?  I found the OS to start freezing even when I had ~60GB free on the OS volume.  Thought it was my hardware, but I'll check more tomorrow when I have access to the machine (MacPro 2x6core).  I do not see this problem on a newer iMac (w/fusion drive) or my Retina MBP.
    A couple things to try:
    1.  Check if Adobe Drive is enabled in File Handling prefs - if it is, disable it
    2.  Also in File Handling prefs, try disabling Automatically save recovery information
    Do either of those things help overall performance?
    Adam
    Oct 29, 2013 7:07 PM   in reply to Adam Jerugim
    I have the problem no matter what. I've ran it as the only application open.  File Handling prefs are disabled. Automatic saved is disabled. It works fine without using the Wacom tablet plugged in. Adobe needs to get in touch with Wacom and get this issue resolved. The new drivers are not working for me. I wonder if it has anything to do with it being a fresh install of Mavericks (since it's a brand new computer that was just released )and not an upgrade from a previous OS.
    Oct 29, 2013 9:58 PM   in reply to Adam Jerugim
    I mostly notice my photoshop freezing when I try to use the "step backward" shortcut. I noticed that when the program freezes and I'm unable to perform the shortcut I can still use my Wacom tablet to select "step backwards" from the menu bar and it will work. I have no idea why. During this time of Photoshop being frozen I can not click any of the keys to select another tool. I can however make another selection to the image using my brush and then it will allow me to undo from that point... until it freezes again.
    Oct 30, 2013 12:44 AM   in reply to Adam Jerugim
    In my case I haven't been using a Wacom tablet, although I did have one installed. The old software does not seem to be compatible and I have removed it now. i was using a traditional mouse and a magic trackpad some of the time.
    I'll test it and see if the problem is gone, then try the other suggestions.
    Oct 30, 2013 1:23 AM   in reply to tim-p
    Looking further at this, I have been having one other problem with mavericks, which is that my DXT ergonomic mouse became laggy and very difficult to use with precision. I have removed the wacon application/driver and disconnected the third party mouse and - so far - alll is well again. i am wondering if Photoshop isn't the victim of a wider issue with third party pointers?
    Oct 30, 2013 9:27 AM   in reply to tim-p
    That's what I was thinking. Wacom keeps repeating that their drivers are "fully compatable". I guess that doesn't mean work correctly but rather just work. Anyone at Adobe able to replicate this error? I have a tough time believing that 2 of these new computers I just bought just so happen to have a random bug with photoshop and Wacom tablets under Mavericks.
    Oct 31, 2013 5:05 PM   in reply to ChrisML
    Anyone making any progress towards a solution?
    Nov 4, 2013 1:10 AM   in reply to ChrisML
    I removed the old Wacom driver and thought this had solved the problem. Unfortunately I later discovered it hadn't. It seemed ok on smaller files but bigger ones still triggered the problem, although instead of completing freezing the mac I found things like activity Monitor still accessible (which they weren't before).
    I noticed a component of Sophos was eating processor usage during the freezes, so i tried unchecking the scan on demand option, and so far - touch wood - this seems to have fixed it. I wonder whether my problem isn't that Sophos on mavericks gets indigestion on the bigger files and that only PS CC triggers it (because 5.1 doesn't)? I will use it some more today and report back.
    Nov 4, 2013 1:00 PM   in reply to tim-p
    I don't have Sophos installed on my system...
    Nov 4, 2013 3:24 PM   in reply to ChrisML
    Hello, I have a similar issue that is being looked at by Adobe.
    http://feedback.photoshop.com/photoshop_family/topics/keyboard_shortcu ts_not_responding_photoshop_cs6_mavericks?utm_content=reply_link&utm_m edium=email&utm_source=reply_notification#reply_13240422
    Maybe follow this thread for developments.
    In the meantime I think I am going to revert back to Mountain Lion, where life was more simple.
    A
    Nov 7, 2013 9:29 AM   in reply to ChrisML
    Please take a look at the console log while Photoshop is having performance issues (to use Console, go to Applications/Utilitlies/Console and launch the app - set it to show all messages.   What (if anything) is being logged there while Photoshop runs?
    Adam
    Nov 7, 2013 9:57 AM   in reply to Adam Jerugim
    Not quite sure what I'm looking for here. I can provide the Photoshop User Diagnostic Report if that's any use?
    It's rather a large amount of text though...
    Process:         Adobe Photoshop CS6 [1590]
    Path:            /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/MacOS/Adobe Photoshop CS6
    Identifier:      com.adobe.Photoshop
    Version:         13.0.0 (20120315.r.428)
    Code Type:       X86-64 (Native)
    Parent Process:  launchd [228]
    Responsible:     Adobe Photoshop CS6 [1590]
    User ID:         501
    Date/Time:       2013-10-24 12:54:43.516 +0100
    OS Version:      Mac OS X 10.9 (13A603)
    Report Version:  11
    Anonymous UUID:  CBBB16F3-7EEA-4051-E87A-47A57D68A432
    Sleep/Wake UUID: 97AE079D-5982-4F98-891D-BC995176B9BA
    Crashed Thread:  0  Dispatch queue: com.apple.main-thread
    Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
    Exception Codes: KERN_PROTECTION_FAILURE at 0x00007fff5f3fffc8
    VM Regions Near 0x7fff5f3fffc8:
        MALLOC_NANO            0000608000c00000-0000608052e00000 [  1.3G] rw-/rwx SM=PRV
    --> STACK GUARD            00007fff5bc00000-00007fff5f400000 [ 56.0M] ---/rwx SM=NUL  stack guard for thread 0
        Stack                  00007fff5f400000-00007fff5fc00000 [ 8192K] rw-/rwx SM=COW  thread 0
    Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
    0   com.apple.CoreFoundation                0x00007fff8ead0097 CFBasicHashFindBucket + 327
    1   com.apple.CoreFoundation                0x00007fff8eacff1f CFDictionaryGetValue + 111
    2   com.apple.CoreFoundation                0x00007fff8eb07274 _copyValueForKey + 260
    3   com.apple.CoreFoundation                0x00007fff8eb07147 -[CFPrefsPlistSource copyValueForKey:] + 71
    4   com.apple.CoreFoundation                0x00007fff8eb06fa5 -[CFPrefsSearchListSource alreadylocked_copyValueForKey:] + 149
    5   com.apple.CoreFoundation                0x00007fff8eb06edf -[CFPrefsSource copyValueForKey:] + 79
    6   com.apple.CoreFoundation                0x00007fff8eb06e70 __CFPreferencesCopyAppValue_block_invoke + 32
    7   com.apple.CoreFoundation                0x00007fff8eb0104e +[CFPrefsSearchListSource withSearchListForIdentifier:perform:] + 846
    8   com.apple.CoreFoundation                0x00007fff8eb00cb8 CFPreferencesCopyAppValue + 168
    9   com.apple.FinderKit                     0x00007fff8b4594ad -[FI_TUserDefaults _finderObjectForKey:] + 25
    10  com.apple.FinderKit                     0x00007fff8b45964d -[FI_TUserDefaults objectForRegID:] + 98
    11  com.apple.FinderKit                     0x00007fff8b45a570 +[FI_TUserDefaults dictionaryForRegID:] + 61
    12  com.apple.FinderKit                     0x00007fff8b420e31 TSharedServerNode::ViewSettingsDictionary() const + 123
    13  com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    14  com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    15  com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    16  com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    17  com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    18  com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    19  com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    20  com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    21  com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    22  com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    23  com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    24  com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    25  com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    26  com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    27  com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    28  com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    29  com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    30  com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    31  com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    32  com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    33  com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    34  com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    35  com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    36  com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    37  com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    38  com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    39  com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    40  com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    41  com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    42  com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    43  com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    44  com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    45  com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    46  com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    47  com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    48  com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    49  com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    50  com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    51  com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    52  com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    53  com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    54  com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    55  com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    56  com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    57  com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    58  com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    59  com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    60  com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    61  com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    62  com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    63  com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    64  com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    65  com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    66  com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    67  com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    68  com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    69  com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    70  com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    71  com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    72  com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    73  com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    74  com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    75  com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    76  com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    77  com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    78  com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    79  com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    80  com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    81  com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    82  com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    83  com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    84  com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    85  com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    86  com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    87  com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    88  com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    89  com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    90  com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    91  com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    92  com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    93  com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    94  com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    95  com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    96  com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    97  com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    98  com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    99  com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    100 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    101 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    102 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    103 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    104 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    105 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    106 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    107 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    108 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    109 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    110 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    111 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    112 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    113 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    114 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    115 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    116 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    117 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    118 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    119 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    120 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    121 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    122 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    123 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    124 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    125 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    126 