PP CC will NOT render timeline, crashes, OpenCL.dll to blame?
Oct 31, 2013 5:27 PM
Tags: #pro #premiere #crash #render #cc #opencl.dll
Hey all. I very much appreciate any help. I just opened CC for the first time, used CS6 since it came out with hardly any problems at all. (It should be noted that no version of Premiere has ever been run on this machine) I brought in some footage, tried to render and within 10 seconds it crashes. I have tried to only render certain portions, copy/paste to a new sequence, render audio only all with the same results. Below are all the details.
Sequence AVCHD 720p 30fps about a 50 minute clip, plugins used, dynamics, eq and RGB curves
PP CC 7.0.1
Windows 7 64bit SP1
Asus X79 Sabertooth LGA2011
Intel i7 4820 3.7ghz
16gb ram
Sapphire 7900 HD Radeon series running 13.200.16.0 drivers
I think it is related to my GPU because of the crash report below. Something to do with OpenCL.dll
CRASH REPORT.
Problem signature:
  Problem Event Name: APPCRASH
  Application Name: Adobe Premiere Pro.exe
  Application Version: 7.0.1.105
  Application Timestamp: 51cbdef8
  Fault Module Name: OpenCL.dll
  Fault Module Version: 1.2.11.0
  Fault Module Timestamp: 5244a047
  Exception Code: c0000005
  Exception Offset: 0000000000002b8c
  OS Version: 6.1.7601.2.1.0.256.48
  Locale ID: 1033
  Additional Information 1: edde
  Additional Information 2: eddea275a78afc51b189ccf4ea3eecb4
  Additional Information 3: 1424
  Additional Information 4: 14246fec5a8b55b22735c484f3fad52f
Thanks again for the help!!
Andrew
    Oct 31, 2013 5:27 PM   in reply to Droidtn
    What happens if you switch from hardware GPU acceleration, to software only?
    Oct 31, 2013 6:29 PM   in reply to Droidtn
    That's worth a try.  Just be sure to visit the AMD web site, don't count on Windows Update for those drivers.
