Closing Framemaker via batch processing
Oct 28, 2013 12:27 PM
Tags: #batch #close #automatic #exit #quit #patternstream
We have a batch mechanism running via Patternstream.  Everything is finally working well, except I can't get Frame to close on it's own once a report is complete.  Is this a registry or maker.ini issue?  I'm working with Frame 11 on Windows Server 2008 machines.  thanks! Al
    Oct 28, 2013 12:30 PM   in reply to Tiggyboo1
    Pretty sure that FM11 isn’t supported on a W2K8 server
    Oct 28, 2013 3:05 PM   in reply to Tiggyboo1
    Depending upon how you're running your set-up, i.e. using an operator directly on the server vs submitting over a network, you may need to be using FrameServer to be license compliant.
    The shutdown of FM should be triggered by PatternStream, so you probably need to take up this issue with Finite Matters.