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    127 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    128 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    129 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    130 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    131 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    132 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    133 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    134 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    135 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    136 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    137 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    138 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    139 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    140 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    141 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    142 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    143 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    144 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    145 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    146 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    147 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    148 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    149 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    150 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    151 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    152 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    153 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    154 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    155 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    156 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    157 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    158 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    159 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    160 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    161 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    162 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    163 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    164 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    165 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    166 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    167 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    168 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    169 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    170 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    171 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    172 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    173 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    174 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    175 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    176 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    177 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    178 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    179 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    180 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    181 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    182 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    183 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    184 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    185 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    186 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    187 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    188 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    189 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    190 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    191 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    192 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    193 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    194 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    195 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    196 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    197 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    198 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    199 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    200 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    201 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    202 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    203 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    204 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    205 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    206 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    207 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    208 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    209 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    210 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    211 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    212 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    213 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    214 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    215 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    216 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    217 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    218 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    219 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    220 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    221 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    222 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    223 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    224 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    225 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    226 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    227 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    228 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    229 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    230 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    231 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    232 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    233 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    234 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    235 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    236 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    237 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    238 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    239 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    240 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    241 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    242 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    243 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    244 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    245 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    246 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    247 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    248 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    249 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    250 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    251 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    252 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    253 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    254 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    255 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    256 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    257 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    258 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    259 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    260 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    261 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    262 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    263 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    264 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    265 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    266 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    267 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    268 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    269 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    270 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    271 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    272 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    273 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    274 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    275 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    276 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    277 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    278 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    279 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    280 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    281 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    282 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    283 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    284 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    285 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    286 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    287 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    288 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    289 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    290 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    291 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    292 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    293 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    294 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    295 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    296 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    297 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    298 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    299 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    300 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    301 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    302 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    303 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    304 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    305 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    306 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    307 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    308 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    309 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    310 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    311 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    312 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    313 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    314 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    315 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    316 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    317 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    318 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    319 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    320 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    321 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    322 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    323 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    324 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    325 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    326 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    327 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    328 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    329 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    330 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    331 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    332 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    333 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    334 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    335 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    336 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    337 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    338 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    339 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    340 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    341 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    342 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    343 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    344 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    345 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    346 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    347 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    348 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    349 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    350 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    351 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    352 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    353 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    354 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    355 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    356 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    357 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    358 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    359 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    360 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    361 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    362 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    363 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    364 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    365 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    366 