Cockney Viking
Spacing Between Elements
Oct 28, 2013 12:57 PM
How can I reduce the space between the two elements below (h2 & p)?
There is a significant gap between the two lines which cannot be reduced with padding / margin. The gap does reduce with font size  but not as much as I would like.
<header>
    <h2 id="BannerLineLarge">BPM Resolution Ltd</h2>
    <p><span id="BannerLineSmall"> Process Management Solutions </span></p>
  </header>
    Oct 28, 2013 1:04 PM   in reply to Cockney Viking
    The gap you are seeing is caused by the browser default margin settings for the <p> and <h2> tags.
    You can remove it with css...
    h2 {margin:0:}
    p {margin:0;}
    Or you can add in your own settings...
    h2 {margin-bottom:5px;}
    p {margin-top:5px;}
    Oct 28, 2013 2:04 PM   in reply to Cockney Viking
    Incidentally, why are you using <span> tags?  You don't need them.
    <p id="BannerLineSmall">Process Management Solutions></p>
    Nancy O.
    Oct 29, 2013 6:16 AM   in reply to Cockney Viking
    Cockney Viking wrote:
    Thanks - that did the trick.  It looked like these settings were set 0 in the CSS Designer, but they cannot be....
    That's something Adobe should look at.
    Rather than showing the margin as the grayed out 0px in the little display box of the css designer, it really should say "default" unless you change it to 0px. There are more than a few elements that receive "default css" given by the browsers, it would be nice if that was displayed as default, rather than assuming the person using the program knows there is a default.
