How do I make one period of a sine wave in illustrator?
Oct 31, 2013 5:25 PM
Tags: #wave #sine
I started a thread earlier this evening but I think that I accidentally flagged it as "solved" or something like that (I'm new to this forum). So I'm trying this again. I want to know if there's a way of creating a sine wave in illustrator. I've managed to create a cosine wave in
    Oct 31, 2013 10:03 PM   in reply to ekmanch
    One of the easiest ways is to splt a circle in two, move the bottom half over then join them.
    This can also be done with the pen tool you would half 3 points a beginning, middle and end. The control handles should be vertical. Moving the handles away from the point increases the curve and moving it closer decreases the curve. The length of each handle should match the other points.
    You can also use the arc tool, playing around with that tool can result in a sine wave by using the tool 2 to 4 times.