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    367 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    368 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    369 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    370 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    371 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    372 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    373 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    374 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    375 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    376 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    377 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    378 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    379 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    380 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    381 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    382 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    383 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    384 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    385 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    386 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    387 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    388 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    389 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    390 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    391 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    392 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    393 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    394 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    395 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    396 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    397 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    398 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    399 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    400 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    401 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    402 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    403 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    404 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    405 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    406 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    407 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    408 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    409 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    410 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    411 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    412 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    413 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    414 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    415 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    416 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    417 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    418 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    419 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    420 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    421 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    422 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    423 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    424 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    425 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    426 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    427 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    428 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    429 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    430 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    431 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    432 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    433 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    434 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    435 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    436 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    437 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    438 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    439 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    440 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    441 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    442 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    443 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    444 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    445 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    446 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    447 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    448 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    449 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    450 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    451 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    452 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    453 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    454 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    455 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    456 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    457 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    458 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    459 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    460 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    461 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    462 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    463 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    464 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    465 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    466 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    467 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    468 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    469 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    470 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    471 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    472 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    473 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    474 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    475 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    476 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    477 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    478 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    479 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    480 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    481 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    482 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    483 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    484 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    485 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    486 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    487 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    488 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    489 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    490 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    491 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    492 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    493 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    494 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    495 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    496 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    497 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    498 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    499 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    500 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    501 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    502 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    503 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    504 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    505 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    506 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    507 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    508 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    509 com.apple.FinderKit                     0x00007fff8b3eee1b TCustomNode::SetSpatialData(DataBrowserItemSpatialData const&, bool&) + 45
    510 com.apple.FinderKit                     0x00007fff8b420e62 TSharedServerNode::ViewSettingsDictionary() const + 172
    511 com.apple.FinderKit                     0x00007fff8b3eaf08 TCustomNode::GetIconViewSettings(NSMutableDictionary**) const + 26
    Thread 1:: Dispatch queue: com.apple.libdispatch-manager
    0   libsystem_kernel.dylib                  0x00007fff8ff6e662 kevent64 + 10
    1   libdispatch.dylib                       0x00007fff8ace443d _dispatch_mgr_invoke + 239
    2   libdispatch.dylib                       0x00007fff8ace4152 _dispatch_mgr_thread + 52
    Thread 2:
    0   libsystem_kernel.dylib                  0x00007fff8ff6d716 __psynch_cvwait + 10
    1   libsystem_pthread.dylib                 0x00007fff8ee58c3b _pthread_cond_wait + 727
    2   MultiProcessor Support                  0x000000010bcdb0f3 main + 8403
    3   MultiProcessor Support                  0x000000010bcdb1b0 main + 8592
    4   MultiProcessor Support                  0x000000010bcf7f50 main + 126768
    5   libsystem_pthread.dylib                 0x00007fff8ee56899 _pthread_body + 138
    6   libsystem_pthread.dylib                 0x00007fff8ee5672a _pthread_start + 137
    7   libsystem_pthread.dylib                 0x00007fff8ee5afc9 thread_start + 13
    Thread 3:
    2   com.apple.CoreServices.CarbonCore          0x00007fff8ef22a50 TSWaitOnCondition + 108
    3   com.apple.CoreServices.CarbonCore          0x00007fff8ef22c4f TSWaitOnConditionTimedRelative + 172
    4   com.apple.CoreServices.CarbonCore          0x00007fff8eef338d MPWaitOnQueue + 192
    5   com.adobe.ACE                           0x00000001051452c9 0x10510c000 + 234185
    6   com.adobe.ACE                           0x00000001051445da 0x10510c000 + 230874
    7   com.apple.CoreServices.CarbonCore          0x00007fff8eef390b PrivateMPEntryPoint + 58
    8   libsystem_pthread.dylib                 0x00007fff8ee56899 _pthread_body + 138
    9   libsystem_pthread.dylib                 0x00007fff8ee5672a _pthread_start + 137
    10  libsystem_pthread.dylib                 0x00007fff8ee5afc9 thread_start + 13
    Thread 4:
    0   libsystem_kernel.dylib                  0x00007fff8ff6da3a __semwait_signal + 10
    1   libsystem_c.dylib                       0x00007fff8f37ce60 nanosleep + 200
    2   com.adobe.PSAutomate                    0x00000001199449cb ScObjects::Thread::sleep(unsigned int) + 59
    3   com.adobe.PSAutomate                    0x000000011992a7c9 ScObjects::BridgeTalkThread::run() + 169
    4   com.adobe.PSAutomate                    0x0000000119944d36 ScObjects::Thread::go(void*) + 166
    Thread 5:
    0   libsystem_kernel.dylib                  0x00007fff8ff69a1a mach_msg_trap + 10
    1   libsystem_kernel.dylib                  0x00007fff8ff68d18 mach_msg + 64
    2   com.apple.CoreFoundation                0x00007fff8eb37315 __CFRunLoopServiceMachPort + 181
    3   com.apple.CoreFoundation                0x00007fff8eb36939 __CFRunLoopRun + 1161
    4   com.apple.CoreFoundation                0x00007fff8eb36275 CFRunLoopRunSpecific + 309
    5   com.apple.AppKit                        0x00007fff951c11ce _NSEventThread + 144
    6   libsystem_pthread.dylib                 0x00007fff8ee56899 _pthread_body + 138
    7   libsystem_pthread.dylib                 0x00007fff8ee5672a _pthread_start + 137
    8   libsystem_pthread.dylib                 0x00007fff8ee5afc9 thread_start + 13
    Thread 6:
    2   com.adobe.ape.engine                    0x000000011ca88c0d APXGetHostAPI + 2516093
    3   com.adobe.ape.engine                    0x000000011c836ec1 APXGetHostAPI + 83761
    4   com.adobe.ape.engine                    0x000000011ca88cd1 APXGetHostAPI + 2516289
    5   com.adobe.ape.engine                    0x000000011ca88d4a APXGetHostAPI + 2516410
    6   com.adobe.ape.engine                    0x000000011ca88e79 APXGetHostAPI + 2516713
    7   libsystem_pthread.dylib                 0x00007fff8ee56899 _pthread_body + 138
    8   libsystem_pthread.dylib                 0x00007fff8ee5672a _pthread_start + 137
    9   libsystem_pthread.dylib                 0x00007fff8ee5afc9 thread_start + 13
    Thread 7:
    Thread 8:
    1   libsystem_pthread.dylib                 0x00007fff8ee58c77 _pthread_cond_wait + 787
    2   com.adobe.ape.engine                    0x000000011ca88bd0 APXGetHostAPI + 2516032
    3   com.adobe.ape.engine                    0x000000011caa0ddb APXGetHostAPI + 2614859
    Thread 9:
    3   com.adobe.ape.engine                    0x000000011cc1b2c3 APXGetHostAPI + 4164403
    Thread 10:
    0   libsystem_kernel.dylib                  0x00007fff8ff6d91a __recvfrom + 10
    1   ServiceManager-Launcher.dylib           0x000000011dd7d5ec Invoke + 45721
    2   ServiceManager-Launcher.dylib           0x000000011dd7c813 Invoke + 42176
    3   ServiceManager-Launcher.dylib           0x000000011dd7bbe0 Invoke + 39053
    4   ServiceManager-Launcher.dylib           0x000000011dd7bc66 Invoke + 39187
    5   ServiceManager-Launcher.dylib           0x000000011dd7730f Invoke + 20412
    6   ServiceManager-Launcher.dylib           0x000000011dd77616 Invoke + 21187
    7   ServiceManager-Launcher.dylib           0x000000011dd77cd7 Invoke + 22916
    8   ServiceManager-Launcher.dylib           0x000000011dd77f41 Invoke + 23534
    9   ServiceManager-Launcher.dylib           0x000000011dd7a61d Invoke + 33482
    10  ServiceManager-Launcher.dylib           0x000000011dd7a775 Invoke + 33826
    11  ServiceManager-Launcher.dylib           0x000000011dd7afb2 Invoke + 35935
    12  ServiceManager-Launcher.dylib           0x000000011dd7b0ad Invoke + 36186
    13  ServiceManager-Launcher.dylib           0x000000011dd6dd6b Login + 480
