How do I make interactive slides for HTML5?
Nov 1, 2013 6:11 AM
Tags: #flash #slideshow #html5 #cms
I need to produce a simple interactive slideshow to HTML5. I'm very new to Flash, but quite experienced in most of the CC suite.
I followed a tutorial last night and created a slideshow of 4 images and 4 buttons, which worked fine when output to and .swc and HTML wrapper. But when I Published using the Tooklkit Create for JS, the slideshow continuously cycled and the buttons (from the button library – with UP/OVER/DOWN/HIT) flashed and cycled.
Is the code, that I was prompted to write in the ActionScript, available in a library of snippets? Otherwise, if I start a new project and want slightly different actions, how will I know what code to enter?
I've used Muse sucessfully and used the Slideshow Widget, editing and placing the forward and back buttons, styling captions and removing the thumbnail option. I can output this as code (Export to HTML), and the preview works fine. I can also open this in Dreamweaver.
Would I be best advised to continue working in Muse, or will I be missing a whole lot of tricks not using Flash.
Is there any other Adobe application that would beter suit my task, and allow a CMS?
Thanks, Jerry
  • kglad
    Jul 21, 2002
    Nov 1, 2013 5:17 PM   in reply to JerryPF
    use muse if it does what you want.  using flash to create html5 is not a seemless experience.
  • kglad
    Jul 21, 2002
    Nov 2, 2013 8:38 AM   in reply to JerryPF
    i don't know much about muse.  you should post that question in the muse forum, http://forums.adobe.com/community/muse?view=discussions
