Deep6Sully
Rendering a 5.1 output
Oct 29, 2013 8:37 AM
This is what I'm trying to render
Codec: MPEG AAC Audio(mp4a)
Channels: 3F2R/LFE
Sample rate: 48000Hz
I'm trying to create a Left, Right, Center, LFE, Left Rear and Right Rear file to run on a Windows machine, and doing it on a Mac!
It appears that I should use the Apple Audio Toolkit which should allow me to create an .m4a format file which I believe will satisfy the requirement.
When I select this for output and render, it says my destination folder is not available or full.  I can render other formats, and have no problem to the same location (about 2T available)
I get the same problem with the AAC format when I attempt to render using it.
I've just downladed Audition CC, so it should be the most current software.
Any suggestions?
  • SteveG(AudioMasters)
    Oct 26, 2006
    Oct 30, 2013 3:29 AM   in reply to Deep6Sully
    Assuming that Audition is sending the toolbox within core audio what it needs, this sounds like an Apple problem, not an Audition one. But, because it's on a Mac and the vast majority of us don't use them, I can't tell you absolutely. So, you will almost certainly need a developer comment about this.