    14  ServiceManager-Launcher.dylib           0x000000011dd717ad Login + 15394
    15  ServiceManager-Launcher.dylib           0x000000011dd7b412 Invoke + 37055
    16  ServiceManager-Launcher.dylib           0x000000011dd7d253 Invoke + 44800
    17  libsystem_pthread.dylib                 0x00007fff8ee56899 _pthread_body + 138
    18  libsystem_pthread.dylib                 0x00007fff8ee5672a _pthread_start + 137
    19  libsystem_pthread.dylib                 0x00007fff8ee5afc9 thread_start + 13
    Thread 11:
    2   com.adobe.Photoshop                     0x00000001019d4dfb AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 18345115
    3   com.adobe.Photoshop                     0x00000001019d4ee2 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 18345346
    4   com.adobe.Photoshop                     0x00000001019d2d95 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 18336821
    5   com.adobe.Photoshop                     0x0000000101958160 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 17833984
    Thread 12:
    2   com.adobe.Photoshop                     0x000000010034a98b 0x100000000 + 3451275
    3   com.adobe.Photoshop                     0x00000001017137cb AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 15455851
    4   com.adobe.Photoshop                     0x000000010171061f AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 15443135
    Thread 13:
    0   libsystem_kernel.dylib                  0x00007fff8ff6de6a __workq_kernreturn + 10
    1   libsystem_pthread.dylib                 0x00007fff8ee57f08 _pthread_wqthread + 330
    2   libsystem_pthread.dylib                 0x00007fff8ee5afb9 start_wqthread + 13
    Thread 14:
    Thread 15:
    Thread 16:: CVDisplayLink
    2   com.apple.CoreVideo                     0x00007fff917bea38 CVDisplayLink::runIOThread() + 656
    3   com.apple.CoreVideo                     0x00007fff917be78f startIOThread(void*) + 147
    4   libsystem_pthread.dylib                 0x00007fff8ee56899 _pthread_body + 138
    5   libsystem_pthread.dylib                 0x00007fff8ee5672a _pthread_start + 137
    6   libsystem_pthread.dylib                 0x00007fff8ee5afc9 thread_start + 13
    Thread 17:
    Thread 18:
    2   com.apple.Foundation                    0x00007fff91a1aa39 -[NSCondition wait] + 237
    3   com.apple.Foundation                    0x00007fff919e721e -[NSObject(NSThreadPerformAdditions) performSelector:onThread:withObject:waitUntilDone:modes:] + 749
    4   com.apple.Foundation                    0x00007fff91a5572b -[NSObject(NSThreadPerformAdditions) performSelectorOnMainThread:withObject:waitUntilDone:modes:] + 85
    5   com.apple.CoreFoundation                0x00007fff8eb72384 ___forwarding___ + 452
    6   com.apple.CoreFoundation                0x00007fff8eb72138 _CF_forwarding_prep_0 + 120
    7   com.apple.imageKit                      0x00007fff8a504ae7 -[IKTaskManager taskLoop] + 2413
    8   com.apple.Foundation                    0x00007fff91a1d70b __NSThread__main__ + 1318
    9   libsystem_pthread.dylib                 0x00007fff8ee56899 _pthread_body + 138
    10  libsystem_pthread.dylib                 0x00007fff8ee5672a _pthread_start + 137
    11  libsystem_pthread.dylib                 0x00007fff8ee5afc9 thread_start + 13
    Thread 19:: com.apple.appkit-heartbeat
    2   libsystem_c.dylib                       0x00007fff8f37cd52 usleep + 54
    3   com.apple.AppKit                        0x00007fff952852ad -[NSUIHeartBeat _heartBeatThread:] + 2132
    4   com.apple.Foundation                    0x00007fff91a1d70b __NSThread__main__ + 1318
    Thread 0 crashed with X86 Thread State (64-bit):
      rax: 0x0000000000010000  rbx: 0x00007fff7ae57d00  rcx: 0x0000000000000005  rdx: 0x0000000000000001
      rdi: 0x00007fff5f4000e8  rsi: 0x00007fff7a76e548  rbp: 0x00007fff5f4000d0  rsp: 0x00007fff5f3fff90
       r8: 0x00007fff8a78b2ec   r9: 0x00007fff5f400200  r10: 0x0000000107085ec0  r11: 0x00007fff7ae59128
      r12: 0x00007fff5f4001c0  r13: 0x0000000000000004  r14: 0x0000600001a78bc0  r15: 0x0000600001a78bc0
      rip: 0x00007fff8ead0097  rfl: 0x0000000000010293  cr2: 0x00007fff5f3fffc8
    Logical CPU:     0
    Error Code:      0x00000006
    Trap Number:     14
    Binary Images:
           0x100000000 -        0x10333cfff +com.adobe.Photoshop (13.0.0 - 20120315.r.428) <6A87A703-3170-CA73-8C77-35C282C4E264> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/MacOS/Adobe Photoshop CS6
           0x1039bf000 -        0x1039ebff7 +libtbb.dylib (0) <57655978-A378-BE1E-7905-7D7F951AD6F7> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/libtbb.dylib
           0x103a02000 -        0x103a10ff3 +libtbbmalloc.dylib (0) <CB038B96-2999-5EB1-E26A-7720A7A8F8CD> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/libtbbmalloc.dylib
           0x103a24000 -        0x103a2afff  org.twain.dsm (1.9.5 - 1.9.5) <E614CAAE-7B01-348B-90E4-DB3FD3D066A6> /System/Library/Frameworks/TWAIN.framework/Versions/A/TWAIN
           0x103a32000 -        0x103a4cff7 +com.adobe.ahclientframework (1.7.0.56 - 1.7.0.56) <C1C5DE5C-39AB-0871-49A6-FA3449D39B8A> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
           0x103a55000 -        0x103a59fff  com.apple.agl (3.2.3 - AGL-3.2.3) <1B85306F-D2BF-3FE3-9915-165237B491EB> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
           0x103a60000 -        0x103c6efff +com.adobe.owl (AdobeOwl version 4.0.93 - 4.0.93) <CB035C4D-044D-4004-C887-814F944E62ED> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
           0x103caf000 -        0x1040f5ff7 +com.adobe.MPS (AdobeMPS 5.8.0.19463 - 5.8.0.19463) <8A4BA3B2-6F6A-3958-ABDE-C3E8F21373B0> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
           0x104171000 -        0x1044caff7 +com.adobe.AGM (AdobeAGM 4.26.17.19243 - 4.26.17.19243) <E96C804B-158B-D4A2-9A64-482F9ADC29D0> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
           0x104533000 -        0x104894fef +com.adobe.CoolType (AdobeCoolType 5.10.31.19243 - 5.10.31.19243) <8BFF14FB-AA14-1CBF-C2A3-715363B5A841> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeC oolType
           0x1048e1000 -        0x104909ff7 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <9BDD08A8-2DD8-A570-7A7B-EDAA7097D61B> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeB IBUtils
           0x104910000 -        0x10493cfff +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.7.101.18636 - 3.7.101.18636) <488DF1F7-A643-5168-706A-498A0322A87E> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A /AdobeAXE8SharedExpat
           0x10495f000 -        0x104aacff7 +com.winsoft.wrservices (WRServices 5.0.0 - 5.0.0) <FFA48E0A-A17C-A04F-AE20-6815EB944DEA> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/WRServices.framework/Versions/A/WRService s
           0x104b20000 -        0x104b8ffef +com.adobe.AIF (AdobeAIF 3.0.00 - 3.0.00) <924155A9-D00E-B862-C490-5099BA70B978> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/aif_core.framework/Versions/A/aif_core
           0x104bb6000 -        0x104c0ffff +com.adobe.AIF (AdobeAIF 3.0.00 - 3.0.00) <BC353D4E-1AE2-3FB5-D3EE-81A09C0C4328> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/data_flow.framework/Versions/A/data_flow
           0x104caf000 -        0x104d36ff7 +com.adobe.AIF (AdobeAIF 3.0.00 - 3.0.00) <5FCA15B4-F721-09C3-B412-1F86D9D7DE9E> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/image_flow.framework/Versions/A/image_flo w
           0x104d9b000 -        0x104db6ff7 +com.adobe.AIF (AdobeAIF 3.0.00 - 3.0.00) <BB7B342A-8CBC-4B73-58A2-9B062F590EBC> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/image_runtime.framework/Versions/A/image_ runtime
           0x104dd0000 -        0x10500dfff +com.adobe.AIF (AdobeAIF 3.0.00 - 3.0.00) <6839CFB1-74EE-B205-7D82-ABC5428E0810> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/aif_ogl.framework/Versions/A/aif_ogl
           0x10510c000 -        0x105285fff +com.adobe.ACE (AdobeACE 2.19.18.19243 - 2.19.18.19243) <7F28B188-1D1B-20C9-BBB9-B74FCC12ECAD> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
           0x105298000 -        0x1052b7fff +com.adobe.BIB (AdobeBIB 1.2.02.19243 - 1.2.02.19243) <B7D7EE28-D604-2989-B099-62AEF4885C21> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
           0x1052be000 -        0x1053a2fe7 +com.adobe.amtlib (amtlib 6.0.0.75 - 6.0.0.75) <07A3E1E1-55C3-BA5B-A0B0-60250809ED61> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
           0x1053b3000 -        0x105478fff +com.adobe.JP2K (2.0.0 - 2.0.0.18562) <B14B096C-AA23-BA8F-E3AE-8DB102F9D161> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
           0x1054c5000 -        0x1054c9ff7 +com.adobe.ape.shim (3.3.8.19346 - 3.3.8.19346) <13D5CEF7-6090-CD66-8DA0-190771950F76> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
           0x1054cf000 -        0x10554dfff +com.adobe.FileInfo.framework (Adobe XMP FileInfo 5 . 3 . 0 . 0 -i 3 - 66.145433) <5C63613F-6BDE-1C29-D3FD-9D292F9ADB12> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
           0x10555e000 -        0x1055beff7 +com.adobe.AdobeXMPCore (Adobe XMP Core 5.3 -c 11 - 66.145661) <B475CD07-1024-560D-5BFE-2A6FCE63925C> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
           0x1055c8000 -        0x105b20fef +com.nvidia.cg (2.2.0006 - 0) /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/Cg.framework/Cg
           0x10617d000 -        0x1061ebfef +com.adobe.headlights.LogSessionFramework (2.1.2.1652) <25E6F475-1522-419C-2169-547FCF2FD97F> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSessio n
           0x10623f000 -        0x106264ffe +adobepdfsettings (1) <56E7F033-6032-2EC2-250E-43F1EBD123B1> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/adobepdfsettings.framework/Versions/A/ado bepdfsettings
           0x10629f000 -        0x1062a3ff7 +com.adobe.AdobeCrashReporter (6.0 - 6.0.20120201) <A6B1F3BD-5DB0-FEE5-708A-B54E5CA80481> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/A dobeCrashReporter
           0x1062a9000 -        0x106459fef +com.adobe.PlugPlug (3.0.0.383 - 3.0.0.383) <908DBB12-D2AC-1844-BD2A-F1C483424917> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
           0x106510000 -        0x106530fff +com.adobe.AIF (AdobeAIF 3.0.00 - 3.0.00) <DC3301F2-FC6E-70C7-3927-B0DD024210D6> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/aif_ocl.framework/Versions/A/aif_ocl
           0x10654a000 -        0x106607fff +com.adobe.AdobeExtendScript (ExtendScript 4.2.12 - 4.2.12.18602) <0957DFA6-0593-CE4B-8638-00F32113B07B> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/Ad obeExtendScript
           0x106651000 -        0x1066fffef +com.adobe.AdobeScCore (ScCore 4.2.12 - 4.2.12.18602) <9CEE95E5-2FC6-5E58-02A4-138EA6F8D894> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScC ore
           0x10673c000 -        0x106836fe7 +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.7.101.18636 - 3.7.101.18636) <C7652AF2-56D7-8AF8-A207-0BDEDDFF0BEC> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/Adob eAXEDOMCore
           0x1068da000 -        0x106b23fe7 +com.adobe.linguistic.LinguisticManager (6.0.0 - 17206) <301AAE8E-BA78-230E-9500-FCCA204B49CB> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/Adob eLinguistic
           0x106f39000 -        0x106f3bff7  com.apple.textencoding.unicode (2.6 - 2.6) <0EEF0283-1ACA-3147-89B4-B4E014BFEC52> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
           0x106ff7000 -        0x106ff8fff  libCyrillicConverter.dylib (61) <AA2B224F-1A9F-30B9-BE11-633176790A94> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
           0x1096b4000 -        0x1096b4ffb +cl_kernels (???) <44FA342A-212B-47F7-8DC2-205BD90F83F9> cl_kernels
           0x109771000 -        0x10978dfff  libJapaneseConverter.dylib (61) <94EF6A2F-F596-3638-A3DC-CF03567D9427> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
           0x109792000 -        0x1097b3ff7  libKoreanConverter.dylib (61) <22EEBBDB-A2F2-3985-B9C7-53BFE2B02D08> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
           0x1097b8000 -        0x1097c7fff  libSimplifiedChineseConverter.dylib (61) <F5827491-A4E3-3471-A540-8D1FE241FD99> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter. dylib
           0x1097cb000 -        0x1097ddfff  libTraditionalChineseConverter.dylib (61) <A182514D-426F-3D5F-BA69-4C4A4680ECB8> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter .dylib
           0x10ba10000 -        0x10ba56fe7 +com.adobe.pip (6.0.0.1654) <3576D8F9-E2F9-6EB8-6684-C2FE6B0A3731> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
           0x10bb13000 -        0x10bb13fff +Enable Async IO (???) <F56F1FB2-9CF1-19A8-0D14-885A652B19B7> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Extensions/Enable Async IO.plugin/Contents/MacOS/Enable Async IO
           0x10bb17000 -        0x10bb1afff +FastCore (???) <29AAF151-6CC4-28C5-68B8-0F6600A20435> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Extensions/FastCore.plugin/Content s/MacOS/FastCore
           0x10bb20000 -        0x10bb8cfff +MMXCore (???) <B9B6C7FB-CE56-8F6F-664E-DFCBBC5E3ADE> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Extensions/MMXCore.plugin/Contents /MacOS/MMXCore
           0x10bc96000 -        0x10bd1bfff +MultiProcessor Support (???) <467BB668-E9DD-60F4-CAAD-768A98174734> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Extensions/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
           0x10d8c8000 -        0x10d96bff7  ColorSyncDeprecated.dylib (426) <1EBD0729-A174-3EA5-B226-DE63C2E89D14> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated .dylib
           0x119551000 -        0x1195cbfef +com.adobe.adobe_caps (adobe_caps 6.0.29.0 - 6.0.29.0) <C0AD101D-E452-4B4B-5B31-F467133EC20C> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
           0x119800000 -        0x119a5bff7 +com.adobe.PSAutomate (13.0 - 13.0) <6EE89DAF-28E8-B15F-1C4B-18D8D19F6452> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Extensions/ScriptingSupport.plugin /Contents/MacOS/ScriptingSupport
           0x11ab78000 -        0x11ac69fff +com.adobe.AdbeScriptUIFlex (ScriptUIFlex 6.2.29 - 6.2.29.18602) <2BD3388F-976E-0B1C-55DB-B97A5AF95724> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdbeScriptUIFlex.framework/Versions/A/Adb eScriptUIFlex
           0x11aced000 -        0x11ad13ff7 +com.adobe.ape (3.3.8.19346 - 3.3.8.19346) <79E11A18-8AF4-2515-59F7-4CBE161BF020> /Library/Application Support/Adobe/*/adbeapecore.framework/adbeapecore
           0x11ad25000 -        0x11ad30fff  libGPUSupport.dylib (9.0.83) <AF15BF74-F9B3-35B9-8728-3B3A2EB6E432> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Lib raries/libGPUSupport.dylib
