Flash Professional Help | Packaging applications for AIR for iOS
Oct 28, 2013 8:16 PM
    Oct 28, 2013 8:16 PM   in reply to Community Help
    I am unable to launch the iOS simulator from flash CC or find any info online about this problem. I have tried reinstalling flash and xcode. The error I get is:
    iOS publishing requires files which are not installed. Please quit Flash Professional and run the original installer to ensure that all optional components are installed.
    SDK is missing GPL component /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneSimulator. platform/Developer/SDKs/../../../../../usr/llvm-gcc-4.2/lib/gcc/
    Oct 28, 2013 9:55 PM   in reply to AngryINeedAnotherScreeNam
    This would happen if you are using iOS SImulator7.0 with AIR3.8 SDK. To test with iOS Simulator7.0, please use AIR3.9 SDK(using Manager AIR SDK).
    Please let me know if the problem persists!
    Thanks and Regards,
    Meenakshi
    Oct 28, 2013 11:17 PM   in reply to meenat3
    Hi Meenakshi,
    I'm using air 3.9.0.1030.
    thanks,
    Andy
    Oct 28, 2013 11:21 PM   in reply to AngryINeedAnotherScreeNam
    Hi Andy,
    Could you give information on OSX & iOS Simulator version also.
    Thanks and Regards,
    Meenakshi
    Oct 28, 2013 11:27 PM   in reply to meenat3
    OSX 10.9
    Simulator   Version 7.0 (463.9.4)
    Oct 29, 2013 1:01 AM   in reply to AngryINeedAnotherScreeNam
    Please give it a try with the latest AIR3.9 SDK build available, and let me know.
    Thanks and Regards,
    Meenakshi
    Oct 29, 2013 3:25 PM   in reply to meenat3
    After going over the documentation carefully again I found the error was my
    fault as I missed the scroll bar with the path to the iOS simulator and was
    only entering   "
    Applications/Xcode.app/Contents/Developer/Platforms/iPhoneSimulator.pl atform/Developer"
    I've fixed this now and the simulator will launch from flash cc however the
    app is not installed. If i extract the payload and manually dump the .app
    file in the applications folder I can use it in the simulator but not when
    using any of the iPad devices.
    Dec 12, 2013 8:06 AM   in reply to meenat3
    Hi Meenakshi,
    I am having the exact same trouble as Andy... First off, how do you install AIR3.9SDK in Flash? Second, what is the exact path to the Simulator on mac? and finally how do you manage AIR SDK.
    Thanks!
