dahliagirl
eliminating space above character in ai file for exporting to png
Nov 2, 2013 4:51 PM
Tags: #png #character #space #extra #type
The image above is for a website which has a colored background. The image will be exported as a PNG file so that the background is transparent. I am unable to eliminate the space above 40th. It seems the bounding box around the character can not go past the artboard area. Is there a way to crop in Illustrator or do something to the character so that it is flush at the top on the artboard area?
Angela
    Nov 2, 2013 8:47 PM   in reply to dahliagirl
    It should go flush. Take a look at the character panel, in there you can adjust the vertical movement. It may have been set to a large value for a different project. (guessing)
    Nov 3, 2013 3:15 AM   in reply to dahliagirl
    Angela,
    As I (mis)understand it, you may consider this:
    1) Edit>Preferences>General>tick Use preview Bounds;
    2) Select the live Type and Effect>Path>Outline Path;
    3) Set the Artboard to fit the artwork and export;
    4) Edit>Preferences>General>untick Use preview Bounds.
    Nov 3, 2013 9:51 AM   in reply to dahliagirl
    You are welcome, Angela.