           0x11ad59000 -        0x11ad5dffd  com.apple.audio.AppleHDAHALPlugIn (2.5.2 - 2.5.2fc2) <DEB558B7-BACF-3871-A021-B3A904F4FB44> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHAL PlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
           0x11af00000 -        0x11b17bff7  com.apple.RawCamera.bundle (4.09 - 711) <0040632D-09A9-32DE-98E8-BFA99F9F6526> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamer a
           0x11b400000 -        0x11b426ffb  com.apple.cmio.DAL.VDC-4 (401.0 - 4544) <8ABCC14F-8989-3CAA-941A-9EAC16938145> /System/Library/Frameworks/CoreMediaIO.framework/Resources/VDC.plugin /Contents/MacOS/VDC
           0x11c000000 -        0x11c74aff7  libclh.dylib (4.0.3 - 4.0.3) <4A998D5D-A2C8-326F-AD0F-F0E2F60E920A> /System/Library/Extensions/GeForceTeslaGLDriver.bundle/Contents/MacOS /libclh.dylib
           0x11c7ee000 -        0x11d773fd7 +com.adobe.ape.engine (3.3.8.19346 - 3.3.8.19346) <5E188E32-37F7-4E0B-0674-E8D16B60074F> /Library/Application Support/Adobe/*/adbeapecore.framework/Libraries/adbeapeengine.bundle/ Contents/MacOS/adbeapeengine
           0x11dd08000 -        0x11dd4efff +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 6.0.0.24 - 6.0.0.24) <58C40EB9-2F38-2479-E710-344CAB0CEFB7> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/updaternotifications.framework/Versions/A /UpdaterNotifications
           0x11dd68000 -        0x11dd93fff +ServiceManager-Launcher.dylib (389) <7AE35754-3413-206D-4B92-579AAA25B4F8> /Library/Application Support/Adobe/*/ServiceManager-Launcher.dylib
           0x11deb1000 -        0x11df97fef  unorm8_bgra.dylib (2.3.58) <9FF943D1-4EF7-36CA-852D-B61C2E554713> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/Imag eFormats/unorm8_bgra.dylib
           0x11e0fc000 -        0x11e0fcff9 +cl_kernels (???) <65A2087E-010B-47A8-9436-573078BC513F> cl_kernels
           0x11f56e000 -        0x11f56fffa +cl_kernels (???) <B265D20A-1FD9-48D4-99D8-CC30F8A42435> cl_kernels
           0x138866000 -        0x13886aff7  libgermantok.dylib (14) <33B11365-E59E-38C1-952E-AFFFEFEE427F> /usr/lib/libgermantok.dylib
           0x140f37000 -        0x140f39ffa +cl_kernels (???) <D5A9D41D-19E7-49A4-9026-B13AC02FCA13> cl_kernels
           0x168991000 -        0x168a41fe7 + (???) <3DC0B893-3983-14AD-9701-295239CCFAA5>
           0x18b813000 -        0x18b813ffd +cl_kernels (???) <06380D9F-9240-424B-9446-25D090E588AC> cl_kernels
           0x18b892000 -        0x18b894ff8 +cl_kernels (???) <93A726EB-6004-4798-A001-8E32D6DAC81F> cl_kernels
           0x19a60d000 -        0x19a60eff4 +cl_kernels (???) <E653D8D5-03FD-4D78-A216-B3A0845207F6> cl_kernels
           0x1a3fd9000 -        0x1a40b9ff7  unorm8_rgba.dylib (2.3.58) <DDD1AFEB-FD30-34D2-958A-823C3EFD649A> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/Imag eFormats/unorm8_rgba.dylib
        0x123440000000 -     0x123440867ff7  com.apple.GeForceTeslaGLDriver (8.18.27 - 8.1.8) <5B0E2B4A-D4E6-3C65-A8D5-87F24E79D432> /System/Library/Extensions/GeForceTeslaGLDriver.bundle/Contents/MacOS /GeForceTeslaGLDriver
        0x7fff69eb2000 -     0x7fff69ee5817  dyld (239.3) <D1DFCF3F-0B0C-332A-BCC0-87A851B570FF> /usr/lib/dyld
        0x7fff8a431000 -     0x7fff8a435ff7  libGIF.dylib (1038) <C29B4323-1B9E-36B9-96C2-7CEDBAA124F0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/lib GIF.dylib
        0x7fff8a437000 -     0x7fff8a698ff7  com.apple.imageKit (2.5 - 770) <33BCF627-EB1A-3CC1-98AB-2324B6DFB329> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Ima geKit.framework/Versions/A/ImageKit
        0x7fff8a699000 -     0x7fff8a69efff  com.apple.DiskArbitration (2.6 - 2.6) <F8A47F61-83D1-3F92-B7A8-A169E0D187C0> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskA rbitration
        0x7fff8a69f000 -     0x7fff8a6c9ff7  libpcap.A.dylib (42) <91D3FF51-D6FE-3C05-98C9-1182E0EC3D58> /usr/lib/libpcap.A.dylib
        0x7fff8a6ca000 -     0x7fff8a71cff7  com.apple.Suggestions (3.0 - 137.1) <B7E5B685-C6A4-35DB-BA0A-8DBA2BF4ADF6> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Su ggestions
        0x7fff8a71d000 -     0x7fff8a71dfff  com.apple.quartzframework (1.5 - 1.5) <3B2A72DB-39FC-3C5B-98BE-605F37777F37> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
        0x7fff8a72b000 -     0x7fff8a734ff7  libcldcpuengine.dylib (2.3.58) <A2E1ED7B-FC7E-31F6-830A-FF917689766B> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libc ldcpuengine.dylib
        0x7fff8a735000 -     0x7fff8a786ff3  com.apple.audio.CoreAudio (4.2.0 - 4.2.0) <BF4C2FE3-8BC8-30D1-8347-2A7221268794> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
        0x7fff8a787000 -     0x7fff8a78dff7  libsystem_platform.dylib (24.1.4) <331BA4A5-55CE-3B95-99EB-44E0C89D7FB8> /usr/lib/system/libsystem_platform.dylib
        0x7fff8a78e000 -     0x7fff8a7b2ff7  libJPEG.dylib (1038) <86F349A8-882D-3326-A0B0-63257F68B1A7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/lib JPEG.dylib
        0x7fff8a7b3000 -     0x7fff8a7bbff3  libCGCMS.A.dylib (599.7) <92AA4E85-7633-36E2-BAD0-7B1A2E48E75C> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resource s/libCGCMS.A.dylib
        0x7fff8a7bc000 -     0x7fff8a7cdff7  libsystem_asl.dylib (217.1.4) <655FB343-52CF-3E2F-B14D-BEBF5AAEF94D> /usr/lib/system/libsystem_asl.dylib
        0x7fff8a7ce000 -     0x7fff8a7d0ff7  libquarantine.dylib (71) <7A1A2BCB-C03D-3A25-BFA4-3E569B2D2C38> /usr/lib/system/libquarantine.dylib
        0x7fff8a7d1000 -     0x7fff8a7d7fff  com.apple.AOSNotification (1.7.0 - 760.3) <7901B867-60F7-3645-BB3E-18C51A6FBCC6> /System/Library/PrivateFrameworks/AOSNotification.framework/Versions/ A/AOSNotification
        0x7fff8a80a000 -     0x7fff8a813fff  com.apple.speech.synthesis.framework (4.6.2 - 4.6.2) <0AAE45F0-FC6E-36B6-A6A7-73E6950A74AC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
        0x7fff8a82d000 -     0x7fff8a85cfff  com.apple.DebugSymbols (106 - 106) <E1BDED08-523A-36F4-B2DA-9D5C712F0AC7> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/D ebugSymbols
        0x7fff8a874000 -     0x7fff8a87cff7  com.apple.speech.recognition.framework (4.2.4 - 4.2.4) <98BBB3E4-6239-3EF1-90B2-84EA0D3B8D61> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Spe echRecognition.framework/Versions/A/SpeechRecognition
        0x7fff8a87d000 -     0x7fff8a8cbff9  libstdc++.6.dylib (60) <0241E6A4-1368-33BE-950B-D0A175C41F54> /usr/lib/libstdc++.6.dylib
        0x7fff8a8cc000 -     0x7fff8a8f6ff7  libsandbox.1.dylib (278.10) <B4183FA8-F7E2-3301-8BF9-0EEFB793A5D5> /usr/lib/libsandbox.1.dylib
        0x7fff8a8f7000 -     0x7fff8a8f9fff  com.apple.EFILogin (2.0 - 2) <C360E8AF-E9BB-3BBA-9DF0-57A92CEF00D4> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILo gin
        0x7fff8a8fa000 -     0x7fff8ac70ffa  com.apple.JavaScriptCore (9537 - 9537.65) <7E76880C-832E-385B-9591-ACCF57A68385> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaSc riptCore
        0x7fff8ac71000 -     0x7fff8ace0ff1  com.apple.ApplicationServices.ATS (360 - 363.1) <88976B22-A9B8-3E7B-9AE6-0B8E09A968FC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/ATS
        0x7fff8ace1000 -     0x7fff8acfbfff  libdispatch.dylib (339.1.9) <46878A5B-4248-3057-962C-6D4A235EEF31> /usr/lib/system/libdispatch.dylib
        0x7fff8acfc000 -     0x7fff8ae3cfff  com.apple.QTKit (7.7.3 - 2826) <7A110F61-D4DD-3C84-950D-E5F486DE5765> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
        0x7fff8ae3d000 -     0x7fff8ae64ff7  com.apple.shortcut (2.6 - 2.6) <A62BC973-6782-3893-B014-EC6503AB7EAD> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Short cut
        0x7fff8ae65000 -     0x7fff8ae89fff  com.apple.quartzfilters (1.8.0 - 1.7.0) <39C08086-9866-372F-9420-81F5689149DF> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qua rtzFilters.framework/Versions/A/QuartzFilters
        0x7fff8ae8a000 -     0x7fff8af0afff  com.apple.CoreSymbolication (3.0 - 141) <B018335C-698B-3F87-AF1C-6115C4FA8954> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Version s/A/CoreSymbolication
        0x7fff8af0b000 -     0x7fff8afa8fff  com.apple.imcore (10.0 - 1000) <027E09B4-B4B6-3710-8806-B4CE41DF3242> /System/Library/PrivateFrameworks/IMCore.framework/Versions/A/IMCore
        0x7fff8afda000 -     0x7fff8b167ff7  GLEngine (9.0.83) <26CCE609-D645-3945-A678-517ED5B65785> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEn gine.bundle/GLEngine
        0x7fff8b168000 -     0x7fff8b17afff  com.apple.ImageCapture (9.0 - 9.0) <BE0B65DA-3031-359B-8BBA-B9803D4ADBF4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ima geCapture.framework/Versions/A/ImageCapture
        0x7fff8b17b000 -     0x7fff8b188ff4  com.apple.Librarian (1.2 - 1) <F1A2744D-8536-32C7-8218-9972C6300DAE> /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Libr arian
        0x7fff8b189000 -     0x7fff8b18cff7  com.apple.LoginUICore (3.0 - 3.0) <1ECBDA90-D6ED-3333-83EB-9C8232DFAD7C> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Fra meworks/LoginUICore.framework/Versions/A/LoginUICore
        0x7fff8b18d000 -     0x7fff8b198fff  libkxld.dylib (2422.1.72) <C88EF3E6-B31F-3E12-BE9B-562D912BA733> /usr/lib/system/libkxld.dylib
        0x7fff8b199000 -     0x7fff8b19efff  libmacho.dylib (845) <1D2910DF-C036-3A82-A3FD-44FF73B5FF9B> /usr/lib/system/libmacho.dylib
        0x7fff8b249000 -     0x7fff8b39cff7  com.apple.audio.toolbox.AudioToolbox (1.9 - 1.9) <A0B7B007-9BD8-30E2-B644-47856DA29FEE> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToo lbox
        0x7fff8b39d000 -     0x7fff8b6f8fff  com.apple.FinderKit (1.2 - 1.2) <B4B8F675-2F04-39BB-8B3C-A1E400DFDFD5> /System/Library/PrivateFrameworks/FinderKit.framework/Versions/A/Find erKit
        0x7fff8b6f9000 -     0x7fff8b74afff  com.apple.QuickLookFramework (5.0 - 622.3) <AB6CCD09-ECDF-3F01-9C42-34B37DDCF12D> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
        0x7fff8b74b000 -     0x7fff8b763ff7  com.apple.GenerationalStorage (2.0 - 160.2) <79629AC7-896F-3302-8AC1-4939020F08C3> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versi ons/A/GenerationalStorage
        0x7fff8b773000 -     0x7fff8ba47fc7  com.apple.vImage (7.0 - 7.0) <D241DBFA-AC49-31E2-893D-EAAC31890C90> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vImage.framework/Versions/A/vImage
        0x7fff8baa0000 -     0x7fff8bac7ff7  libsystem_network.dylib (241.3) <8B1E1F1D-A5CC-3BAE-8B1E-ABC84337A364> /usr/lib/system/libsystem_network.dylib
        0x7fff8bcda000 -     0x7fff8bd1fff6  com.apple.HIServices (1.22 - 466) <21807AF8-3BC7-32BB-AB96-7C35CB59D7F6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/HIServices.framework/Versions/A/HIServices
        0x7fff8bd20000 -     0x7fff8bd2cff3  com.apple.AppleFSCompression (56 - 1.0) <5652B0D0-EB08-381F-B23A-6DCF96991FB5> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versio ns/A/AppleFSCompression
        0x7fff8bd2f000 -     0x7fff8bd58ff7  libc++abi.dylib (48) <8C16158F-CBF8-3BD7-BEF4-022704B2A326> /usr/lib/libc++abi.dylib
        0x7fff8bd59000 -     0x7fff8bdb1ff7  com.apple.Symbolication (1.4 - 129) <16D42516-7B5E-357C-898A-FAA9EE7642B3> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/ Symbolication
        0x7fff8bdb2000 -     0x7fff8bdb6fff  libpam.2.dylib (20) <B93CE8F5-DAA8-30A1-B1F6-F890509513CB> /usr/lib/libpam.2.dylib
        0x7fff8be01000 -     0x7fff8be0bfff  com.apple.AppSandbox (3.0 - 1) <55717299-8164-3D79-918F-BD64706735CF> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/App Sandbox
        0x7fff8be0c000 -     0x7fff8be12ff7  libCGXCoreImage.A.dylib (599.7) <AC38090E-BA96-33C0-92F3-8EF6231582C4> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resource s/libCGXCoreImage.A.dylib
        0x7fff8befb000 -     0x7fff8c81705f  com.apple.CoreGraphics (1.600.0 - 599.7) <7D0FD5A7-A061-39BA-8E00-723825D2C4DD> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGrap hics
        0x7fff8c818000 -     0x7fff8c850ff7  com.apple.RemoteViewServices (2.0 - 94) <3F34D630-3DDB-3411-BC28-A56A9B55EBDA> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versio ns/A/RemoteViewServices
        0x7fff8c851000 -     0x7fff8c868ffa  libAVFAudio.dylib (32.2) <52DA516B-DE79-322C-9E1B-2658019289D7> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resource s/libAVFAudio.dylib
        0x7fff8c869000 -     0x7fff8c958fff  libFontParser.dylib (111.1) <835A8253-6AB9-3AAB-9CBF-171440DEC486> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
        0x7fff8c959000 -     0x7fff8c95bff7  com.apple.diagnosticlogcollection (10.0 - 1000) <5CA6D8A2-DEA6-33C3-91BC-F3B076C0500B> /System/Library/PrivateFrameworks/DiagnosticLogCollection.framework/V ersions/A/DiagnosticLogCollection
        0x7fff8d0ac000 -     0x7fff8d0dbff7  com.apple.CoreAVCHD (5.7.0 - 5700.4.3) <404369C0-ED9F-3010-8D2F-BC55285F7808> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/Core AVCHD
        0x7fff8d0dc000 -     0x7fff8d0e4fff  libMatch.1.dylib (19) <021293AB-407D-309A-87F5-8E782F46753E> /usr/lib/libMatch.1.dylib
        0x7fff8d0e5000 -     0x7fff8d1c4fff  libcrypto.0.9.8.dylib (50) <B95B9DBA-39D3-3EEF-AF43-44608B28894E> /usr/lib/libcrypto.0.9.8.dylib
        0x7fff8d1c5000 -     0x7fff8d1d2ff0  libbz2.1.0.dylib (29) <0B98AC35-B138-349C-8063-2B987A75D24C> /usr/lib/libbz2.1.0.dylib
        0x7fff8d1d3000 -     0x7fff8d1deff7  com.apple.NetAuth (5.0 - 5.0) <C811E662-9EC3-3B74-808A-A75D624F326B> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAut h
        0x7fff8d1ee000 -     0x7fff8d23affe  com.apple.CoreMediaIO (401.0 - 4544) <44EBC0FE-DAD5-3711-96CB-05250F350A16> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMedia IO
        0x7fff8d23b000 -     0x7fff8d24ffff  com.apple.aps.framework (4.0 - 4.0) <F529A05B-FB03-397E-B06A-3A60B808FA11> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions /A/ApplePushService
        0x7fff8d751000 -     0x7fff8d764ff7  com.apple.AppContainer (3.0 - 1) <A90C058D-46E8-3BAB-AF17-AF9C7C273069> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/A ppContainer
        0x7fff8d7dd000 -     0x7fff8da87ffd  com.apple.HIToolbox (2.1 - 695) <C4DE35FF-D0AC-35C3-A7E6-F54CD153825C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIT oolbox.framework/Versions/A/HIToolbox
        0x7fff8da88000 -     0x7fff8da88fff  com.apple.ApplicationServices (48 - 48) <3E3F01A8-314D-378F-835E-9CC4F8820031> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/A pplicationServices
        0x7fff8daab000 -     0x7fff8dab5ff7  libcsfde.dylib (380) <3A54B430-EC05-3DE9-86C3-00C1BEAC7F9B> /usr/lib/libcsfde.dylib
