I made a recording with Presenter 9
I edit the audio. I just cut some silence... When I listen to the audio in the editor, everything is fine.
When I export my presentation, Presenter export 1 audio file per cut that I have made.
For example, on slide 2, I have 1 minute of audio
I made 2 cuts...(to remove 5 sec of silence two times) so now the file is 50 seconds long
In the audio editor, I have a 50 seconds audio clips that play correctly
When I export my presentation, I have 3 audios overlaping each other and the duration of the slide is like 30 seconds (the duration of the longest audio part)
That issue was not in previous version of Adobe Presenter...
How to correct that ???
I found a solution...
My Powerpoint was a PPT. I saved it in PPTX and now, everything is fine.
I just saw that thread: http://forums.adobe.com/thread/1298040?tstart=0
But me I don't want to delete the audio... I want all the audio one after the other...
Hi
Can you please share me the presentation as Adobe Presenter Package and also the published output
Please send it to malyanp@adobe.com.
Also is it possible to give the scenario in which you faced the issue
We will try to see what the issue is and resolve it for you.
Mahesh
