Cannot open JPEG files in PE9
Oct 31, 2013 6:18 PM
Cannot open JPEG files in PE9 "because an unknown or invalid JPEG marker type is found"
    Oct 31, 2013 6:25 PM   in reply to Phaint
    Have you by any chance used a forbidden character like a dot or a slash in the file name? Does this happen with all jpegs or only with certain ones?
    Oct 31, 2013 6:42 PM   in reply to Phaint
    Okay, now I'm confused. Your post title and the body of your first post say that you can't open JPEG files and now you san that you can't anything that isn't a jpeg. So sorry, but can you clarify exactly what is happening and also which version of your operating system?
    Oct 31, 2013 6:54 PM   in reply to Phaint
    Thanks. Can you open these files in Preview?
    Oct 31, 2013 8:58 PM   in reply to Phaint
    Try resaving one in preview and then opening it in PSE. Does it work then?
    Nov 1, 2013 7:24 AM   in reply to Phaint
    No jpeg file can have layers, ever. I think the problem may be something in your work flow if you think you are able to create jpgs with layers. Please explain exactly how you are saving these files and give an example of how you are naming them.
    Nov 1, 2013 8:50 AM   in reply to Phaint
    it wants
    to default into a JPEG file and there is a JPEG marker on the end of the
    saved file even when I select Photoshop format.
    I would really like to see a screenshot of the save as window, since any time you have a layered file PSE fights you every step of the way and makes you save as a copy when you choose jpeg as the format.