        0x7fff8dad5000 -     0x7fff8daebfff  com.apple.CoreMediaAuthoring (2.2 - 947) <B01FBACC-DDD5-30A8-BCCF-57CE24ABA329> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versio ns/A/CoreMediaAuthoring
        0x7fff8db35000 -     0x7fff8db37fff  libRadiance.dylib (1038) <55F99274-5074-3C73-BAC5-AF234E71CF38> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/lib Radiance.dylib
        0x7fff8db38000 -     0x7fff8db44ff7  com.apple.HelpData (2.1.4 - 90) <BEA1C549-40D3-35BF-9204-CB679FCB0648> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpD ata
        0x7fff8db45000 -     0x7fff8db46fff  com.apple.AddressBook.ContactsData (8.0 - 1365) <61090508-4CC3-3F57-9B0C-D8527947D35D> /System/Library/PrivateFrameworks/ContactsData.framework/Versions/A/C ontactsData
        0x7fff8db4d000 -     0x7fff8db4eff7  libDiagnosticMessagesClient.dylib (100) <4CDB0F7B-C0AF-3424-BC39-495696F0DB1E> /usr/lib/libDiagnosticMessagesClient.dylib
        0x7fff8db4f000 -     0x7fff8db52fff  com.apple.help (1.3.3 - 46) <AE763646-D07A-3F9A-ACD4-F5CBD734EE36> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Hel p.framework/Versions/A/Help
        0x7fff8db53000 -     0x7fff8de21ff4  com.apple.CoreImage (9.0.54) <74BB8685-69A9-3A45-8DED-EA26BD39D710> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks /CoreImage.framework/Versions/A/CoreImage
        0x7fff8de22000 -     0x7fff8de79fff  com.apple.ViewBridge (1.0 - 46) <C49FDC96-7087-3B2F-AEC3-039F7B2CB50C> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/Vie wBridge
        0x7fff8dff1000 -     0x7fff8e01afff  GLRendererFloat (9.0.83) <1F1160A8-5047-3CEE-AC1E-D29520D0B367> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRe ndererFloat.bundle/GLRendererFloat
        0x7fff8e066000 -     0x7fff8e070fff  libcommonCrypto.dylib (60049) <8C4F0CA0-389C-3EDC-B155-E62DD2187E1D> /usr/lib/system/libcommonCrypto.dylib
        0x7fff8e071000 -     0x7fff8e0adfff  com.apple.ids (10.0 - 1000) <22502AAF-CC59-33EC-9ACF-106315206701> /System/Library/PrivateFrameworks/IDS.framework/Versions/A/IDS
        0x7fff8e14e000 -     0x7fff8e14eff7  libkeymgr.dylib (28) <3AA8D85D-CF00-3BD3-A5A0-E28E1A32A6D8> /usr/lib/system/libkeymgr.dylib
        0x7fff8e14f000 -     0x7fff8e16bfff  com.apple.frameworks.preferencepanes (16.0 - 16.0) <059E99D8-67C2-3B59-B5E7-850DD7A92D75> /System/Library/Frameworks/PreferencePanes.framework/Versions/A/Prefe rencePanes
        0x7fff8e16c000 -     0x7fff8e177ff7  com.apple.DirectoryService.Framework (10.9 - 173.1.1) <F8566D1F-450F-3571-911F-75C68E45919F> /System/Library/Frameworks/DirectoryService.framework/Versions/A/Dire ctoryService
        0x7fff8e178000 -     0x7fff8e1cbfff  com.apple.ScalableUserInterface (1.0 - 1) <CF745298-7373-38D2-B3B1-727D5A569E48> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks /ScalableUserInterface.framework/Versions/A/ScalableUserInterface
        0x7fff8e1cc000 -     0x7fff8e4e6ff7  com.apple.MediaToolbox (1.0 - 1273.29) <6260E68B-7E50-3D49-8C0A-7145614C13D8> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToo lbox
        0x7fff8e50e000 -     0x7fff8e52bff7  com.apple.framework.Apple80211 (9.0 - 900.47) <C897AFE6-DD73-387D-816A-67252A564207> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/App le80211
        0x7fff8e52c000 -     0x7fff8e579ff2  com.apple.print.framework.PrintCore (9.0 - 428) <8D8253E3-302F-3DB2-9C5C-572CB974E8B3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/PrintCore.framework/Versions/A/PrintCore
        0x7fff8e57a000 -     0x7fff8e643fff  com.apple.LaunchServices (572.23 - 572.23) <8D955BDE-2C4C-3DD4-B4D7-2D916174FE1D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/LaunchServices.framework/Versions/A/LaunchServices
        0x7fff8e644000 -     0x7fff8e645fff  liblangid.dylib (117) <9546E641-F730-3AB0-B3CD-E0E2FDD173D9> /usr/lib/liblangid.dylib
        0x7fff8e646000 -     0x7fff8e65fff7  com.apple.Kerberos (3.0 - 1) <F108AFEB-198A-3BAF-BCA5-9DFCE55EFF92> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
        0x7fff8e661000 -     0x7fff8e7fdff7  com.apple.QuartzCore (1.8 - 332.0) <994D1E0A-64B6-398C-B9A2-C362F02DE943> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
        0x7fff8e7fe000 -     0x7fff8e871ffb  com.apple.securityfoundation (6.0 - 55122) <119D1C53-B292-3378-AEE1-A3B1FB02F43F> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/Se curityFoundation
        0x7fff8e872000 -     0x7fff8e994ff1  com.apple.avfoundation (2.0 - 651.12) <03E595B7-A559-3D4D-90E9-BCA603E3A39E> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFounda tion
        0x7fff8e995000 -     0x7fff8eac5ff7  com.apple.desktopservices (1.8 - 1.8) <09DC9BB8-432F-3C7A-BB08-956A2DDFC2DE> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versi ons/A/DesktopServicesPriv
        0x7fff8eac6000 -     0x7fff8ecabff7  com.apple.CoreFoundation (6.9 - 855.11) <E22C6A1F-8996-349C-905E-96C3BBE07C2F> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFo undation
        0x7fff8ecac000 -     0x7fff8ecc7ff7  libsystem_malloc.dylib (23.1.10) <FFE5C472-B23A-318A-85BF-77CDE61900D1> /usr/lib/system/libsystem_malloc.dylib
        0x7fff8ecc8000 -     0x7fff8ed01ff7  com.apple.QD (3.50 - 298) <C1F20764-DEF0-34CF-B3AB-AB5480D64E66> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/QD.framework/Versions/A/QD
        0x7fff8ed02000 -     0x7fff8ed04fff  libCVMSPluginSupport.dylib (9.0.83) <E2AED858-6EEB-36C6-8C06-C3CF649A3CD5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC VMSPluginSupport.dylib
        0x7fff8ed05000 -     0x7fff8ed72fff  com.apple.SearchKit (1.4.0 - 1.4.0) <B9B8D510-A27E-36B0-93E9-17146D9E9045> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/SearchKit.framework/Versions/A/SearchKit
        0x7fff8ed73000 -     0x7fff8edc2ff7  com.apple.framework.internetaccounts (2.1 - 210) <C77069C7-928C-315C-AA61-D90543901F20> /System/Library/PrivateFrameworks/InternetAccounts.framework/Versions /A/InternetAccounts
        0x7fff8edd6000 -     0x7fff8ede7ff7  libz.1.dylib (53) <42E0C8C6-CA38-3CA4-8619-D24ED5DD492E> /usr/lib/libz.1.dylib
        0x7fff8ede8000 -     0x7fff8ee16ff7  com.apple.securityinterface (9.0 - 55047) <0346D8A9-2CAA-38F3-A741-5FBA5E9F1E7C> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/Sec urityInterface
        0x7fff8ee2b000 -     0x7fff8ee54fff  com.apple.DictionaryServices (1.2 - 208) <A539A058-BA57-35EE-AA08-D0B0E835127D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/DictionaryServices.framework/Versions/A/DictionaryServices
        0x7fff8ee55000 -     0x7fff8ee5cff7  libsystem_pthread.dylib (53.1.4) <AB498556-B555-310E-9041-F67EC9E00E2C> /usr/lib/system/libsystem_pthread.dylib
        0x7fff8ee5d000 -     0x7fff8ee78ff7  libPng.dylib (1038) <EF781AF8-C2E6-3179-B8A1-A584783070F1> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/lib Png.dylib
        0x7fff8ee79000 -     0x7fff8f163fff  com.apple.CoreServices.CarbonCore (1077.13 - 1077.13) <21324540-8B84-3333-ADB8-D3D5181D4639> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CarbonCore.framework/Versions/A/CarbonCore
        0x7fff8f164000 -     0x7fff8f290fff  com.apple.MediaControlSender (1.9 - 190.4) <F5E934E1-D004-3C84-815A-961319F8C522> /System/Library/PrivateFrameworks/MediaControlSender.framework/Versio ns/A/MediaControlSender
        0x7fff8f291000 -     0x7fff8f292ff7  libodfde.dylib (20) <C00A4EBA-44BC-3C53-BFD0-819B03FFD462> /usr/lib/libodfde.dylib
        0x7fff8f301000 -     0x7fff8f38aff7  libsystem_c.dylib (997.1.1) <61833FAA-7281-3FF9-937F-686B6F20427C> /usr/lib/system/libsystem_c.dylib
        0x7fff8fc4f000 -     0x7fff8fc80fff  com.apple.MediaKit (15 - 709) <23E33409-5C39-3F93-9E73-2B0E9EE8883E> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/Media Kit
        0x7fff8fc95000 -     0x7fff8fd7cff7  libxml2.2.dylib (26) <A1DADD11-89E5-3DE4-8802-07186225967F> /usr/lib/libxml2.2.dylib
        0x7fff8fd97000 -     0x7fff8fde0fff  com.apple.CoreMedia (1.0 - 1273.29) <4ACD30BA-E9FE-3842-A8B7-E3BD63747867> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
        0x7fff8fde1000 -     0x7fff8fdf9ff7  com.apple.openscripting (1.4 - 157) <B3B037D7-1019-31E6-9D17-08E699AF3701> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ope nScripting.framework/Versions/A/OpenScripting
        0x7fff8fdfa000 -     0x7fff8fe55ffb  com.apple.AE (665.5 - 665.5) <BBA230F9-144C-3CAB-A77A-0621719244CD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/AE.framework/Versions/A/AE
        0x7fff8fe56000 -     0x7fff8fe5ffff  com.apple.DisplayServicesFW (2.8 - 360.8.14) <816A9CED-1BC0-3C76-8103-1B9BE0F723BB> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/ A/DisplayServices
        0x7fff8fe6b000 -     0x7fff8fe92ffb  libsystem_info.dylib (449.1.3) <7D41A156-D285-3849-A2C3-C04ADE797D98> /usr/lib/system/libsystem_info.dylib
        0x7fff8fe93000 -     0x7fff8fea1fff  com.apple.opengl (9.0.83 - 9.0.83) <AF467644-7B1D-327A-AC47-CECFCAF61990> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
        0x7fff8fea4000 -     0x7fff8fea6fff  com.apple.marco (10.0 - 1000) <FC7EF8C7-5EDF-3720-BAEC-281F12A7A3F8> /System/Library/PrivateFrameworks/Marco.framework/Versions/A/Marco
        0x7fff8fea7000 -     0x7fff8fea7fff  com.apple.Accelerate (1.9 - Accelerate 1.9) <509BB27A-AE62-366D-86D8-0B06D217CF56> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
        0x7fff8febe000 -     0x7fff8fec3ff7  libunwind.dylib (35.3) <78DCC358-2FC1-302E-B395-0155B47CB547> /usr/lib/system/libunwind.dylib
        0x7fff8ff57000 -     0x7fff8ff57fff  com.apple.CoreServices (59 - 59) <7A697B5E-F179-30DF-93F2-8B503CEEEFD5> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServ ices
        0x7fff8ff58000 -     0x7fff8ff74ff7  libsystem_kernel.dylib (2422.1.72) <D14913DB-47F1-3591-8DAF-D4B4EF5F8818> /usr/lib/system/libsystem_kernel.dylib
        0x7fff8ff99000 -     0x7fff8ffd7ff7  libGLImage.dylib (9.0.83) <C08048A7-03CC-3E40-BCDC-7791D87AC8E4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LImage.dylib
        0x7fff8ffd8000 -     0x7fff90019fff  com.apple.PerformanceAnalysis (1.47 - 47) <784ED7B8-FAE4-36CE-8C76-B7D300316C9F> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versi ons/A/PerformanceAnalysis
        0x7fff90045000 -     0x7fff90116ff7  com.apple.QuickLookUIFramework (5.0 - 622.3) <9741E66B-3978-35F6-8846-B6C528945611> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qui ckLookUI.framework/Versions/A/QuickLookUI
        0x7fff90117000 -     0x7fff90124fff  com.apple.Sharing (132.2 - 132.2) <F983394A-226D-3244-B511-FA51FDB6ADDA> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharin g
        0x7fff90125000 -     0x7fff90152ff2  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <43A137C4-3E72-37DC-945F-92569C12AAD4> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/Cor eDaemon
        0x7fff90153000 -     0x7fff901a1fff  libcorecrypto.dylib (161.1) <F3973C28-14B6-3006-BB2B-00DD7F09ABC7> /usr/lib/system/libcorecrypto.dylib
        0x7fff901a2000 -     0x7fff901a3ff7  libsystem_blocks.dylib (63) <FB856CD1-2AEA-3907-8E9B-1E54B6827F82> /usr/lib/system/libsystem_blocks.dylib
        0x7fff901a4000 -     0x7fff9025cff7  com.apple.DiscRecording (8.0 - 8000.4.6) <CDAAAD04-A1D0-3C67-ABCC-EFC9E8D44E7E> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRec ording
        0x7fff905f6000 -     0x7fff90635fff  libGLU.dylib (9.0.83) <8B457205-513B-3477-AE9C-3AD979D5FE11> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LU.dylib
        0x7fff90636000 -     0x7fff9064dfff  com.apple.CFOpenDirectory (10.9 - 173.1.1) <3FB4D5FE-860B-3BDE-BAE2-3531D919EF10> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Framewo rks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
        0x7fff9064e000 -     0x7fff9067fff7  libtidy.A.dylib (15.12) <BF757E3C-733A-3B6B-809A-A3949D46466E> /usr/lib/libtidy.A.dylib
        0x7fff906b5000 -     0x7fff90946ff7  com.apple.AOSKit (1.06 - 176) <35525B2F-B02F-31FD-A3B2-FD6AE6D32C11> /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/AOSKit
        0x7fff90947000 -     0x7fff90a18ff1  com.apple.DiskImagesFramework (10.9 - 371.1) <D456ED08-4C1D-341F-BAB8-85E34A7275C5> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/Dis kImages
        0x7fff90a6f000 -     0x7fff90a73fff  libsystem_stats.dylib (93.1.26) <B9E26A9E-FBBC-3938-B8B7-6CF7CA8C99AD> /usr/lib/system/libsystem_stats.dylib
        0x7fff90b29000 -     0x7fff90c2efff  com.apple.ImageIO.framework (3.3.0 - 1038) <2C058216-C6D8-3380-A7EA-92A3F04520C1> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
        0x7fff90c2f000 -     0x7fff90c8fff2  com.apple.CoreUtils (1.9 - 190.4) <CBB5B4DC-2801-32B3-A31C-8811CCF99873> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/Core Utils
        0x7fff90c90000 -     0x7fff90c99ffb  libCGInterfaces.dylib (271) <68EFBEFE-7506-3235-99A2-5B69EDBFD7B8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vImage.framework/Versions/A/Resources/libCGInterfaces.dylib
        0x7fff90c9a000 -     0x7fff90e0aff6  com.apple.CFNetwork (673.0.3 - 673.0.3) <42CFC3DB-35C8-3652-AF37-4BCC73D8BDEF> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
        0x7fff90e0b000 -     0x7fff90e1cff7  com.apple.idsfoundation (10.0 - 1000) <0BC25100-092B-3C5A-8245-F7C963380785> /System/Library/PrivateFrameworks/IDSFoundation.framework/Versions/A/ IDSFoundation
        0x7fff90e1d000 -     0x7fff91250ffb  com.apple.vision.FaceCore (3.0.0 - 3.0.0) <F42BFC9C-0B16-35EF-9A07-91B7FDAB7FC5> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceC ore
        0x7fff91251000 -     0x7fff9126aff7  com.apple.Ubiquity (1.3 - 289) <C7F1B734-CE81-334D-BE41-8B20D95A1F9B> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiqu ity
        0x7fff9126b000 -     0x7fff91423ff3  libicucore.A.dylib (511.25) <3ED7B656-416E-3071-AEC8-E85C90232F78> /usr/lib/libicucore.A.dylib
        0x7fff91424000 -     0x7fff91440fff  libresolv.9.dylib (54) <11C2C826-F1C6-39C6-B4E8-6E0C41D4FA95> /usr/lib/libresolv.9.dylib
        0x7fff9145d000 -     0x7fff916a0fff  com.apple.AddressBook.framework (8.0 - 1365) <816242B1-D45E-3B5D-BC98-BB23458D5367> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBo ok
        0x7fff916a1000 -     0x7fff916a2fff  libunc.dylib (28) <62682455-1862-36FE-8A04-7A6B91256438> /usr/lib/system/libunc.dylib
        0x7fff916a3000 -     0x7fff916d3fff  com.apple.IconServices (25 - 25.17) <4751127E-FBD5-3ED5-8510-08D4E4166EFE> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/I conServices
        0x7fff916d4000 -     0x7fff916d5ffb  libremovefile.dylib (33) <3543F917-928E-3DB2-A2F4-7AB73B4970EF> /usr/lib/system/libremovefile.dylib
        0x7fff916d6000 -     0x7fff916dfff3  libsystem_notify.dylib (121) <52571EC3-6894-37E4-946E-064B021ED44E> /usr/lib/system/libsystem_notify.dylib
        0x7fff916e0000 -     0x7fff916e2fff  com.apple.Mangrove (1.0 - 1) <72F5CBC7-4E78-374E-98EA-C3700136904E> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangr ove
        0x7fff916e3000 -     0x7fff916e6fff  com.apple.AppleSystemInfo (3.0 - 3.0) <4D032152-AA40-350E-BB96-44BC55C5C69C> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/ A/AppleSystemInfo
        0x7fff916e7000 -     0x7fff916efff7  com.apple.AppleSRP (5.0 - 1) <ABC7F088-1FD5-3768-B9F3-847F355E90B3> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/Apple SRP
        0x7fff916f0000 -     0x7fff91700fff  libbsm.0.dylib (33) <2CAC00A2-1352-302A-88FA-C567D4D69179> /usr/lib/libbsm.0.dylib
        0x7fff91701000 -     0x7fff91702ff7  libsystem_sandbox.dylib (278.10) <A47E7E11-3C76-318E-B67D-98972B86F094> /usr/lib/system/libsystem_sandbox.dylib
        0x7fff91703000 -     0x7fff917bcfff  libcrypto.0.9.7.dylib (106) <BFE87BFA-7971-37DC-9B20-55F04E509A80> /usr/lib/libcrypto.0.9.7.dylib
        0x7fff917bd000 -     0x7fff917e2ff7  com.apple.CoreVideo (1.8 - 117.2) <4674339E-26D0-35FA-9958-422832B39B12> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
        0x7fff917e3000 -     0x7fff917e3fff  com.apple.Carbon (154 - 157) <45A9A40A-78FF-3EA0-8FAB-A4F81052FA55> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
        0x7fff9181e000 -     0x7fff9184afff  com.apple.CoreServicesInternal (184.8 - 184.8) <707E05AE-DDA8-36FD-B0FF-7F15A061B46A> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Vers ions/A/CoreServicesInternal
        0x7fff9184b000 -     0x7fff91857ff7  com.apple.OpenDirectory (10.9 - 173.1.1) <6B78BD7B-5622-38E6-8FC6-86A117E3ACCA> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDir ectory
        0x7fff91858000 -     0x7fff918c2ff7  com.apple.framework.IOKit (2.0.1 - 907.1.13) <C1E95F5C-B79B-31BE-9F2A-1B25163C1F16> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
        0x7fff918d2000 -     0x7fff91982ff7  libvMisc.dylib (423.32) <049C0735-1808-39B9-943F-76CB8021744F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvMisc.dylib
        0x7fff91983000 -     0x7fff919b2fd2  libsystem_m.dylib (3047.16) <B7F0E2E4-2777-33FC-A787-D6430B630D54> /usr/lib/system/libsystem_m.dylib
        0x7fff919b3000 -     0x7fff919b5ffb  libutil.dylib (34) <DAC4A6CF-A1BB-3874-9569-A919316D30E8> /usr/lib/libutil.dylib
        0x7fff919b6000 -     0x7fff91cb5fff  com.apple.Foundation (6.9 - 1056) <D608EDFD-9634-3573-9B7E-081C7D085F7A> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
        0x7fff91cb6000 -     0x7fff91cd3fff  com.apple.facetimeservices (10.0 - 1000) <9B4815BA-4305-381D-A178-F79E10B2C6E9> /System/Library/PrivateFrameworks/FTServices.framework/Versions/A/FTS ervices
        0x7fff91cd4000 -     0x7fff91f2cff1  com.apple.security (7.0 - 55471) <233831C5-C457-3AD5-AFE7-E3E2DE6929C9> /System/Library/Frameworks/Security.framework/Versions/A/Security
        0x7fff91f68000 -     0x7fff91fccff9  com.apple.Heimdal (4.0 - 2.0) <E7D20A4D-4674-37E1-A949-635FFF7C439A> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimda l
        0x7fff91fcd000 -     0x7fff92058fff  libCoreStorage.dylib (380) <AE14C2F3-0EF1-3DCD-BF2B-A24D97D3B372> /usr/lib/libCoreStorage.dylib
        0x7fff921d3000 -     0x7fff921fbffb  libxslt.1.dylib (13) <C9794936-633C-3F0C-9E71-30190B9B41C1> /usr/lib/libxslt.1.dylib
        0x7fff921fc000 -     0x7fff92206ff7  com.apple.bsd.ServiceManagement (2.0 - 2.0) <2D27B498-BB9C-3D88-B05A-76908A8A26F3> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/Ser viceManagement
        0x7fff92207000 -     0x7fff92214ff7  libxar.1.dylib (202) <5572AA71-E98D-3FE1-9402-BB4A84E0E71E> /usr/lib/libxar.1.dylib
        0x7fff92215000 -     0x7fff92274fff  com.apple.framework.CoreWLAN (4.0 - 400.45.1) <775F9444-8059-30A2-8058-7F7ACD68CCF1> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
        0x7fff92275000 -     0x7fff922c2fff  com.apple.AppleVAFramework (5.0.27 - 5.0.27) <D01B7D87-4BDC-3E48-A79B-951D05075F9D> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleV A
        0x7fff922c3000 -     0x7fff922d5ff7  com.apple.MultitouchSupport.framework (245.13 - 245.13) <D5E7416D-45AB-3690-86C6-CC4B5FCEA2D2> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Version s/A/MultitouchSupport
        0x7fff922d6000 -     0x7fff922d6ffd  libOpenScriptingUtil.dylib (157) <19F0E769-0989-3062-9AFB-8976E90E9759> /usr/lib/libOpenScriptingUtil.dylib
        0x7fff922d7000 -     0x7fff922e7ffb  libsasl2.2.dylib (170) <C8E25710-68B6-368A-BF3E-48EC7273177B> /usr/lib/libsasl2.2.dylib
        0x7fff922e8000 -     0x7fff923aaff1  com.apple.CoreText (352.0 - 367.15) <E5C70FC8-C861-39B8-A491-595E5B55CFC8> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
        0x7fff923ab000 -     0x7fff923b2fff  libcompiler_rt.dylib (35) <4CD916B2-1B17-362A-B403-EF24A1DAC141> /usr/lib/system/libcompiler_rt.dylib
        0x7fff923b3000 -     0x7fff923b5ff7  com.apple.SecCodeWrapper (3.0 - 1) <F5107AD0-20CD-328C-8B2E-74CB6F3169F6> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A /SecCodeWrapper
        0x7fff926bc000 -     0x7fff926f0fff  libssl.0.9.8.dylib (50) <B15F967C-B002-36C2-9621-3456D8509F50> /usr/lib/libssl.0.9.8.dylib
        0x7fff92704000 -     0x7fff92872ff7  libBLAS.dylib (1094.5) <DE93A590-5FA5-32A2-A16C-5D7D7361769F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libBLAS.dylib
        0x7fff92873000 -     0x7fff928c5fff  libc++.1.dylib (120) <4F68DFC5-2077-39A8-A449-CAC5FDEE7BDE> /usr/lib/libc++.1.dylib
        0x7fff928c6000 -     0x7fff92b0efff  com.apple.CoreData (107 - 481) <E5AFBA07-F73E-3B3F-9099-F51224EE8EAD> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
        0x7fff92b0f000 -     0x7fff92b98fff  com.apple.ColorSync (4.9.0 - 4.9.0) <B756B908-9AD1-3F5D-83F9-7A0B068387D2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ColorSync.framework/Versions/A/ColorSync
        0x7fff92bb5000 -     0x7fff92bb9ff7  libheimdal-asn1.dylib (323.12) <063A01C2-E547-39D9-BB42-4CC8E64ADE70> /usr/lib/libheimdal-asn1.dylib
        0x7fff92bba000 -     0x7fff92c85fff  libvDSP.dylib (423.32) <3BF732BE-DDE0-38EB-8C54-E4E3C64F77A7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvDSP.dylib
        0x7fff92c86000 -     0x7fff92c8dfff  com.apple.NetFS (6.0 - 4.0) <8E26C099-CE9D-3819-91A2-64EA929C6137> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
        0x7fff92d5e000 -     0x7fff92da5fff  libFontRegistry.dylib (127) <A77A0480-AA5D-3CC8-8B68-69985CD546DC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
        0x7fff92da6000 -     0x7fff92da9fff  com.apple.TCC (1.0 - 1) <32A075D9-47FD-3E71-95BC-BFB0D583F41C> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
        0x7fff92daa000 -     0x7fff92dc5ff7  libCRFSuite.dylib (34) <FFAE75FA-C54E-398B-AA97-18164CD9789D> /usr/lib/libCRFSuite.dylib
        0x7fff92dc6000 -     0x7fff92dcbff7  com.apple.MediaAccessibility (1.0 - 43) <D309D83D-5FAE-37A4-85ED-FFBDA8B66B82> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/Me diaAccessibility
        0x7fff92dcc000 -     0x7fff92dd2fff  com.apple.AddressBook.ContactsFoundation (8.0 - 1365) <CFB1A744-8096-3FAB-B55E-2E6C410A0376> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versio ns/A/ContactsFoundation
        0x7fff92dd3000 -     0x7fff92e62ff7  com.apple.Metadata (10.7.0 - 800.12) <04486C95-3E49-36C4-89B6-925E925BB417> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/Metadata.framework/Versions/A/Metadata
        0x7fff92e63000 -     0x7fff92ec3fff  com.apple.ISSupport (1.9.9 - 57) <E1E343D7-222C-3458-9D1F-FC600B7F1C50> /System/Library/PrivateFrameworks/ISSupport.framework/Versions/A/ISSu pport
        0x7fff92ec4000 -     0x7fff93312fff  com.apple.VideoToolbox (1.0 - 1273.29) <6E38291D-7A81-3033-AFB9-61ABD38B6371> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToo lbox
        0x7fff93313000 -     0x7fff93358ff7  libcurl.4.dylib (78) <A722B4F0-1F6C-3E16-9CB1-4C6ADC15221E> /usr/lib/libcurl.4.dylib
        0x7fff93359000 -     0x7fff9335cfff  libCoreVMClient.dylib (58.1) <EBC36C69-C896-3C3D-8589-3E9023E7E56F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC oreVMClient.dylib
        0x7fff935a5000 -     0x7fff93608ff7  com.apple.SystemConfiguration (1.13 - 1.13) <F05F4149-981B-380B-8F50-51CE804BBB89> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/S ystemConfiguration
        0x7fff93609000 -     0x7fff9366ffff  com.apple.framework.CoreWiFi (2.0 - 200.21.1) <5491896D-78C5-30B6-96E9-D8DDECF3BE73> /System/Library/Frameworks/CoreWiFi.framework/Versions/A/CoreWiFi
        0x7fff9368f000 -     0x7fff9369dfff  com.apple.CommerceCore (1.0 - 42) <ACC2CE3A-913A-39E0-8344-B76F8F694EF5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Fr ameworks/CommerceCore.framework/Versions/A/CommerceCore
        0x7fff936a8000 -     0x7fff93730ff7  com.apple.CorePDF (4.0 - 4) <92D15ED1-D2E1-3ECB-93FF-42888219A99F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePD F
        0x7fff93741000 -     0x7fff93743ff3  libsystem_configuration.dylib (596.12) <C4F633D9-94C8-35D9-BB2D-84C5122533C7> /usr/lib/system/libsystem_configuration.dylib
        0x7fff93744000 -     0x7fff9374cfff  libsystem_dnssd.dylib (522.1.11) <270DCF6C-502D-389A-AA9F-DE4624A36FF7> /usr/lib/system/libsystem_dnssd.dylib
        0x7fff9374d000 -     0x7fff93c71fff  com.apple.QuartzComposer (5.1 - 316) <B20E93C3-8517-3E5C-83B6-C312C839C5D0> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qua rtzComposer.framework/Versions/A/QuartzComposer
        0x7fff93cd5000 -     0x7fff93cd7ff7  com.apple.securityhi (9.0 - 55005) <405E2BC6-2B6F-3B6B-B48E-2FD39214F052> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Sec urityHI.framework/Versions/A/SecurityHI
        0x7fff93cf0000 -     0x7fff94b3cff5  com.apple.WebCore (9537 - 9537.70) <7A90E9D3-4F26-3049-9C96-C6B8CB1395C8> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/Web Core.framework/Versions/A/WebCore
        0x7fff94ddd000 -     0x7fff94ea0ff7  com.apple.backup.framework (1.5 - 1.5) <92C8038F-CC00-3202-90D8-3C3AEC90986F> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
        0x7fff94ea1000 -     0x7fff94ea5ff7  libcache.dylib (62) <BDC1E65B-72A1-3DA3-A57C-B23159CAAD0B> /usr/lib/system/libcache.dylib
        0x7fff94ea6000 -     0x7fff94f03fff  com.apple.imfoundation (10.0 - 1000) <122D84B9-871D-3885-9D8D-840CD529028F> /System/Library/PrivateFrameworks/IMFoundation.framework/Versions/A/I MFoundation
        0x7fff94f04000 -     0x7fff94f4ffff  com.apple.ImageCaptureCore (5.0 - 5.0) <F529EDDC-E2F5-30CA-9938-AF23296B5C5B> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/Imag eCaptureCore
        0x7fff94f50000 -     0x7fff94fb4ff3  com.apple.datadetectorscore (5.0 - 354.0) <9ACF24B8-3268-3134-A5BC-D72C9371A195> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Version s/A/DataDetectorsCore
        0x7fff94fb5000 -     0x7fff94ff7ff7  libauto.dylib (185.5) <F45C36E8-B606-3886-B5B1-B6745E757CA8> /usr/lib/libauto.dylib
        0x7fff94ffd000 -     0x7fff95b71ff7  com.apple.AppKit (6.9 - 1265) <0E9FC8BF-DA3C-34C5-91CC-12BC922B5F01> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
        0x7fff95b72000 -     0x7fff95bacff3  com.apple.bom (12.0 - 192) <989690DB-B9CC-3DB5-89AE-B5D33EDC474E> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
        0x7fff95bad000 -     0x7fff95c24fff  com.apple.CoreServices.OSServices (600.4 - 600.4) <36B2B009-C35E-3F21-824E-E0D00E7808C7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/OSServices.framework/Versions/A/OSServices
        0x7fff95c25000 -     0x7fff95c28ffa  libCGXType.A.dylib (599.7) <2FC9C2BC-B5C5-3C27-93F9-51C6C4512E9D> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resource s/libCGXType.A.dylib
        0x7fff95c29000 -     0x7fff95c55ff7  com.apple.framework.SystemAdministration (1.0 - 1.0) <36C562FF-5D91-318C-A19C-6B4453FB78B9> /System/Library/PrivateFrameworks/SystemAdministration.framework/Vers ions/A/SystemAdministration
        0x7fff95c56000 -     0x7fff95c5effc  libGFXShared.dylib (9.0.83) <11A621C3-37A0-39CE-A69B-8739021BD79D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG FXShared.dylib
        0x7fff9608b000 -     0x7fff9608effc  com.apple.IOSurface (91 - 91) <07CA8A59-1E32-3FB6-B506-18DAF58A8CE0> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
        0x7fff9624b000 -     0x7fff9626ffff  libxpc.dylib (300.1.17) <4554927A-9467-365C-91F1-5A116989DD7F> /usr/lib/system/libxpc.dylib
        0x7fff96270000 -     0x7fff96295ff7  com.apple.ChunkingLibrary (2.0 - 155.1) <B845DC7A-D1EA-31E2-967C-D1FE0C628036> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/ A/ChunkingLibrary
        0x7fff962a1000 -     0x7fff962a1ffd  com.apple.audio.units.AudioUnit (1.9 - 1.9) <6E89F3CB-CC41-3728-9F9A-FDFC151E8261> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
        0x7fff962a2000 -     0x7fff9638cfff  libsqlite3.dylib (158) <00269BF9-43BE-39E0-9C85-24585B9923C8> /usr/lib/libsqlite3.dylib
        0x7fff9638d000 -     0x7fff96398fff  libGL.dylib (9.0.83) <984A960A-C159-3AE5-8B40-E2B451F6C712> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG L.dylib
        0x7fff963b3000 -     0x7fff96923fff  com.apple.CoreAUC (6.22.08 - 6.22.08) <F306D552-2220-3160-88EA-C916193C5EFD> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAU C
        0x7fff96c5d000 -     0x7fff96c67ff7  com.apple.CrashReporterSupport (10.9 - 538) <B487466B-3AA1-3854-A808-A61F049FA794> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Vers ions/A/CrashReporterSupport
        0x7fff96c68000 -     0x7fff96d9dffa  com.apple.WebKit (9537 - 9537.71) <8A07478D-B2CA-3724-81E4-ADC10E1AD3EA> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
        0x7fff96f4b000 -     0x7fff96f7aff5  com.apple.GSS (4.0 - 2.0) <ED98D992-CC14-39F3-9ABC-8D7F986487CC> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
        0x7fff96f7b000 -     0x7fff96fc2ff7  libcups.2.dylib (372) <348EED62-6C20-35D6-8EFB-E80943965100> /usr/lib/libcups.2.dylib
        0x7fff97058000 -     0x7fff970b1fff  libTIFF.dylib (1038) <5CBFE0C2-9DD8-340B-BA63-A94CE2E476F2> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/lib TIFF.dylib
        0x7fff970b2000 -     0x7fff971a0fff  libJP2.dylib (1038) <6C8179F5-8063-3ED6-A7C2-D5603DECDF28> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/lib JP2.dylib
        0x7fff971a1000 -     0x7fff971effff  com.apple.opencl (2.3.57 - 2.3.57) <FC03A80D-543A-3448-83FF-D399C3A240D9> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
        0x7fff97274000 -     0x7fff9727bff7  com.apple.phonenumbers (1.1.1 - 105) <767A63EB-244C-34F1-9FFA-D1A6BED60C31> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/P honeNumbers
        0x7fff9727c000 -     0x7fff972a4ffb  libRIP.A.dylib (599.7) <6F528EE3-99F8-3871-BD60-1306495C27D5> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resource s/libRIP.A.dylib
        0x7fff972a5000 -     0x7fff972a5fff  com.apple.AOSMigrate (1.0 - 1) <ABA8F3F2-BC96-3F89-AAF4-1AA459A0BCBD> /System/Library/PrivateFrameworks/AOSMigrate.framework/Versions/A/AOS Migrate
        0x7fff972a6000 -     0x7fff9738afff  com.apple.coreui (2.1 - 231) <432DB40C-6B7E-39C8-9FB5-B95917930056> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
        0x7fff973a3000 -     0x7fff973a3fff  com.apple.Cocoa (6.8 - 20) <E90E99D7-A425-3301-A025-D9E0CD11918E> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
        0x7fff973a4000 -     0x7fff973a8fff  com.apple.CommonPanels (1.2.6 - 96) <6B434AFD-50F8-37C7-9A56-162C17E375B3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Com monPanels.framework/Versions/A/CommonPanels
        0x7fff97400000 -     0x7fff97566fff  libGLProgrammability.dylib (9.0.83) <9C97E814-F674-30F8-8C2D-C45FC1E7D934> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LProgrammability.dylib
        0x7fff97567000 -     0x7fff97568ff7  com.apple.print.framework.Print (9.0 - 260) <EE00FAE1-DA03-3EC2-8571-562518C46994> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Pri nt.framework/Versions/A/Print
        0x7fff97569000 -     0x7fff9765aff9  libiconv.2.dylib (41) <BB44B115-AC32-3877-A0ED-AEC6232A4563> /usr/lib/libiconv.2.dylib
        0x7fff976a1000 -     0x7fff976b0ff8  com.apple.LangAnalysis (1.7.0 - 1.7.0) <8FE131B6-1180-3892-98F5-C9C9B79072D4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/LangAnalysis.framework/Versions/A/LangAnalysis
        0x7fff976b1000 -     0x7fff976b1fff  com.apple.Accelerate.vecLib (3.9 - vecLib 3.9) <F8D0CC77-98AC-3B58-9FE6-0C25421827B6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/vecLib
        0x7fff976b2000 -     0x7fff976bbfff  com.apple.CommonAuth (4.0 - 2.0) <1D263127-5F27-3128-996D-7397660D0C6E> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/Com monAuth
        0x7fff976bc000 -     0x7fff976bdff7  libSystem.B.dylib (1197.1.1) <BFC0DC97-46C6-3BE0-9983-54A98734897A> /usr/lib/libSystem.B.dylib
        0x7fff976be000 -     0x7fff9774aff7  com.apple.ink.framework (10.9 - 207) <8A50B893-AD03-3826-8555-A54FEAF08F47> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink .framework/Versions/A/Ink
        0x7fff977cd000 -     0x7fff977d4ff7  liblaunch.dylib (842.1.4) <FCBF0A02-0B06-3F97-9248-5062A9DEB32C> /usr/lib/system/liblaunch.dylib
        0x7fff977d5000 -     0x7fff977d8ff7  libdyld.dylib (239.3) <62F4D752-4089-31A8-8B73-B95A68893B3C> /usr/lib/system/libdyld.dylib
        0x7fff97a0a000 -     0x7fff97bb7f27  libobjc.A.dylib (551.1) <AD7FD984-271E-30F4-A361-6B20319EC73B> /usr/lib/libobjc.A.dylib
        0x7fff97bb8000 -     0x7fff97bb9fff  com.apple.TrustEvaluationAgent (2.0 - 25) <334A82F4-4AE4-3719-A511-86D0B0723E2B> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Vers ions/A/TrustEvaluationAgent
        0x7fff97bba000 -     0x7fff97c55ff7  com.apple.PDFKit (2.9 - 2.9) <AD968A31-6567-30A7-A699-154C88DB56D0> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDF Kit.framework/Versions/A/PDFKit
        0x7fff97c5c000 -     0x7fff97c7efff  com.apple.framework.familycontrols (4.1 - 410) <4FDBCD10-CAA2-3A9C-99F2-06DCB8E81DEE> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A /FamilyControls
        0x7fff97c7f000 -     0x7fff97cb4ffc  com.apple.LDAPFramework (2.4.28 - 194.5) <7E31A674-C6AB-33BE-BD5E-F5E3C6E22894> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
        0x7fff97cb5000 -     0x7fff97cbbff7  com.apple.XPCService (2.0 - 1) <2CE632D7-FE57-36CF-91D4-C57D0F2E0BFE> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPC Service
        0x7fff97cbc000 -     0x7fff97cc3ff3  libcopyfile.dylib (103) <5A881779-D0D6-3029-B371-E3021C2DDA5E> /usr/lib/system/libcopyfile.dylib
        0x7fff97cc4000 -     0x7fff980a5ffe  libLAPACK.dylib (1094.5) <7E7A9B8D-1638-3914-BAE0-663B69865986> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libLAPACK.dylib
    External Modification Summary:
      Calls made by other processes targeting this process:
        task_for_pid: 16
        thread_create: 0
        thread_set_state: 0
      Calls made by this process:
        task_for_pid: 0
        thread_create: 0
        thread_set_state: 0
      Calls made by all processes on this machine:
        task_for_pid: 10960
        thread_create: 3
        thread_set_state: 0
    VM Region Summary:
    ReadOnly portion of Libraries: Total=363.8M resident=356.7M(98%) swapped_out_or_unallocated=7300K(2%)
    Writable regions: Total=3.7G written=2.0G(53%) resident=2.3G(62%) swapped_out=8K(0%) unallocated=1.4G(38%)
    REGION TYPE                      VIRTUAL
    ATS (font support)                 32.0M
    ATS (font support) (reserved)         4K        reserved VM address space (unallocated)
    CG backing stores                  23.3M
    CG image                           3076K
    CG raster data                      104K
    CG shared images                    236K
    CoreAnimation                       584K
    CoreAnimation (reserved)              8K        reserved VM address space (unallocated)
    CoreGraphics                         32K
    CoreImage                            72K
    CoreServices                       1440K
    Foundation                            4K
    IOKit                             274.5M
    IOKit (reserved)                      4K        reserved VM address space (unallocated)
    Image IO                            112K
    Kernel Alloc Once                     8K
    MALLOC                              1.6G
    MALLOC (admin)                       32K
    Memory Tag 240                     17.9M
    Memory Tag 241                       92K
    Memory Tag 242                       12K
    Memory Tag 251                       24K
    OpenCL                               80K
    OpenGL GLSL                        1792K
    STACK GUARD                        56.1M
    Stack                              17.2M
    VM_ALLOCATE                         1.7G
    __DATA                             64.7M
    __IMAGE                             528K
    __LINKEDIT                         76.9M
    __TEXT                            286.9M
    __UNICODE                           544K
    mapped file                        99.5M
    shared memory                        68K
    TOTAL                               4.3G
    TOTAL, minus reserved VM space      4.3G
    System Profile:
    Model: MacBookPro5,4, BootROM MBP53.00AC.B03, 2 processors, Intel Core 2 Duo, 2.53 GHz, 8 GB, SMC 1.49f2
    Graphics: NVIDIA GeForce 9400M, NVIDIA GeForce 9400M, PCI, 256 MB
    Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1067 MHz, 0x859B, 0x435435313236344243313036372E4D313646
    Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1067 MHz, 0x859B, 0x435435313236344243313036372E4D313646
    AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8D), Broadcom BCM43xx 1.0 (5.106.98.100.22)
    Bluetooth: Version 4.2.0f6 12982, 3 services, 23 devices, 1 incoming serial ports
    Network Service: Wi-Fi, AirPort, en1
    Serial ATA Device: TOSHIBA MK5065GSXF, 500.11 GB
    Serial ATA Device: HL-DT-ST DVDRW  GS23N
    USB Device: Built-in iSight
    USB Device: Keyboard Hub
    USB Device: Apple Optical USB Mouse
    USB Device: Apple Keyboard
    USB Device: Internal Memory Card Reader
    USB Device: Apple Internal Keyboard / Trackpad
    USB Device: IR Receiver
    USB Device: Intuos5 touch S
    USB Device: BRCM2046 Hub
    USB Device: Bluetooth USB Host Controller
    Thunderbolt Bus:
    Nov 7, 2013 10:20 AM   in reply to AndyForshaw
    Crash report data (while helpful) isn't what I'm looking for here.  I'm looking for system console log data.  It looks like this:
    Note that this is a screenshot from 10.8.5, but it should look pretty similar under 10.9.  Also note that the slow performance/freeze/hang issue is different than the "keyboard shortcuts stop working issue" also found on 10.9.  Please do not confuse the two issues as I'm trying to diagnose why PS is having performance issues under 10.9.
    It is possible that when the application does slow down or freeze that many messages are being logged to the console log above.  I'd like someone to confirm that if possible.
    Thanks again for everyone's help with this,
    Adam
    Nov 8, 2013 5:57 AM   in reply to Venture1
    Yeah, this is the problem I was having. I solved it by... taking back my computer! The newest macbook pros can't be reverted back to mountain lion... which is the only solution. It's been over two weeks now and I'm not very confident in a timely solution. I can't imagine any graphics professionals having a fun time since updating to mavericks.
    Nov 8, 2013 6:07 AM   in reply to AndyForshaw
    You're missing a number of updates. http://adobe.ly/PS-Up-To-Date
    Process:         Adobe Photoshop CS6 [1590]
    Version:         13.0.0 (20120315.r.428)
    Nov 8, 2013 6:09 AM   in reply to Venture1
    The issue where the paint>Undo and PS stops responding to KB shortcuts is being tracked here:
    http://feedback.photoshop.com/photoshop_family/topics/keyboard_shortcu ts_not_responding_photoshop_cs6_mavericks
    Dec 11, 2013 1:15 PM   in reply to ChrisML
    As a Professional, I can tell you that this issue is really annoying !!
    My workstation is a 2009 MacPro with 16gb of RAM, and I monitor it with a little App called Memory Clean.
    I usually work on Webdesigns with hundreds of layers, dynamic ones, vector shapes and icons... I have to quit PS CC ten times a day.. I can open only 2 PSD files at a time, and of course use only 1 CC software at a time... Photoshop crashed several times, I lost precious time to remake work I lost... Adobe AND Apple support might have loved insults I sent them in the crash reports..
    I disabled Open CL, RAM available drops slower, but in the end, System runs with only 30 Mb after 25 minutes of work... CAN YOU BELIEVE THAT ?
    Please, find a way to fix it.. I don't pay my licences (since CS3..) to have these issues, maybe the problem is the Mavericks OS and its RAM "smart use".. BTW, it's not my problem, FIX IT, with or without Apple guys, FIX IT, FIX IT !
    (On this screenshot You can see the RAM available on the top menu..)
    Dec 11, 2013 1:20 PM   in reply to wstlone
    Get rid of Memory Clean - it does more damage than good, especially on MacOS 10.9!
    Dec 11, 2013 1:22 PM   in reply to AndyForshaw
    You crashed in part of the OS, and it appears to be due to corrupt data structures on your disk.
    Running disk utility and repairing your disk usually solves those problems, but FinderKit is notorious for crashing when the disk is even slightly corrupted.
    Also, you really, really need to install the Photoshop updates.
    Dec 12, 2013 10:22 AM   in reply to Chris Cox
    These comments are a lot like the comments over on the inDesign board. After a great deal of yelling and screaming (figuratively, of course) Adobe provided a link to CS6 for everyone to download and use until the real problems between Adobe and Apple are fixed. We aren't blaming anyone or angry. Hey! We've all been through upgrades before. They never work all that well at first.
    This one is slightly more annoying than usual, but Adobe is helping by making CS6 available until they get it all worked out.
    I ran the latest CC update for Photoshop and it is working just fine for now, but if it continues to slow down to a crawl like inDesign CC was doing I'll switch back to CS6, which I now have installed, until they fix it and fix it, they will.
    Dec 12, 2013 2:17 PM   in reply to Chris Cox
    Thanks for your replies Chris, but Memory Clean is only there to inform, I never use it to clear out memory caches...
    It seems that the problems come from that precise point... Today I opened the wrong file and cancelled the opening. The Memory available was starting to reduce and it stopped just after the cancellation.. Maybe it could help..
    Yes but I already did this with Onyx before posting here.
    I swear CC suite is the only one failing with Mavericks..
    @Pat Carney:
    Downgrading to CS6... impossible for now, too many projects running InDesign CC...
    Dec 12, 2013 3:17 PM   in reply to wstlone
    Photoshop CC files open in CS6.
    InDesign files can be saved as IDML files.
    IDMLs open effortlessly in CS6.
    The hardest transition is installing the software.
    Jan 4, 2014 11:02 AM   in reply to Venture1
    I just subscribed to CC ("upgraded" from CS5 12.0.4) and am having the problem discribed in the original post.  More than once per hour when using Photoshop CC.  I, however, am using Slow Leopard on this Mac and not Mavricks.  I have never had this issue with previous versions of Photoshop... and am still not as I've swiched back to using CS5 until this is fixed (why am I paying a monthly fee to use CC if it's broken?).  So the problem is definately CC specific for me.
    Photoshop CC
    OS X 10.6.8
    No Perian
    No Tablet
    Jan 5, 2014 6:12 PM   in reply to whoTookMyName
    Can anyone report their CC issues with Mavericks having gone away? I couldn't open a number of programs, and others were running terribly slowly, so downgraded back down to Lion. However, there are a number of key under-the-hood features I'd like to take advantage of in Mavericks, so am looking for confirmation that it's now safe. I use basically all the apps except for the web dev ones. Many thanks!
    Jan 9, 2014 2:10 PM   in reply to lehestro
    More information if it is at all useful....
    Caveat:This is on Snow Leopard an not Mavericks but the symptoms are exactly the same as discribed in the OP and throughtout this thread.  PS is 14.1.2 x64.
    I can reliably cause this problem with the Healing Brush by making the brush somewhat larger or smaller and then using the brush.  The freeze then happens for me almost every time.  And as discribed above by other posters, I am able to recover by switching focus to another app and then back to PS.  And as aslo discribed above , while frozed PS consumes about 100% CPU (i.e., 1 core's worth) and slowly eats up all the system's physical memory.
    I have also had touble with other tools too, most frequently the Polygonal Selection tool.
Bookmarked By (1)
